Old Jul 05, 2010, 12:29 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Sid3ways - Thanks!
rcimports is offline Find More Posts by rcimports
Old Jul 05, 2010, 03:18 AM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
Originally Posted by cdi3d View Post
No green light only the red is contant
mike
Hi,
if no LED goes up after few second, it is a problem of I2C communication.
=> maybe
- a wrong cabling (SDA SCL inversion ?)
- a dead WM+
- a good WM+ which does not match my init code
It is not a RC problem.
Can you post a photo of your WM+ ?
Alexinparis is offline Find More Posts by Alexinparis
Old Jul 05, 2010, 03:29 AM
Paris, France
Joined Jun 2009
Originally Posted by RCvertt View Post
I got it off the ground today.
Is there a way to decrease the yaw gyros sensitivity to vibrations?
We can do more smoothing for this axis, because it is not so sensitive.
But it's not coded for the moment.
Mine shuts down with yaw stick right while having the throttle stick at the minimum position.
You probably have to revert the yaw channel in your radio
My opposite rudder commands seam to be due to the way I have my servo mounted.
There are 2 different problems:
- the yaw channel sense => can be solved by reverting RC channel in the radio
- the gyro correction sense => can be change by reversing a sign in the code
Old Jul 05, 2010, 04:06 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Sounds good. I'll change the direction in the code and TX. Thanks.
Originally Posted by tazdevil View Post
Yep , I was exactly the same problem
all working with a reverse channel and a sign mod in code
Cool. Good to know.
RCvertt is offline Find More Posts by RCvertt
Old Jul 05, 2010, 04:36 AM
tazdevil is offline
Find More Posts by tazdevil
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
tazdevil is offline Find More Posts by tazdevil
Old Jul 05, 2010, 09:50 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Are these PID values for Roll, Pitch, and Yaw? Or does each axis get it's own numbers?
Old Jul 05, 2010, 10:45 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Alex - here are the pics of my WMP+ - Thanks
cdi3d is offline Find More Posts by cdi3d
Old Jul 05, 2010, 01:27 PM
Paris, France
Joined Jun 2009
Did you already try to comment the line in the code ?
// TWBR = ((16000000L / 400000L) - 16) / 2;
Old Jul 05, 2010, 02:30 PM
Paris, France
Joined Jun 2009
P I D settings are global for pitch and roll axis.
PYAW is only for YAW (DYAW and IYAW does not exist as there are 0)
Old Jul 05, 2010, 04:12 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Thanks Alex - Yes I commented the code but no change -
Old Jul 05, 2010, 05:37 PM
tazdevil is offline
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
original WMP working with this code uncomment
I think originalwmp is the best way for 100% succesfull replication
Old Jul 06, 2010, 10:09 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Okay - I have made a little progress - green light on Arduino is now solid green but still no controls from tx - I tried yaw stick lower right to start but nothing - Any ideas?
Old Jul 06, 2010, 10:25 AM
Paris, France
Joined Jun 2009
Okay - I have made a little progress - green light on Arduino is now flashing but still no controls from tx - I tried yaw stick lower right to start but nothing - Any idea why my arduino is flashing green and not solid?
Hi,
If green LED is flashing, this is a good start: the WM+ communication is OK.
But the flash means there is now a problem with your rc TX/RX.
You should recheck the connection between your RX and the arduino.
Old Jul 06, 2010, 11:06 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Okay - Found the problem - one pin on arduino was not fully soldered - Now solid green light on arduino but still no TX control - Using a DX7 TX - Thanks
Old Jul 06, 2010, 11:16 AM
Paris, France
Joined Jun 2009
Ok, good news.
several things to try:
- increase your ATV on all channels (125% for spektrum should be good)
- you'll maybe have to reverse some channels in your radio
