Old Jun 16, 2010, 04:50 PM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Build Log
Carbon Sally "Thepasty"
"Carbon Sally" "Thepasty"
This "side arm launch" Carbon plank, is the product of the design and development carried out by "Thepasty" Steve.
He has tested it extensively and has finally (with some coaxing) agreed to allow his fellow slopers to to indulge in a frenzy of of build activity and orgasmic soaring enjoyment...
There are two models available, and we will discuss their merits at length.
Thepasty will kindly provide guidance and advice during "Thebuild"....
And we will do the footwork for all you DIY enthusiasts!!
There are some rules however!
1. You may not produce them commercially without his consent.
2. You have to post build pictures on this thread.
3. You have to post photo's or video of them in flight
That's it!
Here are some video clips as teasers... and hopefully get you all motivated to jump right in!
Jamming with Zally (3 min 2 sec)
Sunset Zally (4 min 5 sec)
Sally in a good blow (1 min 59 sec)
Carbon Sally (2 min 4 sec)
Homebrew SAL Testing (2 min 57 sec)
A morning with Sally (3 min 19 sec)
Here is some general info posted by "Thepasty"
I'll give you the make up of the two Sallys I have at present...
The section is PW1211, the coords can be found here...
http://www.b2streamlines.com/PWairfoils/PW1211.dat
For the chaps who will be cutting with templates, these are included in the PDF Joan posted up top.
That PDF is scaled 1 to 1 if printed at A0.
Carbon Sally:- span ~ 32in
400g's AUW
Wing - 200gsm twill weave carbon, same on the LE
pod - 300gsm plan weave carbon (lost foam).
Fin - Carbon Tow from the 300g carbon cloth and 50g glass finishing layer.
Ply wood keel.
LE = 200g glass
Wings = 50g glass
Foam Core = blue foam
I added 3 or 4 carbon tows opposed top and bottom but I'm not sure they do alot.
Leccy Gear was 2 x E-power 12g metal gear digi servos, 500mah 2s lipo, cheapo 10amp ESC and a Corona RX.
Glass Sally:- span ~ 32in
180g's AUW
Wing - 50g glass with a 200g glass LE and a few carbon tows from the 300g carbon top and bottom.
Pod - a few layers of 200g glass with a 200g carbon bandage to stiffen up where I split the pod.
Fin - 6mm depron with 0.5 carbon strips.
Balsa keel.
Leccy gear was 2 x e-power 8g digi servos, 1s 450mah lipo and 4ch corona synth RX.
PW1211 is designed for a bottom hinged elevon
the elevons are 40mm
cofg is around 33-34mm back from where the pod meets the wing TE.
I used this calculator: http://www.inlandsloperebels.com/Calc/cgcalc.html I'm sure they all use basically the same formulas.
Need anything else? You may want to stick these details along with the above video onto the opening post, will give people quick access to all the shizzle without havign to trawl throuh the thread.
And some basic layouts!
Updated plans
For anyone who's been referencing the old plan I didnt update the span from my very first prototype so its 40" on that plan, this one is the proper 32".
Sally Video Posting....
1. Zally Maiden
Carbon Zally (3 min 15 sec)
2. ZAlly and the slope trash
ZAlly and the slope trash (2 min 54 sec)
3. Speedy Zally
Speedy Zally (3 min 46 sec)
4. Popcorn Zally
Popcorn Zally (2 min 44 sec)
5. Zapper Maiden Flight
Zapper Maiden Flight (2 min 4 sec)
6. Bakkie's 1st flight
ZAlly Maiden (3 min 1 sec)
7. Zenmaniac aka Dave's -+ Sally's maiden flight
Glass Sally maiden flight (4 min 11 sec)
8. Flying Beagle's Leopard Zally
Leopard Zally1.wmv (2 min 9 sec)
9. Dave 'Aka' Shadow man's Glass Sally
Glass Sally, February in Wisconsin (9 min 35 sec)
10. The "Flying Beagle's" Barbie
Barbie & Panther Zally (2 min 45 sec)
11. Layer's Zsally
Zsally first flight (4 min 36 sec)
12 Sean at Maitlands
13 Paul in Australia
Paul DSing at Punchbowl.wmv (1 min 19 sec)
14 Simon in Australia
Glass Sally at Swansea (3 min 30 sec)
15 Dave in Wisconsin
Three Sallys at Play -- (3 min 22 sec)
johannlochner is offline Find More Posts by johannlochner
Old Jun 16, 2010, 06:40 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Steve,
2nd VID, you mention: " I think I get my first snif of a thermal".
Just when your arm is all worn out and you catch that thermal, it' amazing how much more energy you will find to keep the side arm launches going to catch another thermal.
Your lucky that your wife helped in the filming.
How much does your Carbon Sally come out to in ounces.
Eternalflight is offline Find More Posts by Eternalflight
Old Jun 17, 2010, 04:07 AM
Thepasty is offline
Find More Posts by Thepasty
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
You know I said I would help out...
well...
