ok , 4.2 is fine , need to check in wind , ( I go now to test it ..!)
6 is good on yaw with modifiy the hole pôsition more neer the center of the servo on harm i'm happy , it's equiped for fpv right now with light 2.4 ghz camera 5 V , let's do the test if it's ok , I will change the camera for a better one need to order a screen now or modify the soft for serial command on hyperterminal for pid setting R W on eeprom have fun |
http://wiire.org/Wii/MotionPlus All the copies I saw have not this metal case component. Exemple: http://www.dealextreme.com/details.dx/sku.32506 Wiimote uses fast I2C mode to communicate with WMP. So this erratic operation does not mean copies are better than the original. It’s just a problem of couple Arduino-WMP. |
WMP is the new development ISZ-650 / IDG650 - http://invensense.com/mems/gaming.html jürgen
![]() my tricopter fly good in the wind, just put some trim correction sometime (it's not adxr gyro acc would be help a lot) but it fly great even with the battery just connected by the power wire like an heli who make marchandise transport under it with a cable I thingk an acceloremeter could be great for beginer and fpv I'l try fpv, and it was more difficult than will tricopter who ismore stable my tri has tendence to "autocabre" (don't know the word in english) so with a fish eyes camera it is difficult to pilot at low altitude I think it will be not complicate to adapt a nunshunk on it with all the exemple there is on th web let's see, what do you think alex ? another thing , piro rate is very low, anything to do it more accurate ? i'm happy |
Alexinparis-
Are you using three gyros for stability? I only see two connections to analogue 5 and 6. Is it a 12c thing where all three gyros signals can travel through just two pins? Quote:
Now we're talking. Just an accel, no magnetometer or other junk. |
For the moment, it's only a proportional counter action. Quote:
when I spek of nunchunk it's wmp and nuncunk both the problem of autocabre was due to my propeler to smooth (xufo silverit) I put maxprod one and it's look very better , but one controler have a probleme now?... grunt , do no why it's seem to detect only one lipo at startup ... bbut when I plusg it directly to a receiver it's working, when plug it on tri board , motor start at init and stop a few second later. other motor still working??? I swap 2 controler same problem on another output of the tri board, so I've got a probleme with my simple controler...... need to order new one .. MDR yes yaw need PI cause it's oscilate a lot when you turn the yaw and return quicly to the neutral position of the stick. heading is very correct waiting improved soft, once again good job and thank you |
