Don't think I like it!
The colour scheme and the execution! I should have stuck to the base colour and added the trim in vinyl! Lots of masking.. The release agent is still apparent as the edges were "tearing" I should flat it down and start again! B U T I think I'll just write it down to experience! Sooo... Daron, We'll have another plane to fly the cr p out!![]() ![]() Oh... We still have some fish eye in the painted mould!
The one fairly good thing is... That with paint, the wing weighs 183g Better than Zally1 at 250g! ![]() But I must say, that Zally1 never felt heavy in the air. This one should be even better! ![]()
Hi Johan
Great flying with you today and thanks for the pointers! |
Latest blog entry: Maitlands Pole Cam fun!
2K Paints & Fisheyes
Spraying some 2 component paints into molds can be pain. Here is how I do it:
1) Use the fastest hardener & reducer that you can get your hands on. 2) Read the instructions to determine how the paint can be "forced dry". Most Urethanes can be forced dry by either Infared light or short periods of elevated temps after a short purge time. Some high velocity paints can be fully cured with short wave IR light as quickly as 5 minutes. 3) Mist on your first coat and use either IR light or the appropriate elevated temp and time. This with get your mist coat to a point that will prevent it from being softened by the following heavier coats. Your hot box can come in pretty handy .4) Then hit it with a nice flowing coat. Option 2 - Allow your mist coat to set for a long time before hitting with heavier coats. Option 3 - is to spray the mold with PVA, let it dry, and then you can spray your flowing coat right away (no misting required). Option 4 - Use an anti-fisheye agent that is added to the paint. Some manufactures make it and some don't. Option 5 - Some paints can be put on really heavy till the fisheyes fill. This can cause really long cures times. |
[QUOTE=wyowindworks;15982137]Spraying some 2 component paints into molds can be pain. Here is how I do it:
QUOTE] Thanks Adam You are a wealth of information, and much appreciated! I think I'll try a combination of option 1 & 2... Don't know if I'll come right with the fish-eye inhibitor, but will ask! ![]() Thanks for your input! ![]()
Sooo... Steve.
"Theboxes" should arrive soon... I'm not too sure which fuz was sent to you, but I think it was one that was slightly heavier... at 65g (I can't remember) You know the story... But it looks good! ![]() One of Vic's old flying friends will be coming to the UK at the end of the month. So if we can get our vacuum pump going... He can bring one along if you wish! or.. You can adapt your carbon Sally's wing and keep her out of retirement for a while longer.. ![]()
NICE!!! very nice!
I think it's that dusty pink... Worries me a bit, but I think you are right, It needs some bold signage to break the symmetrical lines a bit! ![]() Nice clean angular cut there Sean... Mine ended up all square, and effected the hinge line a bit! ![]() Sean's is up next! Who can guess his colour scheme??? ![]()
| Thread Tools | |
| Sold NIB Sapac T-45 V1 Composit with Air Sally ducts | mickydee | Aircraft - Electric - Jets (FS/W) | 7 | Dec 11, 2009 05:57 PM |
| Sold Phase 3 F-16 w/ Air Sally fiberglass NIB | mflander | Aircraft - Electric - Jets (FS/W) | 6 | Nov 27, 2009 02:21 PM |
| Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled $100 shipped | mjbennett9 | Aircraft - Electric - Jets (FS/W) | 3 | Nov 03, 2009 08:36 PM |
| Wanted Air Sally Ducts for BAe Hawk | jzuniga | Aircraft - Electric - Jets (FS/W) | 0 | Oct 23, 2009 08:05 PM |
| Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled | mjbennett9 | Aircraft - Electric - Jets (FS/W) | 2 | Oct 23, 2009 09:13 AM |