I lied...
Thepasty is offline Find More Posts by Thepasty
Old Jun 17, 2010, 04:19 AM
Stirring the pot
Joined Jun 2008
So, you found it.....
How about some photos of the real one!!
Now's your time...
For fame and....
Ok..
Not so sure of the fortune bit!
Old Jun 17, 2010, 04:32 AM
Stirring the pot
Joined Jun 2008
Steve......
I'll get Sean to start "Thebox" now....
You know how long he takes!
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Only joking!
Hey EF,
Carbon Sally came in at around 14 ounces (I used 200gsm carbon) which equates to 8oz/sq.ft, ideal for light slope work, I've also had her going in a 30mph gale and she ripped it up.
Joan me old mucker... what do you want from your Sallys?
A light glass one (my current one is 180g's) will fly in naff all wind (depending on slope) and when I say fly I dont mean stooging around, it'll carve it up. As the weight goes up it'll need a bit more wind to go well but it'll carry more speed and energy.
The Carbon Sally video above was shot in 10-12mph wind.
As for joiing the pod to the tail... why? you're adding weight out back which means more weight in the nose... and we know where that leads dont we
You could make a separate fin mould to add flanges to where the fin fits the wing, you'd get a stronger fin but less weight.
Old Jun 17, 2010, 04:37 AM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Tonight looks like a nice evening for my light glass Sally, I'll see if I can get some video and piccys.
Heres a pic of Carbon and Glass Sally with the original prototype (now retired)
Old Jun 17, 2010, 04:46 AM
Stirring the pot
Joined Jun 2008
Originally Posted by Thepasty View Post
Only joking!
Hey EF,
Perhaps I'll start listening better...
sooo...
Two part mold...
Do you just stick them together?
How do you get to your gear?
Are both Sally's on the same platform?
If so we'll go light 1st!
I'm sure I'll add the weight naturally...
Old Jun 17, 2010, 05:29 AM
Thepasty is offline
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
Originally Posted by johannlochner View Post
Two part mold...
Stick what together?
The pods on mine to date have been lost foam (you can tell by the finish) so I simply cut the pod in half so the nose comes away and insert a keel to take the radio gear and add strength.
Moulding the pod you could have a lip on the rear pod section so that the nose slips over it and use a keel or make an inner nose to the pod just like a normal mouldy. You could even give the pod a small hatch/canopy and keep it one piece, could be tricky getting your gear in but all that goes up front is the rx and battery.
yep!
Old Jun 17, 2010, 05:49 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
I would like to join the build group! I have had the same type of project in the que since 2006 when I built an EPP "Alula-like" sloper and it flew great. I always wanted to have a Carbon version for the few times a year that I get to fly from slopes with nice LZ's. Here is a video of the maiden of my "Le Bird", EPP construction 13.5oz. Also a link to the thread I posted back then: http://www.rcgroups.com/forums/showt...hlight=le+bird
"Le Bird" Maiden flight 3-27-06 (4 min 8 sec)
I can offer CNC cutting of cores to anyone who wishes to join the fray, I have 25psi and 60psi foam. Keep in mind that I live on the East Coast (50 mile from NYC) and I can ship at your expense.
Sleedo is offline Find More Posts by Sleedo
Old Jun 17, 2010, 09:07 AM
Stirring the pot
Joined Jun 2008
Originally Posted by Sleedo View Post
I would like to join the build group! I have had the same type of project in the que since 2006 when I built an EPP "Alula-like" sloper and it flew great. I always wanted to have a Carbon version for the few times a year that I get to fly from slopes with nice LZ's. Here is a video of the maiden of my "Le Bird", EPP construction 13.5oz. Also a link to the thread I posted back then: [url]http://www.rcgroups.com/forums/showthread.php?t=497667&highlight=le+bird
Welcome on board the Magic Sleedo ride...
The more the merrier...
We'll probably all differ slightly in our approach,
But that's what makes it interesting!
Thanks for the CNC cutting offer, but we're a tad to far away...
There may well be some that might take up your offer!
Great stuff!
Old Jun 17, 2010, 10:16 AM
Stirring the pot
Joined Jun 2008
What is the cog position,
and what size are the ailerons?
All these questions...
Old Jun 17, 2010, 11:37 AM
billscottuk is offline
Find More Posts by billscottuk
Bill Scott
billscottuk's Avatar
United Kingdom, Northern Ireland, Belfast
Joined Nov 2002
What wing section did you use? It's not named on the drawing, is it proprietary?
I usually draw up templates using Profili and hope to have CNC running soon, so the airfoil would be useful
billscottuk is offline Find More Posts by billscottuk
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 05:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 02:21 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled $100 shipped MJB9 Aircraft - Electric - Jets (FS/W) 3 Nov 03, 2009 08:36 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold Used eFlite BAe Hawk with Air Sally ducting - Dismantled MJB9 Aircraft - Electric - Jets (FS/W) 2 Oct 23, 2009 09:13 AM
