Old Jun 17, 2010, 03:48 PM
tazdevil is offline
Find More Posts by tazdevil
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
ok, maybe it's the solution
but in aeroquad with wmp,there is not this problem even it's powered in 5V bythe controler.
i don't know why. pwm with tempo could be the solution,waiting for your new code
thx
Originally Posted by Alexinparis View Post
I noticed something I still don't understand:
  • When I power the arduino with FTDI USB module (to upload a version or to debug), the WMP initialization is always good.
  • When I powered the arduino with the BEC of the ESCs, the WMP initialization fails sometimes as you explain. But when the init is good, every thing works perfectly after.
In both cases, the WMP is powered with 5V.
It may be due to the quality of the 5V at the very beginning.
I think I will power WMP with another method:
  • even if it works with 5V, it maybe better to operate WMP under 3.3V
  • I will use a free analog PIN output to create this alim
  • this alim will be a little temporized to have more voltage stability at the beginning.
I don't think bad copies is the origin of this problem
tazdevil is offline Find More Posts by tazdevil
Old Jun 17, 2010, 11:43 PM
AlouetteIII is online now
Find More Posts by AlouetteIII
AlouetteIII's Avatar
near the Beach
Joined Sep 2007
AlexinParis, Nice flying with positive G - I really like your project - signed up for your idea; it's a real WiizArd of a tricopter. Also nice to see a composite monocoque airframe and the use of a LEDlight strip for orientation.
Errors at startup:- Voltage errors aside; My experience with gyro circuitry in general is they are all sensitive to adjacent circuits. In the past I have found that without shielding they perform better when isolated by shielding or at least 60mm distance.
AlouetteIII is online now Find More Posts by AlouetteIII
Site Sponsor
Old Jun 18, 2010, 12:30 AM
tazdevil is offline
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
thank's for your feedback AllouetteIII,I will try this. On my aeroquad, I've got 10cm from controler board to imu
Alex, for the radio,what about the atv limit? 80% ,100% or 150%
what is working the best ?
Old Jun 18, 2010, 01:33 AM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
For the radio, the settings should be [1000-2000] micro seconds for all channels.
On my Graupner/JR, it represents 125% ATV.
I tested successfully yesterday a new init phase. I was wrong in my explanation about the output analog PIN. It does not exist on Arduino
What I did:
- connect WMP VCC to digital PIN 12
- in the setup() phase
- set the PIN 12 output to 0
- wait for 0.5s
- set the PIN 12 output to 1 => 5V VCC (no way to switch a 3.3V)
- and then I2C init phase
This way, the WMP seems to init well at each attempt. I will try also to shield the WMP with a simple piece of aluminium paper.
If we power the WMP and at the same time the Arduino, I suspect some foolish and unpredictable I2C bits are transmitted to the WMP during the Arduino boot, causing a wrong init.
Alexinparis is offline Find More Posts by Alexinparis
Old Jun 18, 2010, 01:43 AM
tazdevil is offline
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
Cool,is thefirmware avaible on you web site,I would like to test it today !
maybe you can put here only he modification code you done
rgds
Old Jun 18, 2010, 02:57 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
- AERODUINO-FUN - less material for an MWC is not
my base with minimal material use is now AERODUINO-FUN
an ATmega328 with Arduino Bootloader and WM +
less material for an MWC is not.
the power supply and the level converters are already available on the BMA020,
so that the pullup resistors on the carrier ITG3205 can be omitted.
die beschreibung im deutschen Forum - > http://forum.xufo.net/bb/viewtopic.php?p=172269#172269
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jun 18, 2010, 04:00 AM
tazdevil is offline
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
this is what I modify on soft myself according your recommendation:
#define POWERWMP 12 // at the begining
void setup() {
Serial.begin(115200);
pinMode (LEDPIN, OUTPUT);
pinMode (POWERWMP, OUTPUT);
initializeMotors();
readEEPROM();
checkFirstTime();
configureReceiver();
digitalWrite( POWERWMP,LOW );
delay(500);
digitalWrite( POWERWMP,HIGH );
initGyro();
zeroGyros();
digitalWrite(LEDPIN, HIGH);
initializeServo();
previousTime = micros();
is that good for you ?
Old Jun 18, 2010, 04:32 AM
Paris, France
Joined Jun 2009
void setup() {
initializeMotors();
readEEPROM();
checkFirstTime();
delay(500);
initGyro();
zeroGyros();
initializeServo();
Yes that sounds good for the soft.
I'll try to release a version this evening or tomorrow.
Old Jun 18, 2010, 06:41 AM
ddrake is offline
Find More Posts by ddrake
ddrake's Avatar
Milan
Joined Mar 2007
Really good looking project.
I will soon give it a try as I have all the hardware.
Would like to have a cheap platform for FPV when I don't feel like risking the expensive MKs
Many thanks!!!!
ddrake is offline Find More Posts by ddrake
Old Jun 18, 2010, 07:04 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
[LIST]
no problem
The WMP has an independent voltage regulator to 3.0V
the ADC are still free.
how about 2POTI for parameter-adjustment?
juergen
Old Jun 18, 2010, 11:28 AM
tazdevil is offline
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
arf , with delay mod to power the wmp , it's not working too, pin 12 has good delay but...
maybe my wmp is not ok
Old Jun 18, 2010, 01:35 PM
Paris, France
Joined Jun 2009
Does it never work, or just sometimes ?
I updated the schemes and the code.
Old Jun 18, 2010, 02:05 PM
Paris, France
Joined Jun 2009
Originally Posted by JUERGEN_ View Post
no problem
Yes it's a good idea, something like in the kkmulticopter to adjusts the PID => no more remote adjustment to handle with GUI or radio/LCD.
I will have to glue them somewhere, because I have no PCB to host them
Old Jun 18, 2010, 02:52 PM
Ciskje is offline
Find More Posts by Ciskje
Ciskje's Avatar
North Italy
Joined Feb 2009
Please take a look at BaronPilot thread, it is the same project, but with autostable mode, very very easy to flight.
I have take a look in your software, something use old info about Wii Motion Plus.
Fast/Slow mode factor is not 5 (10/2), but it is 2000/440 (the two maximun from the invensense docs).
Why are you shifing right yaw by 3 ? You lost some info.
Ciskje is offline Find More Posts by Ciskje
Old Jun 18, 2010, 04:59 PM
Paris, France
Joined Jun 2009
Hi,
I already read all posts of BaronPilot thread
A agree it's a similar project but there are variants:
- LCD&radio conf vs computer&CLI
- I don't plan for the moment to integrate nunchuk and its accelerometers, I think it's not so useful for a moving purpose tricopter
Reading both WMP and nunchuck divides by two the available update of the gyro due to interleave way of decoding I2C data, and then affect stability.
I know the specification of IDG600 or IDG650 and its two outputs 2000 and 440deg/s. The ratio should effectively be closer to 4.5 than 5.
What I observed on the curves with the copy of WMP I got: the response of gyro are not symmetric. On one sens, the fast mode occurs sooner than in the other, and the absolute max values are not the same given the same opposite angular rate. So 5 is empirical and closer to reality from what I observed on my WMP copy.
I divide Yaw gyro value (and also Pitch/Roll along the code) because the last 2 or 3 bits are not usable at all. The noise is much to high to do some calculation with it.
I observed in BaronPilot code that I2C fast mode is not used. It is well supported for Wii accessories and it reduces a lot the time to read raw values.
