Old Jun 11, 2011, 10:18 AM
Ask Surfimp about UltraBatics
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Originally Posted by JimZinVT View Post
Been sitting back here in the corner for a while, quietly watching and learning. No time right now, but maybe this winter.....
Just wondering....what does this:
Welcome, JZ! It's always nice when a lurker speaks up!! Otherwise, it seems like there's not a lot of interest in this fun little plane
We'll have to see what EZ says -- my guess is that it's some Swiss manner of foam, probably similar to the blue or pink stuff we can get here at Home Depot (although it seems to have a really cool surface pattern )
I don't know if you've built composite before, but this is a pretty easy build (and forgiving -- you should see how many bubbles I have in my first wing , and it flies like a dream).
EZ --- great looking wing -- can't wait to see three sCHally's flying!
-= Dave
Zenmaniac is offline Find More Posts by Zenmaniac
Old Jun 11, 2011, 10:59 AM
let's FLY!
JimZinVT's Avatar
United States, VT, Bomoseen
Joined Dec 2007
Stepping once more from the shadows .....
ZenDave - I've built nothing before, composite or otherwise. In fact I've only just begun flying this month (chinese EZG knockoff) and have a "slope trainer" (Windrider Easy Pro) in transit. But I have experience repairing epoxy/glass/kevlar whitewater kayaks from back before they started building them all out of rotomolded polyethylene....so it's not completely new to me. I've never done any vacuum bagging. For the first round though, I may try a foam and tape Sally, since I have no access to bagging equipment, and to keep the cost minimal. I think Steve mentioned such a build early on in the thread (I've read it all )
But I need to get some flying skills first, and take care of one million annoying homeowner chores. It will be a while. So for now, it's back to my corner......
can someone bring me a beer ? mmm...thanks!
JZ
(I think there's a lot of lurkers here, based on the 46,000 views vs. 1600 posts! )
JimZinVT is offline Find More Posts by JimZinVT
Old Jun 11, 2011, 11:13 AM
scratch build everything
DudleyLeRoux's Avatar
South Africa, KwaZulu-Natal, Botha's Hill
Joined Aug 2009
Edwinzea that looks fantastic, well done.
DudleyLeRoux is offline Find More Posts by DudleyLeRoux
Old Jun 11, 2011, 11:50 AM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Originally Posted by Edwinzea View Post
I used a yellow XPS
Ahh... "yellow expanded polystyrene" (obviously....my brain was not switched on). Cool....never seen yellow.
Old Jun 11, 2011, 06:26 PM
Twisted and Confused
flyonline's Avatar
Joined May 2003
My understanding was that XPS was eXtruded PolyStyrene, and that Expanded PolyStyrene was EPS.
It certainly looks like XPS, but can't be sure without a close up. XPS is one solid piece of foam, rather than a heap of small balls crammed together like EPS - XPS cuts nicer and is stronger but is more expensive though
Steve
flyonline is online now Find More Posts by flyonline
Old Jun 11, 2011, 10:23 PM
Switzerland, AG, Lenzburg
Joined Jan 2006
Thank you everyone for the compliments, the good point is that after one meter of distance you cannot see the flaws, I think the key is to polish the mylars before painting I used green turtle wax.
XPS is indeed extruded poly styrene, most commonly known as "blue foam" and widely used as core for bagged wings, Blue foam comes from DOW and is expensive even here :P then there is pink, violet and yellow, all under the same ISO standar but comming from different brands. It was really difficult for me to find the other brands so I was really happy to find this yellow XPS on my local store, I can walk and bring it home D:
THe fuse is now ready and waitin for sanding, filling paint :P men I even dream about it. THe tail is also cut and waiting for paint and reinforcement
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Jun 11, 2011, 11:46 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
I stand corrected! "E"s and "X"s in both....I always get that wrong
Old Jun 12, 2011, 12:24 AM
Joined Jan 2006
The tape idea is good if you use EPP, on normal EPS can also work but the durability is greatly reduced :P there is some people using wrapping paper and white glue, seems to be very strong even DLG had been build like that
http://www.rcgroups.com/forums/showp...&postcount=113
and is freaking cheap
EZ
JZ
Old Jun 13, 2011, 02:13 AM
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Nice finish EZ!
I wonder how the different wing section will effect how Sally performs... time will tell! Altho to truely tell you need to build another wing with PW1211 and let us know the difference
Was your yellow XPS a bit softer and easier to bent than the blue/pink stuff? I've had some yellow in the past.
Thepasty is offline Find More Posts by Thepasty
Old Jun 13, 2011, 09:25 AM
Joined Jan 2006
Steve!! Master of design!!
I have good experices with the HS130 in other plank, I will post some pics later, we used on the prototypes the PW1211 profiles but the HS130 were superior in final speed and turning :P but indeed that is my idea I have the PW1211 templates ready I need to cut them and cut the cores, my problem now is that I have two other pairs of wings cut with HS130 and not a lot of time to build :P
the fuse in now drying the first layer of paint, I think I will have her ready for the next week.
I have at home, blue, violet and yellow XPS and I would say that they are all similar, stiff and soft after cutting, it needs more temperature than blue foam but my wire can take it with no problem.
thanks for sharing this great project
Regards
EZ
Old Jun 13, 2011, 11:10 AM
Joined Jan 2006
Some samll update from todays work :P the fuse have some minor flaws but you can not see them at one meter of distance :P still some morework to do fitting the wings to the fuse. the servos holes are done and also the cable chanels, it is still missing the receiver and battery holder.
On the pics, sCHAlly and Laissa 1.2m plank with HS130 wing both planes have nose cone fuse.
Regards
EZ
Old Jun 13, 2011, 11:21 AM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
The most important part is how it looks in the air, EZ!! After all, these aren't meant for static display, they're meant to MOVE!
-= Dave
Old Jun 13, 2011, 11:34 AM
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Nice work on the fuz EZ!
Don't worry about Shadowman....
He knows how to keep the pressure up!
johannlochner is online now Find More Posts by johannlochner
Old Jun 13, 2011, 12:22 PM
Joined Jan 2006
....wise men said
only fools rush in...
Is amazing the ammount of work it still needs before flying, anyhow I hope I can make some decent video, normaly my camera man is my launchair :P
Back to the shop
EZ
Old Jun 13, 2011, 02:38 PM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Hey.....not entirely fair!! I haven't mentioned ThePasty not finishing his Zally for at least a month!!!
-= Dave
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 05:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 02:21 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled $100 shipped mjbennett9 Aircraft - Electric - Jets (FS/W) 3 Nov 03, 2009 08:36 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled mjbennett9 Aircraft - Electric - Jets (FS/W) 2 Oct 23, 2009 09:13 AM
