Old May 19, 2013, 12:22 AM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
I've just been given one of these by a friend. I uploaded 2.2 onto it and all seems well. I've got all the sensors showing sane data and responding correctly except the compass is out by about 180 degrees. I've done ACC and MAG calibration but it's still saying south is north and north is south. Yawing is represented correctly.
As far as I can tell the compass is used for carefree and all it needs then is that the headings are reliable in relation to each other, which they are.
Is there something I need to do to fix this or does it not matter?
WendoNZ is offline Find More Posts by WendoNZ
Old May 20, 2013, 07:32 PM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
This seems like it would be a basic feature, and I've heard mention of it before, but after much searching the web and gui I can't find anything about it.
Is there any way to have multiple PID, RC Rate, Expo, profiles setup so you can switch between them on the fly with an aux switch. So that you could for example switch between a regular acro mode, and an insane acro mode?
Usually when I want to switch between a regular acro mode, and a much crazier acro mode, I land, then adjust the RC Rate, and take off again. Would be nice to do this on the fly, but not sure if its possible.
carl1864 is offline Find More Posts by carl1864
Old May 21, 2013, 07:01 PM
Electro 2 is offline
Find More Posts by Electro 2
Joined Feb 2013
Isn't presently in MW, but I understand it's coming in the newer versions. As far as rate tweaks, you could use the dual rate switch setup in the radio. I have, works fine.
Electro 2 is offline Find More Posts by Electro 2
Old May 24, 2013, 09:25 AM
quadcopterguy is offline
Find More Posts by quadcopterguy
Joined May 2013
hey guys i have a quick question i am going to order the mwc se with the programmer. like this one (http://www.goodluckbuy.com/mwc-multi...breakout-.html)
my question is this can i turn on theauto level electronic compass and the altitude hold options without using a switch or switches on my remote i dont have a 4 channel remote and dont have any cash to get one at the moment. so im trying to find a way to permanently turn on the level option and such instead of using a 5th or 6th channel to toggle it on and off.
if this is not possible is there a way that instead of connecting the aux channel for the reciever that you would be using o toggle it on and off if i had more than 4 channels can i hook somthing else up to this aux channel like a physical swich or just short out the 2 or 3 prongs for this channel to act as a permanently on swich??
just trying to figure out how to turn on the auto level electronic compass and the altitude hold with only 4 channel reviever/ transmitter
thanks sorry love the sound of this controller just trying to figure out how to do the above
quadcopter guy
quadcopterguy is offline Find More Posts by quadcopterguy
Old May 24, 2013, 09:32 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
quadcopter guy
You define in the GUI which state of aux channel get you into each mode.
If you select all 3 state, it will permanently active.
Dialfonzo is offline Find More Posts by Dialfonzo
Old May 24, 2013, 09:38 AM
Joined May 2013
ahhh sounds like im ordering it now sweet thank you oh and one more thing does this thing need a seperate battery hooked up to it or will it take juice off of the bec comming from one of my esc?
Old May 24, 2013, 09:44 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Power from "one" of the esc only yes
Old May 24, 2013, 09:51 AM
Joined May 2013
sweet thank you very much
Old May 24, 2013, 03:29 PM
Joined May 2013
Sorry one more question. Does it madder what type of reciever im using. I know some aplications dont take rc reciever pwm signal or somthing like that. Im using this reciever ind controller on my kk board and wil be using the same one on my mwc when it gets here. Heres the link to the controller and reciever where i bought it from. (http://item.mobileweb.ebay.com/viewi...id=26740306289)
Old May 24, 2013, 03:49 PM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
If it works with your KK board, it should work with MW
Ceros007 is offline Find More Posts by Ceros007
Old May 24, 2013, 03:50 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes as he said it should work.
Only thing will be to find the right "Order" of channel in the sketch prior to upload it.
Old May 24, 2013, 04:19 PM
Joined May 2013
Ok so the reciever works. Thank youguys. And dialfonzo what exactly do you mean. Do you mean. Fonding the correct way to hoock channek 1-4 up to the board for aileron elevator throttle and rudder?? AnD what do you mean prior to uploading it?
Old May 24, 2013, 04:22 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Forget what I said...
That's true only for ppm receiver.
Think I need a beer..
Old May 26, 2013, 09:32 AM
WalkOver is offline
Find More Posts by WalkOver
Joined Apr 2013
Hello everyone !
I designed my own flight controler based on arduino Mega with an atmega 2560 MCU for my quad X multirotor.
So I have to use the output pin for motor 2, 3, 5 and 6 but only two of them works.
I have connected my motors like this :
Moteur 3 : PE3 (OC3A)
Moteur 5 : PH4 (OC4B)
Moteur 6 : PH5 (OC4C)
Moteur 2 : PE5 (OC3C)
So I change this part of the code in output.ino :
Code:
/****************  Specific PWM Timers & Registers for the MEGA's   *******************/
  #if defined(MEGA)// [1000:2000] => [8000:16000] for timer 3 & 4 for mega
    #if (NUMBER_MOTOR > 0)
      #ifndef EXT_MOTOR_RANGE
        OCR3C = motor[0]<<3; //  pin 3
      #else
        OCR3C = ((motor[0]<<4) - 16000) + 128;
      #endif
    #endif
    #if (NUMBER_MOTOR > 1)
        OCR3A = motor[1]<<3; //  pin 5
      #else
        OCR3A = ((motor[1]<<4) - 16000) + 128;
      #endif
    #endif
    #if (NUMBER_MOTOR > 2)
        OCR4A = motor[2]<<3; //  pin 6
      #else
        OCR4A = ((motor[2]<<4) - 16000) + 128;
      #endif
    #endif
    #if (NUMBER_MOTOR > 3)
        OCR3B = motor[3]<<3; //  pin 2
      #else
        OCR3B = ((motor[3]<<4) - 16000) + 128;
      #endif
    #endif
to
Code:
        OCR3A = motor[0]<<3; //  pin 3
      #else
        OCR3A = ((motor[0]<<4) - 16000) + 128;
      #endif
    #endif
        OCR4B = motor[1]<<3; //  pin 5
      #else
        OCR4B = ((motor[1]<<4) - 16000) + 128;
      #endif
    #endif
        OCR4C = motor[2]<<3; //  pin 6
      #else
        OCR4C = ((motor[2]<<4) - 16000) + 128;
      #endif
    #endif
        OCR3C = motor[3]<<3; //  pin 2
      #else
        OCR3C = ((motor[3]<<4) - 16000) + 128;
      #endif
    #endif
Now the motor 2 and 3 works in a good way ( there were inverted before that ). But I have always nothing on the 5 and 6.
Anybody had a idea ?
Thank you for your time.
WalkOver is offline Find More Posts by WalkOver
Old May 27, 2013, 06:07 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by WalkOver View Post
Hello everyone !
Code:
      #else
      #endif
    #endif
      #else
      #endif
    #endif
      #else
      #endif
    #endif
      #else
      #endif
    #endif
to
Code:
      #else
      #endif
    #endif
      #else
      #endif
    #endif
      #else
      #endif
    #endif
      #else
      #endif
    #endif
Better to aks this question at multiwii forum.
er9xuser is offline Find More Posts by er9xuser
