Old Sep 10, 2012, 12:06 PM
94'325is is offline
Find More Posts by 94'325is
94'325is's Avatar
Florida
Joined Jan 2010
Does anyone have a spare right wing in red/blue/yellow they're looking to get rid of?
94'325is is offline Find More Posts by 94'325is
Old Sep 12, 2012, 07:21 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Originally Posted by Aeroplayin View Post
Is that with the A60-6XS?
Yes
A60-6XS
Hitec 5565MH x3
Hitec 7245MH x2
Castle BEC pro
Castle ICE 100
The ICE 100 failed and has been sent back to Castle so now I have a Hobbywing 100A in there so I lost at least an ounce off that weight.
Only slighly heavier than the Velox with a much wider fuse. Identical wings in length (I put them up against each other) with the extra having slightly more depth at the wing root. This is probably a decent combination with a DLE-20 or the Mintor 22, or what I really want to read about, the new O.S. GT22.
Enterprise7 is offline Find More Posts by Enterprise7
Old Sep 12, 2012, 07:54 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I'm curious about the Ice... was it an Ice2, and if so, did it fail on the new A60?
Aeroplayin is online now Find More Posts by Aeroplayin
Old Sep 16, 2012, 07:55 PM
bmoney69 is offline
Find More Posts by bmoney69
bmoney69's Avatar
United States, DE, Wilmington
Joined May 2004
does the kit come with all hardware (pushrods, pull-pull, tailwheel assembly, etc?). how about the graphics?
thanks!
bmoney69 is offline Find More Posts by bmoney69
Old Sep 16, 2012, 08:49 PM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
Yep yep yep!!!
powerlines is offline Find More Posts by powerlines
Old Sep 16, 2012, 10:02 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
thanks!
heck yea man press order
Manta1 is offline Find More Posts by Manta1
Old Sep 18, 2012, 09:56 AM
flarpy is offline
Find More Posts by flarpy
Flarpy
flarpy's Avatar
Kitsap County
Joined Nov 2010
Description:
It's over for the clown.
Time to order another... I'm changing my name to "dumb thumb"
flarpy is offline Find More Posts by flarpy
Old Sep 18, 2012, 10:36 PM
USA, NH, Manchester
Joined Jun 2010
I was a ICE 100. The V2s are just for the HVs I think. Yes it was with the A60-6XS. I think the package from castle shows up tomorrow so I'll see if they sent me a new one, or just fixed it. Moral of the story is don't use brake on the A60 until someone else comes up with the proper settings.
Old Sep 19, 2012, 10:02 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
You are correct Enterprise, they do not make the ICE 100 in a V2... to date, I do not think there has been any recalls on the ICE 100.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Sep 19, 2012, 10:35 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Yeah, I see it now... it is the HV ESC's that are now designated as Ice2, but it doesn't have anything to do with the Amps rating. There are Ice2 HV40's, 60's, and 80's too, so it has to do with the volts potential, not Amps, or so it seems.
Old Sep 19, 2012, 12:34 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
done!......ok, i'm sure this information is in here somewhere, i have been reading. however, this is my first high voltage electric and i have some basic questions.
my questing is regarding BEC. i'm sure this will cause a debate, but i'm only looking for my options, because i'm not sure i understand what they all are.
i'm seeing that some people are running a separate BEC and some are not running any (but with a separate reciever pack). i see that you can get the ESC with and without a BEC......i don't see anyone running the ESC with the built in BEC. why is that? the servo load too much for the built in BEC? i assume that a BEC is not required if running a separate RX pack (although it seems that most are doing just that)? is that because the separate BEC will regulate the Voltage to the servos? sorry, i know that's a lot of questions.....just trying to get my head around all the options before i make a decision.
thanks!
Bill
Old Sep 19, 2012, 01:02 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
i'm seeing that some people are running a separate BEC and some are not running any (but with a separate reciever pack). ]i see that you can get the ESC with and without a BEC......i don't see anyone running the ESC with the built in BEC. why is that?
I don't know of any HV ESC's with internal BEC's. If you are going to run this plane on 6S, you can set it up just like the 60 EXPs. If you are going over 6S, you'll need to consider a direct battery connection to the Rx, a 6v BEC, or a HV BEC/Regualtor to power the Rx and servos.
I use a 6v external UBEC on almost all of my planes to this size, then a Rx that already has redundant ports for connecting A123 batteries directly to the Rx when going bigger. Or you can use a BEC/regulator, like the two Castle offers, to attach 2S or 3S Lipos if you have HV servos that can handle the extra juice.
It's really about your servo requirements. If they are not HV, then a 2S 6.6v A123 battery (LiFePO4) plugged directly into the Rx works great for 6v servos. Any LiPo setup for HV servos will require a BEC and/or BEC/Regulator between the battery and the Rx.
Old Sep 19, 2012, 01:15 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
If you are going with 6S, the $17 Motrolfly U-BEC works great right off your main power battery. Deans are already attached, so it's plug and play... bottom of this page:
http://www.subsonicplanes.com/Motrolfly_ESC.html
If you are going more than 6S, this Pro version work great and can pull right off your main battery packs too, or feed a separate battery to it.
http://www.castlecreations.com/products/ccbec.html
Or if 6v is enough for your servos, then you can plug this, or any equivalent, right into your Rx:
http://www.shop.kavarootusa.com/prod...&categoryId=10
http://www.hobbypartz.com/98p-life-1c-1100-2s1p.html
No internal BEC is needed in these cases.
Old Sep 19, 2012, 02:04 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
great!.....thanks, that's great info. if i opted to go the route of a separate RX batt like the A123 at 6v what does the wiring diagram look like? the ESC plugs to the thr and the RX batt plugs to the batt port (or thru a switch if wanted)?
Old Sep 19, 2012, 06:47 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
If you are just going to go with the LiFePO4 A123 right to the Rx, you can do it two ways. You can put a short extension into the Rx, and then plug and unplug the battery into the extension to keep from fumbling around with the Rx port, or you can run a switch on the fuselage to both. I posted a pic on one of the EF threads that showed my JR switch with a charging port with a gate that opened and closed to keep the port pins clean but it will add some unneeded weight.
One switch wire went to the Rx and stayed there, and the other wire went to my battery. I used the switch to turn the Rx on and off, to connect my volt meter to, so I could monitor the voltage, and to connect the charger to at the field so I didn't have to take the battery out. The stable chemistry of the A123 means that I wasn't as hesitant to charge it in the plane like I would a Lipo. But again, the weight may or may not make this worthwhile. They do make pin ports without the switch or gate too, and they are lighter. Being able to check and charge at the field is not a bad thing.
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9812 Jul 26, 2016 05:41 PM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
