Old Jun 19, 2010, 01:14 AM
Thepasty is offline
Find More Posts by Thepasty
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Originally Posted by flyonline View Post
Not sure why you'd need to print the plan?
To get the curves/shape of the pod and fin? I see, You're not replicating Sally, just something that uses the same wing planform... maybe not even that?!
Originally Posted by skinnydoc View Post
Seems like the tail should be simple balsa, for simplicity and weight savings, no?
Hey Doc,
I've been using 6mm Depron with a carbon strip inserted length ways... it weighs nothing... some light grade balsa would defo do the job too, get the grain running length ways and it'll be stiff in the right direction.
On the heavier Carbon Sally I like to bag the tail, just because it looks cool and fits in with the whole composite thing... I certainly wasnt bothered about keeping the weight down with her.
Thepasty is offline Find More Posts by Thepasty
Old Jun 19, 2010, 02:19 AM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
I'll be printing the fin and the pod but not the wing planform (I'll just measure it out on the foam rather than print a massive template), so I guess it's half a plan
I'll be building this one from your plans, so it'll be a Sally for sure - hopefully it will inspire me to do a second one from EPP for lightweight sloping duties/fun urban sloping/Alula replacement.
I made up a fin for a similar plane with balsa but found that it kept breaking off the bottom of the fin if the balsa was horizontal, but anything that made it strong enough to survive the odd bad landing (glass, NS, balsa ply etc.) made it too heavy. Some CF tow CA'd did work but it got messy so I think the Depron tail will be the way to go.
Steve
flyonline is offline Find More Posts by flyonline
Old Jun 19, 2010, 02:28 AM
zummi is offline
Find More Posts by zummi
zummi's Avatar
Cape Town, South Africa
Joined May 2009
Originally Posted by johannlochner View Post
Hey Zummi
Why would you want to thermal with all those heavenly slope sites on your doorstep?
Get some cores cut and join in!
Hermanus is around the corner from you.
We can compare notes and planes later this year...
Let's see what you can do!
Hi Johann
For when there is hardly any wind - OK so this doesn't happen too often, but it is annoying when it does.
Steve - thanks for the info - might have to end up making 2 versions.
zummi is offline Find More Posts by zummi
Old Jun 19, 2010, 04:00 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Originally Posted by like.2.fly View Post
Can you cnc me a set while your at it?
Hey like.2.fly
Now I know why you want a Carbon Sally....
Your Alulas ain't lasting!
That's what happens...
When you use them as Hawk Bait!
Nice footage of the hawk attacks!
Alula glider - Hawk attack 2 (2 min 3 sec)
johannlochner is offline Find More Posts by johannlochner
Old Jun 19, 2010, 05:33 AM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Just got back from an early fly with Hexo, had a great laugh with our Sallys, managed to get some vid so I'll strap a video for you guys to see how a lighter glassed Sally flys.
Old Jun 19, 2010, 07:26 AM
Sean Oelofse is online now
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Hey like.2.fly
http://www.youtube.com/watch?v=r5ZWS...layer_embedded
Ja!!.....if Alula's grew on trees!!
Sean Oelofse is online now Find More Posts by Sean Oelofse
Old Jun 19, 2010, 10:14 AM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Hey like.2.fly
Good catch!
like.2.fly is offline Find More Posts by like.2.fly
Old Jun 19, 2010, 11:12 AM
skinnydoc is offline
Find More Posts by skinnydoc
United States, CA, Berkeley
Joined Feb 2007
depron...
Hey Doc,
Cool Pasty... that's what Dbox did witht the depron... though I think he used 2 layer 3mm depron with carbon between.
I'll get to work on tracing my Alula and cutting a wing... its so small!
Can you show us some build pics and/or close ups of your composite versions?
thx. Good stuff.
btw, I pm'd Dbox... he may chime in here too. I'd love to see some detailed pics of his stuff. He said bagged wing is the way to go vs hollow molded (which he did in that thread... crazy!)
Ben
skinnydoc is offline Find More Posts by skinnydoc
Old Jun 19, 2010, 12:53 PM
Stirring the pot
Joined Jun 2008
I'll come clean..
I did distort the truth...
I did cut the wing back to front!
But..
Where on the drawing does it say...
This way up!
Never mind...
It was only a trail cut so that I could seat the wing on the fuz plug!
I'll have to wait till Monday to get some more Isoboard..
This was polystyrene and a bit soft!
I'll carry on with the plug!
Old Jun 19, 2010, 01:29 PM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
That looks real nice Joan
I'll get some photos of my crew when I'm in the workshop next.
Old Jun 19, 2010, 01:45 PM
Stirring the pot
Joined Jun 2008
Steve..
What battery did you use?
Was it a lipo?
At this point, I'm basing it on 4x AAA's
Weight 54g
The furthest forward would be 40mm from the tip..
I can always change if need be..
The wing span is quite short...
Would it make much difference slightly longer?
May help with wing loading
(You know me and weight gain)
Oh, is the top of the wing flat?
With the dihedral on the bottom,
or wingtip section on the centre line?
J
Old Jun 19, 2010, 02:30 PM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Steve..
Was it a lipo?
J
I used 2s lipo run through an old ESC on Carbon Sally and a 1s lipo straight into the RX on the light glass version. They weigh nothing and I like the fast charging, low discharge and that I have loads of them
The span is short, but thats what makes it Sally , a wider span will reduce roll rate and if you're going pure slope use you dont need the extra span. Carbon Sally goes well in light wind as it moves faster and uses the wing section lift more.
If you check out the wing section templates on the plan you'll see that the top of the wing is flat giving a smidge dihedral to the bottom, helps it to track better.
I've got the vid rendering from today, you'll see how well they go in light lift
Old Jun 19, 2010, 02:46 PM
Stirring the pot
Joined Jun 2008
Some of us battle to read plans....
Old Jun 19, 2010, 03:05 PM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Says the architect
Old Jun 19, 2010, 04:24 PM
Joined Feb 2007
dihedral...
I started sketching it out just now. I cant get the pdf to print full size easily, and its a big PITA to get adobe or mac preview to print pdfs over multiple pages (anyone know how?).
so... I cant get the templates to print full size.
can someone either post a pdf of just the templates, or, give me a clue how much dihedral you pasted onto the bottom of that tip template?
thanks
fun to be working on something so small!
Ben
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 05:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 02:21 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled $100 shipped MJB9 Aircraft - Electric - Jets (FS/W) 3 Nov 03, 2009 08:36 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled MJB9 Aircraft - Electric - Jets (FS/W) 2 Oct 23, 2009 09:13 AM
