Old Oct 09, 2012, 04:14 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
If I'm not mistaken, Enterprise7 has the Hacker A60-6XS, which is a 370Kv, which also means 6S. Is it a 20 inch prop? Sure pulls like one. Nice vid, Cody.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Oct 09, 2012, 07:51 PM
bmoney69 is offline
Find More Posts by bmoney69
bmoney69's Avatar
United States, DE, Wilmington
Joined May 2004
ok i was about to fabricate the stand offs for the motor based on the information provided in the manual. the manual says 4 5/8" from face of motor box to drive washer. i dry fit the cowl just to check to see if that was about right.....lucky i did. with the cowl fit (flush with the back of F1) it's 6" from motor box to front of cowl (or to drive washer). then i realized that my motor box is half the size as all the other photos i've seen. i didn't like the fact i had to use 2" stand offs......they are actually going to be 3.5"! not happy about this.......obviously EF changed the design.....anyone else have this condition and is there a published distance for the "new" design? looking for the distance from the motor box to drive washer.
thanks,
bill
bmoney69 is offline Find More Posts by bmoney69
Old Oct 09, 2012, 08:37 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by bmoney69 View Post
anyone using the Motrofly DM4325-380 on 6s......what props are you using? 19x10 is the recommended prop by Ken, but i'm wondering about a 20x10?
No 20x10 on the 380 on 6s please. Warranty goes bye bye with that much prop. Too many amps= too much heat. That would be really rough on your batteries and esc too.
Manta1 is offline Find More Posts by Manta1
Old Oct 09, 2012, 08:39 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Oh and 19x10 really is sweet on that setup. And if you want a bigger prop, you can drop the kv of the motor.
Old Oct 09, 2012, 09:04 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
19X10 it is. thanks!
Old Oct 09, 2012, 09:09 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
can someone also confirm (who has the long motor box) the distance from the centerline to the offset thrust line on the face of the firewall? mine is 1/4" and i'm wondering if that was not changed when the motor box extension was reduced.
thanks,
Bill
Old Oct 09, 2012, 11:30 PM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
thanks,
Bill
6.25" is the correct length. The thrustline offset is correctly laser scribed on the firewall.
We made this change when DLE changed their 30cc engine to a rear carb design as folks complained about having to recess the carb inside the motor box. We usually include a brief addendum that outlines this but obviously you did not receive it. I apologize for the inconvenience and hope these details get you taken care of.
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old Oct 10, 2012, 09:57 AM
Enterprise7 is online now
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
True! (too much RC Today Show). I have the A60-6XS with a Hobbywing 100A Platinum ESC. Originally it was a ICE 100, but that had issues. Cody flew it to the 6 minute timer and we put in 4600 mah back into the 5300 Gens Ace 30C. Earlier in the day I was flying a Xoar 20x10 PJN, but I managed to damage it in a hard left ground turn to avoid the end of the runway. This flight was done on a APC 20x8 electric Rick lent me. Only pulling around 75 amps.
For standoffs I used 2x Evolution 38mm from the LHS. I drilled them out and used M5x100 or 90mm bolts. I know this is a $40 solution, but it was quick and easy and worked.
Let me see if I get tapatalk to work with a picture as I have one on my iphone.
Enterprise7 is online now Find More Posts by Enterprise7
Old Oct 10, 2012, 09:59 AM
USA, NH, Manchester
Joined Jun 2010
Description:
Old Oct 10, 2012, 11:03 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
very good. no problem.....thanks for the clearification.
Old Oct 10, 2012, 01:46 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
anyone know where i can get 3.5" hex or round 3/8" aluminum standoffs w/ male/female ends? i don't want to spend $40-60 for anodized aluminum. i know there are tons of machine shops out there selling these for a couple of bucks a piece but i can't find one that will sell only 4.
Old Oct 10, 2012, 02:08 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
You may or may not find something here, but this is where I usually start...
http://www.troybuiltmodels.com/items...NDOFF1.25.html
http://www.swbmfg.com/products/Stand-offs.html
http://www.troybuiltmodels.com/categ...tand-Offs.html
Old Oct 10, 2012, 02:48 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
ahh....bingo!
http://www.mcmaster.com/#standard-th...ndoffs/=jnvawc
Old Oct 10, 2012, 04:13 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Nice find... thanks.
Old Oct 10, 2012, 05:07 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
no problem. take a look at the male/female hex standoffs. what's nice about those is you can screw them right into the blind nuts in the firewall and then screw the motor into the other end. you don't have that heavy 4" long bolt running thru the whole thing.
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9446 Yesterday 07:05 PM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 09:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 12:33 PM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 09:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 03:48 PM
