Old Sep 19, 2012, 11:05 PM
Enterprise7 is online now
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
I run a Castle BEC pro. I also use HV servos and run them at 8.5V. I am thinking of backing off to 8V as they are fast enough as is and I don't want to push them too far. Also this setup allows 2 leads into the RX so that the amp draw is distributed a bit.
Enterprise7 is online now Find More Posts by Enterprise7
Old Sep 20, 2012, 08:41 AM
bmoney69 is offline
Find More Posts by bmoney69
bmoney69's Avatar
United States, DE, Wilmington
Joined May 2004
got it....thanks!
bmoney69 is offline Find More Posts by bmoney69
Old Sep 20, 2012, 08:43 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
got mine yesterday....very nice! looking forward to nailing it together!
Old Sep 20, 2012, 12:56 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
anyone running hs-7965mg or 5625mg for ail/rud?
Old Sep 20, 2012, 10:07 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
FWIW, I am using the following:
HS-5245MG x2
HS-5985MG x2
and powering servos with a 2s 1300mAh LiPo regulated to 6v through a Fromeco Sahara regulator.
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Sep 21, 2012, 10:07 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
HS-5245MG x2
HS-5985MG x2
do you mean "HS-5985mg" x3? ail and rud?
Old Sep 21, 2012, 10:17 AM
USA, GA, Atlanta
Joined Nov 2008
Good looking out!
HS-5985 x3
Old Sep 24, 2012, 07:25 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by flarpy View Post
Attachment 5165127
It's over for the clown.
Time to order another... I'm changing my name to "dumb thumb"
What are you gonna do with the airframe?
jw357_23043 is offline Find More Posts by jw357_23043
Old Oct 02, 2012, 06:09 PM
jmanopla is offline
Find More Posts by jmanopla
Joined Dec 2009
Someone Knows wich is the Ref number of the Ultracote Yellow on the Plane
jmanopla is offline Find More Posts by jmanopla
Old Oct 03, 2012, 10:04 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
anyone running the A-50 12L V2 on this plane? if so, do you like it and how many cells are you running?
Old Oct 03, 2012, 11:59 AM
Aeroplayin is online now
Find More Posts by Aeroplayin
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
This motor will require that you decide on your propeller before determining the number of cells. It has a fairly aggressive Kv so you can spin a 19x10 or a 20x8 (maybe) on 6S, but if you go to an 8S setup, you will have to prop down considerably.
You can call Mike or Kyle at Aero-Model.com and I'm sure they will give you the real details, but I'd bet that for this plane, that will perform better with an 18, 19, or 20 inch prop, the 6S is where you'll end up with this motor. I would have selected a lower Kv so that I could swing a bigger prop on more cells (volts).
Aeroplayin is online now Find More Posts by Aeroplayin
Old Oct 03, 2012, 12:53 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
thank you for your response! 6s is kind of where i want to be, so that's why the KV. i know the A-60 6xs seems to be a popular choice, but i'm just looking around the corner. trying to save a little weight. i'm a low and slow 3d'er so i'm not looking for speed and don't need it to be over power, just don't want under powered. ....i just need enough power. just enough torque to get me out of trouble and plenty of a$$ to pull out of a hover. i'll give them a call. i guess i'm just worried about it being underpowered
Old Oct 03, 2012, 02:36 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
UltraCote bright yellow HANU872
This I know for a fact as I just bought a roll to repair a friends Extra.
MLT
MLT67 is offline Find More Posts by MLT67
Old Oct 03, 2012, 03:05 PM
USA, GA, Atlanta
Joined Nov 2008
Thanks a Million MLT
I cant wait to see ya later!
Old Oct 04, 2012, 01:01 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
the CC Ice 100 ESC......can you disable the BEC thru programing or do you have to cut a wire?
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9813 Aug 05, 2016 11:30 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
