Old Mar 27, 2013, 12:22 AM
DR. Jekyll is offline
Find More Posts by DR. Jekyll
Joined May 2009
Originally Posted by Stunt Double View Post
DR. Jekyll, I had the same problem when I swapped from turnigy plush to rctimer simonk speedies. Noticeable drop in power, everything else was the same.
What you can do is increase #define MAXTHROTTLE to 2000. 1850 default value is low and you will get a boost if you up it to 2000. If thats not enough just go back to the old speedies. You can still get good results with non-flashed speedies you just have to fine tune the copter a bit more.
Thanks for the ideas. I already tried uping max throttle to 2000. No change. I have heard that the HK super simple can handle the refresh rate of the Quadrino,anyone else hear this?
DR. Jekyll is offline Find More Posts by DR. Jekyll
Old Mar 27, 2013, 06:17 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Leave some room for ESC's when full throttle. Set to 1950.
er9xuser is offline Find More Posts by er9xuser
Old Mar 28, 2013, 12:49 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
can anyone tell me if multiwii gps still requires an i2c adapter? or has code been worked out yet for serial interface?
dave1993 is offline Find More Posts by dave1993
Old Mar 28, 2013, 02:12 PM
tbee is offline
Find More Posts by tbee
tbee's Avatar
San Jose CA.
Joined Jun 2006
With the Crius aiop v2.0 on multiwii 2.2, do I have to change the baud rate for my rctimer ubox gps v2.0 by using ucenter software or it will automatically be able to talk to the crius board which is new on multuwii 2.2. ? I would like to confirm on that. Thanks
tbee is offline Find More Posts by tbee
Old Mar 28, 2013, 02:41 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
No need the code already takes that into account using the max throttle.
That is why is good to have it match the max of the radio.
IceWind is offline Find More Posts by IceWind
Old Mar 28, 2013, 03:27 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
it will be automatically
titeuf007 is offline Find More Posts by titeuf007
Old Mar 31, 2013, 08:58 PM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Well it's too quiet here again.
Let's make a survey.
Please post your average flight time, quad size, lipo and KV using only MultiWii
<10min
450mm
2800mah
1130kv w/ 10x45
Ceros007 is offline Find More Posts by Ceros007
Old Apr 01, 2013, 05:04 AM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Nice... but i think the AUW is the decisive factor for the flight time.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Apr 01, 2013, 06:40 AM
KeesvR is offline
Find More Posts by KeesvR
Nederland, Gelderland, Meteren
Joined Dec 2010
Originally Posted by RocketMouse View Post
Pleeease help!
I'm trying to run MultiWii_VibTest_18b on HK AIOP. But it seems doesn't recognize censors.
What should I do?
I have in config set:
#define QUADX
#define I2C_SPEED 400000L
#define MEGA
(tried all these for alternative values - nothing changed)
no board or sensor defined
There is a new dynamic vibration test version out now, a little bit different, but working.
http://www.multiwii.com/forum/viewtopic.php?f=7&t=3294
Thanks to PatrikE who made it.
KeesvR is offline Find More Posts by KeesvR
Old Apr 01, 2013, 09:17 AM
Thai is offline
Find More Posts by Thai
Shipped to work. Wife safe.
Thai's Avatar
Canada, eh?
Joined Jan 2007
Can someone explain what Pos, PosR and NavR is? I searched all 1000+ posts in this massive thread to no avail. And Google wasn't helpful at all. Or even MultiWii's site. It's almost as if it's common knowledge, but apparently not common for me.
Thanks.
Thai is offline Find More Posts by Thai
Old Apr 01, 2013, 10:03 AM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Thanks.
Here you go
cquian is offline Find More Posts by cquian
Old Apr 01, 2013, 10:07 AM
Thai is offline
Thai's Avatar
Canada, eh?
Joined Jan 2007
Originally Posted by cquian View Post
Here you go
Thanks. Ok, that document didn't really explain what they are. Perhaps it's outdated?
Pos, PosR and NavR.
Pos = Position Hold?
PosR = Position Hold Rate?
NavR = Navigation Rate? = RTH Rate as in document. I think I get it...
Old Apr 01, 2013, 02:31 PM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
You are right... i'M just looking to extend my flight time. That's one thing I hate about copters vs plane.
Old Apr 01, 2013, 06:47 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
I get 16 minutes on my modified X525. I removed the landing gear and use cable ties to hold the motors on. I use dt750's and 9x4.7 gemfans with a compact zippy 3700 3s 25c battery. if I add a gopro I get massive vibrations and much lower flight time. Its always a tradeoff but with the right combination and a light frame you should be able to maximise your flight time.
You can see my x525 near the start of this video (approx 1min 30sec) I took the other day at casey fields in Melbourne. It flies like a little rocket, powered by home made multiwii.
FLIGHT LOG 04 | casey fields cranbourne (7 min 25 sec)
jbalat is offline Find More Posts by jbalat
Old Apr 02, 2013, 02:07 PM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
I'M using the Keda 20-26M 1130Kv with 10x4.5 props on a 450mm at little less than 1kg (with FPV stuff, etc).
With Zippy 2200mah 40c and I'm killing them... They are getting puffy and do not hold a charge.
What's wrong? I thought that Zippy was a good brand. So I'm thinking of changing my motors...
