Old Oct 12, 2013, 01:28 AM
ehsanware is offline
Find More Posts by ehsanware
Joined May 2013
hi all
i have 10DOF GY80 IMU and a Arduino uno i want to connect between them and after that control quadrotor orientation with programming not RC.
please help me to connect between GY80 and Arduino uno from Multiwii.
TNX
ehsanware is offline Find More Posts by ehsanware
Old Oct 12, 2013, 05:34 AM
Joined May 2013
I got the data from GY80 and saw them into the MultiWii conf but i want to write some code such controller and out put PWM for 4 brushless motor by myself and dont want to use other codes of Multiwii just reading from IMU.is there any body help me???
Old Oct 13, 2013, 02:07 AM
Joined May 2013
there is no one to help me???
Old Oct 14, 2013, 04:37 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
This thread is pratically dead...
All Multiwii work and discussion moved the MWC forums: http://www.multiwii.com/forum/
IceWind is offline Find More Posts by IceWind
Old Nov 10, 2013, 11:50 AM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
for those who may still follow this thread
MultiWii version 2.3 is available now.
Have fun flying
hamburger is offline Find More Posts by hamburger
Old Nov 10, 2013, 07:38 PM
Felixrising is offline
Find More Posts by Felixrising
has an opinion
Felixrising's Avatar
Australia, VIC, Southbank
Joined Jan 2013
Great work!
Felixrising is offline Find More Posts by Felixrising
Old Nov 10, 2013, 07:53 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Another thing on the to-do list...!
Thanks for the great work
Dialfonzo is offline Find More Posts by Dialfonzo
Old Nov 10, 2013, 09:35 PM
djdavid60 is offline
Find More Posts by djdavid60
If it flies, I can crash it!
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
This thread is not dead, we are just all experts now, so no more questions.
djdavid60 is offline Find More Posts by djdavid60
Old Nov 11, 2013, 01:24 AM
SUMPRO is offline
Find More Posts by SUMPRO
Joined Aug 2012
This version 2.3 is great work and i hunger for tring.
But, The MultiWiiConf is no-response (It can't read the data from IMU, but Ver. 2.2 is OK). I had enabled the Internal i2c Pullups (#define INTERNAL_I2C_PULLUPS) & sellected IMU board (GY-86).
SUMPRO is offline Find More Posts by SUMPRO
Old Nov 11, 2013, 01:53 AM
Rust is offline
Find More Posts by Rust
Rust's Avatar
Bulgaria, Sofija-Grad, Sofia
Joined Apr 2013
Have fun flying
Already tried one of the latest betas. It flew very nice!
The biggest difference I immediately saw is the YAW. It's a lot more snappy and it locks in place.
Rust is offline Find More Posts by Rust
Old Nov 14, 2013, 05:17 PM
andreaontheweb is offline
Find More Posts by andreaontheweb
Italy, Lombardy, Milan
Joined May 2012
hi guys i'm a newby in multicopter, i'm trying to connect everything on desk.
I have an arduino uno board and a gy-80 imu well connected and functioning, giving right data in the gui.
The trouble is that when i connect the radio receiver (turnigy 9x not modded) i cannot read the data from the stick in the gui, what it happen is the stick moving crazy on left and right,
I tried two different receiver and get the same results.
I olso tested each pin of the receiver with an esc connected with motor and il function properly.
Could someone give mi some advice?
I'm going crazy.
Thank's a lot.
Andrea
andreaontheweb is offline Find More Posts by andreaontheweb
Old Nov 14, 2013, 05:44 PM
Joined May 2012
I'm going crazy.
Thank's a lot.
Andrea
SOLVED
I don't understand why but appen when power the receiver from external battery, when powered from arduino everything it's ok..
strange???
thank's anyway.
Old Nov 14, 2013, 06:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
SOLVED
strange???
thank's anyway.
Most board are like that.
USB only power the Flight Controler, if you want to power the receiver, you have to power it externally.
Old Nov 14, 2013, 08:32 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
v2.3 thoughts....
I very much like the option to use the gui to configure tricopter yaw servo travel and reversing. No more repeated arduino uploads for minor adjustments.
Yaw stick scaling - about time!! No more messing with P's and travel or linkage settings. Will be testing this soon.
Flight feels much the same as previous firmwares. Have tested 2.3 on a v-tail and a tri, can't feel anything different yet.
The only negative I can think of is no more bluetooth android app compatibility (that is until the developers get up to speed)
There is a massive list of changes this time around so congrats to all involved and keep up the good work.
Stunt Double is offline Find More Posts by Stunt Double
Old Dec 03, 2013, 03:17 AM
Bking1340 is offline
Find More Posts by Bking1340
Bking1340's Avatar
South Africa
Joined Jan 2010
Good day all
I have posted this in the witespy ez3 thread as I use this board on my tri - Greg suggest that I rather ask my question here.
Just replaced my ez3 multiwii 2.2 with 2.3 on my tricopter and used the advise from Picard to change #define MEGA_HW_PWM_SERVOS to //#define MEGA_HW_PWM_SERVOS in config.h and that will bring back the tri servo to D2.
It`s working - so there`s no need to change any wires around from 2.2 to 2.3 on a tri. Thanks Picard.
One problem I do need help with is that my yaw speed to the left are twice as much as the right. If not armed and I give full yaw deflection left or right, the prop almost touch the ground on both sides, so they seem equal.
In wingui left yaw input are 1000, middle 1500 and right 2000. (Tried to play with these in wingui - left input changed to 1350 - still no change)
With or without mag enabled my tri does not yaw without input, it`s just that my right yaw are half the speed of left yaw.
Any advice will be apreciated.
Bking1340 is offline Find More Posts by Bking1340
