Old Jan 30, 2013, 01:20 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Cid156 View Post
+1:d
If i was you, i would just buy that one and cut the PCB arms.
There is no trace on those i think
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jan 31, 2013, 01:32 AM
SUMPRO is offline
Find More Posts by SUMPRO
Joined Aug 2012
Can everyone help me.
How to connect GPS with Atmega328P (Promini)?
I got bad S/N ratio when connect GY-86 & GPS with the same i2c port.
SUMPRO is offline Find More Posts by SUMPRO
Old Jan 31, 2013, 08:00 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
You're using the GPS I2C converter board and not plugging the GPS straight into the I2C port, right?
IceWind is offline Find More Posts by IceWind
Old Jan 31, 2013, 01:34 PM
SUMPRO is offline
Joined Aug 2012
I had setup all (GPS-> I2C converter board ->I2C->FTDI) & plugging the USB connector into the FTDI . Then open the GUI to collect Signal.
left: +GPS right: no GPS
Old Jan 31, 2013, 06:18 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
I2C>FTDI?
The FTDI should connect to the serial port.
Note that the UI is showing tons of I2C errors.
Old Jan 31, 2013, 06:28 PM
SUMPRO is offline
Joined Aug 2012
I2C>FTDI?
sorry
PROmini-->FTDI
my I2C always show error near the tons.
The MAG volue is abnormal (thousands)when adding GPS after 2 min.
Old Feb 01, 2013, 03:08 PM
gardleopard is offline
Find More Posts by gardleopard
Asker, Norway
Joined Jan 2010
Contiouos flipping
When I try to flip my quad it starts flipping until it hits the ground. It is a simple Quad X with arduino nano and genuine wm+ running MultiWii 2.1.
settings:
#define QUADX
#define I2C_SPEED 100000L
#define INTERNAL_I2C_PULLUPS
#define WMP
#define YAW_DIRECTION -1
I cant see any i2c errors in the gui when flipping the quad by hand. I suspect that the internal pullups is the reason. Will external pullups fix this, or is it something else I should do?
gardleopard is offline Find More Posts by gardleopard
Old Feb 01, 2013, 07:33 PM
RajanS is offline
Find More Posts by RajanS
Joined Feb 2013
Please help
So i am a beginner as in its my first time building a rc copter, and for a project I'm building a quad-copter. I have everything set up and my motors are running, but im not sure if my gyro is set up or not, and i cant tell if it needs to be reversed. Id doesnt seem to be speeding up when i tilt it and such. And i cant even take it off the ground, because once i give it enough thrust to get up, it will tilt over to one side and flip over. I am using a kk Multicopter black board v5.5. and one of my motors randomly shuts off, and then turns back on... soo please help
RajanS is offline Find More Posts by RajanS
Old Feb 02, 2013, 05:22 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
First make sure all your controls are going the right way. You can reverse the channels on your radio if not. There are instructions for the kk that tells you how to reverse the gyros by turning off one of the pots and selecting the channel to reverse. Dont worry about the motor stopping or starting, it will sort itself out in the air.
If anyone is interested in my friend Alf's aluminium H-Quad design the forward to about 6min 30sec for a quick look. Its an awesome design but he still needs some blade balancing.
FLIGHT LOG 01 | altona salt lakes (7 min 40 sec)
jbalat is offline Find More Posts by jbalat
Old Feb 03, 2013, 03:40 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Been a while since I posted here, but I thought this had to be a fitting occasion..
SebastianJ´s PsykoKoptr with Alexmos SimpleBGC brushless gimbal prototype from ViaCopter. Multiwii 2.1. Copter and Gimbal RTF AUW is 786 grams.
PsykoKoptR vs Alexmos GoPro3 Gimbal (0 min 56 sec)
Its not available yet, more info here:
http://www.rcgroups.com/forums/showthread.php?t=1815204
JussiH is offline Find More Posts by JussiH
Old Feb 05, 2013, 04:19 PM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Is there something in the multiwii firmware that can drive a SSG gimbal?
Is that what SERVO_TILT_MIX does?
Super Simple Gimbal SSG (5 min 25 sec)
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 05, 2013, 06:26 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
http://www.youtube.com/watch?v=KPBL4pPEzNI
Yes, exactly.
There used to be even a reference to a video of the SSG gimbal in the config.h but it's not there anymore.
Now it's in the code itself:
#ifdef SERVO_MIX_TILT
// Simple CameraGimbal By Bledy http://youtu.be/zKGr6iR54vM
if (rcOptions[BOXCAMSTAB]) {
Old Feb 05, 2013, 06:29 PM
Freakazoid's Avatar
Joined Dec 2004
Haha sweet, thanks for confirming.
Old Feb 06, 2013, 01:53 PM
kiama is offline
Find More Posts by kiama
Australia, NSW, Kiama
Joined Mar 2012
I am having some issues with RTH and PH with my Paris 4.6 board.
When I first installed the board they worked fine, but now as soon as I hit the RTH switch or PH the quad dips and twiches and starts to fly anywhere but home or PH.
I have recalibrated the RC controller, Acc, Gyro. All PIDs are standard that were loaded into the board. The board wad bought with the GPS as a unit so all settings were setup originally.
I am sure that I am missing something, hopefully simple.
Where do I start
Thanks in advance
Mic
kiama is offline Find More Posts by kiama
Old Feb 06, 2013, 02:03 PM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
why not go and contact your vendor and ask for support. If they run an honest business they should provide some useful info and not leave you out in the cold after the $$$ transfer. The least would be to provide you with info which version is installed and what values the params are set to. Ask for the version number and make them send you a copy of the config.h file.
hamburger is offline Find More Posts by hamburger
