Old May 08, 2011, 01:59 AM
Citruz is offline
Find More Posts by Citruz
Joined Nov 2010
Originally Posted by capt View Post
Most likely you have knocked a solder loose, re-touch all the wire/pad connections with a solder gun and try it again.
Thanks for the answer!
I checked the connections with a multimeter and held one end at the little pin on the board, and one end on the tip of the wire and every wire had a connection. I'll redo my soldering later today.
Also, my Arduino is blinking its red LED with a regular interval of about 2 seconds between the blinks when it's connected to my computer, I can't recall it doing like that before. Is there a "what does the blinking mean?"-manual anywhere? Been searching but haven't found anything relevant.
Citruz is offline Find More Posts by Citruz
Old May 08, 2011, 03:33 AM
AdrenaCo is offline
Find More Posts by AdrenaCo
Fly, Crash, Learn, Fly
AdrenaCo's Avatar
France (Beaujolais-Vert)
Joined Nov 2008
Yes, here: http://www.multiwiicopter.com/pages/multiwiicopter-wiki
At about 3 pages down.
AdrenaCo is offline Find More Posts by AdrenaCo
Old May 08, 2011, 07:11 AM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Originally Posted by OrlandoP View Post
That's a mean looking machine (as in really good looking)! The black plastic enclosure and the way it is all layed up looks very professional.
Did you make the frame or did you buy it?
Thanks for the kind words.
I made the frame but the landing gear is from my Avertiacal View XAPCAM 2 axis camera mount.
nicnaimless is offline Find More Posts by nicnaimless
Old May 08, 2011, 09:12 AM
capt is online now
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
They can meter out OK but a cold solder or loose joint will not fly, I had the same problem and after I checked for continuity they all were showing good but it wouldn't work. I went back over them with the hot solder tip it worked again.
capt is online now Find More Posts by capt
Old May 08, 2011, 09:41 AM
pinball is offline
Find More Posts by pinball
USA, AK, Soldotna
Joined Jan 2005
The RED led is the power LED. It should not flicker or flash. Check your power setup.
pinball is offline Find More Posts by pinball
Old May 08, 2011, 10:02 AM
djdavid60 is offline
Find More Posts by djdavid60
If it flies, I can crash it!
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
Originally Posted by troynh View Post
Here's my WiiM+ quad. (No NK)
Very cool Tim. Are those the 2814 Pulsos?
Doug
djdavid60 is offline Find More Posts by djdavid60
Old May 08, 2011, 12:32 PM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Hi Doug,
Nope. 2212/34's - 10x4.7 CW-CCW APC's.
-Tim
troynh is offline Find More Posts by troynh
Old May 08, 2011, 12:50 PM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Hey Guys,
I just finished soldering up my Paris 3.0 board and all I have is the wiimotion+ soldered in right now.
I still don't have my servo wires in yet and was would likehook the board up and load a sketch and check the functions out without having a bec or a esc hooked up yet?
will it function with just the usb power for testing to see if I have everything soldered good?
Randy
Flyingfool is offline Find More Posts by Flyingfool
Old May 08, 2011, 12:51 PM
rollinolin is offline
Find More Posts by rollinolin
Joined Oct 2010
Hi Doug,
-Tim
wow, those are pricy motors....why so expensive?
rollinolin is offline Find More Posts by rollinolin
Old May 08, 2011, 12:53 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Originally Posted by Flyingfool View Post
Hey Guys,
Randy
Yes, you can load the 1.7 sketch on it and check it out using the GUI... it will power the arduino, wm+, and NK. You should be able to see the graph data.
Qrome is offline Find More Posts by Qrome
Old May 08, 2011, 12:56 PM
Duck! is offline
Find More Posts by Duck!
It flew...nearly!
Norway
Joined Apr 2006
First, thanks to all the great work everyone has put into the Wiicopter project, it has opened up the world of copterflying to a great many people who otherwise might never have tried to fly these machines (including me).
A couple of questions:
Yesterday I test flew my Wii for the first time. I always do a control surface (or rotor response in this case) test before taking off as I have seen countless aircraft lost to reversed controls. I noticed while performing this test, on the pitch forward the tail of my Wii lifted as it should, but when I let the stick back to center, the tail seemed to stay in the air and only slowly-slowly return back down. If I need to adjust the P, I, D settings to get it to follow the stick movements, which of them is the correct one to adjust?
I see one can connect an lcd display to the ftdi port on the arduino and after some rummaging through my bitsandbobs box, I found the pictured lcd. Can I use this do you think? GND and 5V are of course used, but do I use the RS232 or TTL input?
Thanks again!
Matthew
Duck! is offline Find More Posts by Duck!
Old May 08, 2011, 02:09 PM
spagoziak is offline
Find More Posts by spagoziak
"Let's put a camera on that.."
spagoziak's Avatar
Twin Cities, MN
Joined Feb 2010
Where to buy APC 10x## SF props? (CW & CCW)
So I bought some EPP 10x4.5 SF props and they're really impressive as far as lift is concerned, but I'm a bit uncomfortable with how much they flex.
I know APC makes CW&CCW 10x4.5 SF props--can anyone recommend a good store to buy them from? I'm looking for somewhere in the continental US.
OR
Is there a better prop than this? I'm using 1050 kv motors (look at this post for more info).
Thanks!
spag
spagoziak is offline Find More Posts by spagoziak
Old May 08, 2011, 02:11 PM
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
They are pricey but worth it. They are very smooth running motors and have a great warranty. I have three of them that I had on my T-Copter prior to going FPV and needing a lot more thrust.
Doug
Old May 08, 2011, 02:20 PM
3DMON is offline
Find More Posts by 3DMON
Fly 3D Mon!
3DMON's Avatar
United States, FL, Sebastian
Joined May 2005
OR
Thanks!
spag
I bought some 10x3.8 apc's from Radicalrc.com
3DMON is offline Find More Posts by 3DMON
Old May 08, 2011, 02:40 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
OR
Thanks!
spag
i bought mine direct from apc themselves, they shipped relatively fast and they obviously carry all of there props...
ohh and theyre outta Cali
paintz2007 is offline Find More Posts by paintz2007
