Old Jul 13, 2010, 06:15 AM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
I agree with Tim on this kind of setup, I was running a very similar 68" setup but with the HS7985MG's the digital 985's I was running those off the internal ICE100's BEC and i did suffer a brown out on Spektrum during a manoeuvre that involved all control surfaces.
I decided to go with a Western Robotics Super Hercules which is a 10A constant BEC and so far no problems. The other thing if you are using the ESC's internal BEC is to ensure there is no binding on surfaces as this can draw a large amount of current causing issues.
IMO go with an external BEC with digitals, use the internal BEC provided no binding on analogs.
simon737 is offline Find More Posts by simon737
Old Jul 13, 2010, 07:11 AM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Originally Posted by simon737 View Post
IMHO go with an external BEC with digitals, use the internal BEC provided no binding on analogs.
Well said Simon!!
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Jul 13, 2010, 11:45 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
I know that many of us have had problems with the internal BEC in ICE controllers and Chris Hinson specifically told me on this plane to use a separate BEC or battery to power the RX.
Initially I ran CC UBEC off of the main flight batteries and that worked well until that Scorpion motor failed. When that happened, even though the ESC BEC was disabled, I lost control if the servos every time I tried to restart the motor in the air before I landed. The big voltage drop from trying to turn a shorted out motor or some sort of queertrons associated with that sent the UBEC nuts. It was a near disaster.
Now, I am back to what I used to believe, which is on high power setups to run your RX and Prop from two different separated power supplies.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jul 13, 2010, 12:07 PM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Originally Posted by hercdriver7777 View Post
....Now, I am back to what I used to believe, which is on high power setups to run your RX and Prop from two different separated power supplies.
Another benefit of this is that it's safer to do any tranmitter changes like model selection or programming changes without risk of the motor starting unexpectedly. You can just power up the RX with the main battery unplugged.
Chris, can you cast any light on whether the 70" & 78" Extra are essentially the same design aside from the different size? I'm trying to decide between them and wondering if there's anything else I should consider besides cost and size..... like if one's optimised more for 3D and one more for precision, etc....
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Jul 13, 2010, 12:15 PM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Aidan, the 78 inch Extra is IMAC legal, the 70 inch is based on the 48" EXP (Experimental Progressive) and has the forward placed canopy. While both fly 3D and precision very well, I'd say the 78 is more optimized for precision and the 70 more for 3D.
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old Jul 13, 2010, 12:34 PM
straightedge_ is offline
Find More Posts by straightedge_
click here
straightedge_'s Avatar
San Diego, CA
Joined Feb 2008
...Initially I ran CC UBEC off of the main flight batteries and that worked well until that Scorpion motor failed. When that happened, even though the ESC BEC was disabled, I lost control if the servos every time I tried to restart the motor in the air before I landed. The big voltage drop from trying to turn a shorted out motor or some sort of queertrons associated with that sent the UBEC nuts. It was a near disaster.
Holy cow! Thanks for the tip.
straightedge_ is offline Find More Posts by straightedge_
Old Jul 13, 2010, 12:48 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
I use a Castle cc bec pro with a 2s 1300 lipo on all my 65-78'' planes.
cc bec pro is set at 6 volts.
I don't trust the internal bec at all. It's just a piece of mind for me.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Jul 13, 2010, 03:29 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Chris,
What servos were you running in this application? Digital or analog?
Thanks!
Tim
Old Jul 13, 2010, 04:11 PM
Columbia SC
Joined Feb 2005
Hey Tim,
My setup is:
2 HS 5245 on Elevator
3 HS 7985 everywhere else
AXI 5320/18 (started with Scorpion but changed to AXI)
Ice 100 ESC
Castle Ulitmate BEC with TP1350 2S
Hyperion 4200, Flightmax 5000 and the new PowerEdge 5000 batteries from RCAccessory.com.
Old Jul 13, 2010, 04:18 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Hey Tim,
My setup is:
Ice 100 ESC
Copy, thank you sir!!
Looking forward to seeing your next video!
Tim
Old Jul 13, 2010, 04:53 PM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Any of you have trouble with the HS-5245's centering properly?
I heard of some people have trouble with them.
Cory
Old Jul 13, 2010, 04:58 PM
Columbia SC
Joined Feb 2005
5245s are working great for me.
Old Jul 13, 2010, 07:07 PM
smelyal8r is offline
Find More Posts by smelyal8r
Guerilla Huck Power..activate!
smelyal8r's Avatar
Round Rock, TX
Joined May 2004
So...why run both a separate BEC and battery to power the servos....redundancy? If the flight pack dies will the external bec take over running the servos?
smelyal8r is offline Find More Posts by smelyal8r
Old Jul 13, 2010, 07:34 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
For my piece of mind, I always run a separate UBEC for any plane 57 and larger.
for my 57-60" stuff, I typically use a hobbywing switchmode UBEC powered directly from the main flight pack.
Anything mid 60's to low 70's gets a ccbec pro powered off a 2s 1600.
For my 89" plane, I go with a ccbec pro and a 2s 2200 pack since its running 5 HS7955TG's
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jul 13, 2010, 07:44 PM
smelyal8r's Avatar
Round Rock, TX
Joined May 2004
So in your 70" planes are you just using the ccbec pro as a regulator for the 2s 1600 flight pack?
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9813 Aug 05, 2016 11:30 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
