Old Jun 27, 2010, 09:46 PM
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
got a new WM+, hoping I killed the other one, and thats why I can't get it working. I'll try to get things hooked up tomorrow. I'll let you guys know if it works.
BobD
signguy is offline Find More Posts by signguy
Old Jun 27, 2010, 10:27 PM
Brushless
cdi3d's Avatar
Joined Mar 2009
Okay here is a total noob question how do I connect my Esc, servo and rx channel to the Arduino? Hardwire or do I need a certain connector?
mike
cdi3d is offline Find More Posts by cdi3d
Old Jun 28, 2010, 05:08 AM
RCvertt's Avatar
Joined Aug 2007
I'm almost finished with my build.
Can I get more detailed info on when the full throttle thing can happen. Full throttle is kind of scarry.
mike
Solder on male breakout header pins and use female to female jumper wires to connect your receiver and female to male jumper wires to connect your ESC's. Sparkfun has what you need.
RCvertt is offline Find More Posts by RCvertt
Old Jun 28, 2010, 06:39 AM
Alexinparis's Avatar
Paris, France
Joined Jun 2009
When you go full throttle, there is nothing for the moment to prevent all motors to spin at their max, and indeed to use a good gyro correction.
I have to code something to limit motor values so that gyro corrections can still be effective.
You can also buy some servo wires. Female plugs are compatible with breakout header pins.
http://www.hobbycity.com/hobbyking/s...2810pcs/set%29
Alexinparis is offline Find More Posts by Alexinparis
Old Jun 29, 2010, 12:06 PM
Brushless
cdi3d's Avatar
Joined Mar 2009
On the schematic is says a bec is needed - is the correct? Sorry for the stupid questions - Mike
Old Jun 29, 2010, 02:41 PM
Ready to fly MRs
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Yes because the Arduino needs 5V to run as well as your RX does too.
Sid3ways is offline Find More Posts by Sid3ways
Old Jun 29, 2010, 02:49 PM
Brushless
cdi3d's Avatar
Joined Mar 2009
one more dumb question - So if I power my bec from balance plug of my battery - should I connect my servo, esc's, arduino and rx all from the bec? I am assuming this is okay or will it mess up my power up sequence in anyway? This is how I do it on my tricopter - main battery power to ESC's then plug in charge plug -
Old Jun 29, 2010, 02:51 PM
Ready to fly MRs
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Since I've never used an Arduino I can't comment on how and when it needs to be powered. I don't see any issues in using the balance plug to power all of that stuff as long as you don't have a BEC that is a POS.
I will soon see as my parts from Sparkfun should be here in a couple of days as well as my motors and ESCs Just need to figure out the frame.
Paris, France
Joined Jun 2009
The BEC is needed, but it is already included in each ESC.
An external UBEC is not needed.
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Ok, I've ordered the bits so hope to be joining you all very soon. Can I just say thanks Alex for all your hard work, and to Niall for the bits
Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old Jun 29, 2010, 03:17 PM
Brushless
cdi3d's Avatar
Joined Mar 2009
I just finished loading my first sketch onto the arduino - took me little bit to get the pins to line up correctly and stay that way since I dont have any header pins yet - now waiting for Wii motion plus -
Old Jun 30, 2010, 01:39 AM
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
Hi Alex,any news on soft upgrade ?
mine is flying every day
tazdevil is offline Find More Posts by tazdevil
Old Jun 30, 2010, 01:57 AM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by tazdevil View Post
...mine is flying every day...
No flight vids
What Ebay seller did you get your motion+ from?
Old Jun 30, 2010, 02:02 AM
Paris, France
Joined Jun 2009
Hi,
I tried to integrate a nunchuk, but apparently I got a very bad copy of it, single side pcb.
It works, but its step resolution is about 5 degrees. I can do nothing precise with this.
I just ordered another one, with the hope it will be good this time.
Old Jun 30, 2010, 03:43 AM
KayCee_V4's Avatar
Joined Mar 2008
Hi Alex, will the ADXL322 dual-axis accelerometer work with your design ?
http://www.sparkfun.com/commerce/pro...roducts_id=849
KayCee_V4 is offline Find More Posts by KayCee_V4
