Old Sep 18, 2010, 11:31 AM
Zenmaniac is offline
Find More Posts by Zenmaniac
Building with TLAR precision
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Originally Posted by johannlochner View Post
That's not a bad weight at all Dave!
My one wing core weighs 33g
sooo ...
10g cloth and +-10g epoxy....
Very light!!
What was your glass lay-up??
Did you lay it up on the bias? and does it "feel strong enough?
Good one Dave!
Sorry... missed all the questions...
I used 2oz cloth -- if my math is any good is like 50g/m2.
Didn't put it on the bias, but should have. It allowed way too much twist. This weekend's full wing will be a double layer of 3/4oz cloth, one on the bias and the other straight on each side. Wish me luck!
Tested a new bag last night, held 12lbs of pressure rock solid all night.
-= Dave
Zenmaniac is offline Find More Posts by Zenmaniac
Old Sep 18, 2010, 05:56 PM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
-= Dave
Thanks Dave
Do you use any other reinforcing in places like the LE, TE, wing tips and hinge line?
3/4 oz is pretty light
The lightest cloth I can get is 30g/m2
Are you trying live hinges or other... (taped/ silicon-ed)
We went out to friends this evening and got nothing done on the wing...
Sean's fuz is curing and tomorrow,
I'll tackle the wing...
If the wind does not blow!
johannlochner is offline Find More Posts by johannlochner
Old Sep 18, 2010, 11:23 PM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Thanks Dave
I'm following Thepasty's recommended 6oz (200g) cloth on the LE. 3/4oz/yd x 2 layers should give me 1 1/2oz/yd on a side, which converts to 50.2 g/m2 if my math is right, close to the 50g on posting #1.
I was going to use Goop hinges, never made one but it seems simple and strong, and I've got Goop in the drawer. I've never made a live hinge either.
-= Dave
Old Sep 19, 2010, 01:21 AM
Stirring the pot
Joined Jun 2008
Sooo...
We enlisted some help!
As regards a temporary vacuum regulator!
That is until Alain decides to come back!!
Sean's Dad did the modifications as per Steve's diagrams....
And it works!
Sort of..
It regulates between 12-17"
Which is way better than I managed!
so today we'll do Sean's wing
Just got to spray up the Mylars first!
Old Sep 19, 2010, 01:41 AM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
Nice work!
If you want a tighter deadband, you can get it by having the contact between the micro switch and the bolt closer to the bend on the switch i.e. it moves less distance to turn on/off. You can do that here by rotating the switch so it sits vertically, or by placing a nut on the bolt so the contact is further along.
Oh, and you might want to put a cover over the live wires so you don't accidentaly short them out
Steve
flyonline is offline Find More Posts by flyonline
Old Sep 19, 2010, 03:47 AM
Thepasty is offline
Find More Posts by Thepasty
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
-= Dave
you might want to be careful with the goop hinge Dave, I'm pretty sure goop eats foam for fun. Silicone works well (you need the right stuff) and tape is perfectly functional.
Thepasty is offline Find More Posts by Thepasty
Old Sep 19, 2010, 08:34 AM
Stirring the pot
Joined Jun 2008
Sean's wing is in the bag!
Erm....
May be a bit heavy for his liking....
I did the prep work..
Stood back and surveyed my handy work,
and decided....
More is better!!1
So, some additional reinforcing tape went on the LE!
I also used a very slow curing epoxy..
It may be a couple of days!!
Old Sep 19, 2010, 10:37 AM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
my sally with a single layer of 50g cloth on the wings is still going strong... less weight means you need less strength. I've spanked it in a couple of times hard enough to break the pod keel and the wing is still cool.
Come on J! you can do a 200g version!
Old Sep 19, 2010, 12:41 PM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
Thepasty you are putting the okes under pressure here and I like it I was at the Slope Cafe when Johan arrived with the fuzz and it only weighs 50g
I took some pics and a video clip which I'll load later.
Bakkie is offline Find More Posts by Bakkie
Old Sep 19, 2010, 12:46 PM
Stirring the pot
Joined Jun 2008
Alain's back!
Now....
We have more vacuum regulators than we know what to do with!
Steve...
I am trying!
Sean has a new fuz! (with some paint blemishes)
I think the painted mould stood for to many days without following up with the lay-up!
But, the good news is...
She's light!!
I'll have to do him another wing!
A light one!
Old Sep 19, 2010, 12:53 PM
Bakkie is offline
I think I'm Mode 2
Bakkie's Avatar
Joined Sep 2010
A light one!
does that mean that my wing is gonna be yellow
Old Sep 19, 2010, 01:22 PM
Sean Oelofse is online now
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Alain's back!
Now....
Steve...
I am trying!
She's light!!
A light one!
J, it might be square, but not sure a 3Amp is going to cut it!!
Sean Oelofse is online now Find More Posts by Sean Oelofse
Old Sep 19, 2010, 01:26 PM
Stirring the pot
Joined Jun 2008
Back in your corner Panda!
Old Sep 19, 2010, 01:33 PM
Joined Oct 2006
Cant wait for you Greg!!
Thanx J for the very cool fuzz!!
Old Sep 19, 2010, 01:55 PM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Good caution, Steve. I was going to seal up the end of the foam with some epoxy and microballoons after carving some foam out for the hinge movement.
-= Dave
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 06:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 03:21 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled $100 shipped MJB9 Aircraft - Electric - Jets (FS/W) 3 Nov 03, 2009 09:36 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 09:05 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled MJB9 Aircraft - Electric - Jets (FS/W) 2 Oct 23, 2009 10:13 AM
