Old Jan 19, 2013, 01:43 AM
amunday is offline
Find More Posts by amunday
United States, CA, Sunnyvale
Joined Nov 2012
Hello all,
Finished my first build - stock Scarab Carbon Armor, everything seemed to be ok during setup and configuration. However, running with props on with the Scarab in my hand it does not feel balanced. There is resistance to motion from three of the motors but when you try to rotate it against the final motor there is little/no resistance. The behavior is confirmed with the unit on the floor...at min throttle it wants to tip towards one motor. I'm thinking it may be an esc issue but I'm not really sure where to go from here. Any suggestions would be appreciated.
Andrew
amunday is offline Find More Posts by amunday
Old Jan 19, 2013, 05:25 AM
Lapino is offline
Find More Posts by Lapino
Lapino's Avatar
Deutschland, NDS, Braunschweig
Joined Mar 2011
Originally Posted by Shikra View Post
Testing the latest dev release out on my Paris/Sirius board in the woods! Then chucked a few other clips from other dev tests. Just the one bad incident with a tree!
Puts a grin on the face every time...!
http://www.youtube.com/watch?v=S6AEhfYHIVA
Nice low level flights
Lapino is offline Find More Posts by Lapino
Old Jan 19, 2013, 07:28 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Who would like a very small Arduino board with USB..
I am in...!
https://tindie.com/shops/femtoduino/...uino-with-usb/
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jan 19, 2013, 08:10 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I am in...!
Add a MPU-6050 or MPU-9150 and it will sell millions.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 19, 2013, 08:12 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes i am sure..
But it was not a Multiwii oriented board at the begining. Still quite easy to put a MPU board attached..
Old Jan 19, 2013, 08:28 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
And it will help to keep the memoriam up for Fabio who passed away not long ago.
I'll order some just to have them.
The Femtoduino preorder will be running 6 more days...
kinderkram is offline Find More Posts by kinderkram
Old Jan 19, 2013, 08:31 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Exacly
Didn't want to talk about it but yes. It's been a long time that i want that board from him but didn't have the time to ask him.
Old Jan 20, 2013, 11:30 AM
eladiomf is offline
Find More Posts by eladiomf
Spanish UAV
eladiomf's Avatar
Sevilla, Spain
Joined Mar 2005
Hello,
I'm flying a Tri with camera gimbal. Board it's a CRIUS SE with arduino pro mini 328. It's working great but servos move from my center position on power up (During the 4 seconds that takes to initializated the board).
Once board it's initializated, not problem an the servos goes to the 1450us center that I have programed.
Anyone knows the part of the code that I must change, so that in power up initial positions for servos is 1450 and not 1500 as default.
Another option for me would be to not send pulses to the servos on power up
Thanks in advance
#define SERVO_TILT
#define TILT_PITCH_MIN 1100 //servo travel min, don't set it below 1020
#define TILT_PITCH_MAX 1900 //servo travel max, max value=2000
#define TILT_PITCH_MIDDLE 1450 //servo neutral value
#define TILT_PITCH_PROP 22 //servo proportional (tied to angle) ; can be negative to invert movement
#define TILT_ROLL_MIN 1100
#define TILT_ROLL_MAX 1900
#define TILT_ROLL_MIDDLE 1450
#define TILT_ROLL_PROP -22
eladiomf is offline Find More Posts by eladiomf
Old Jan 21, 2013, 12:45 AM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Scarab Stealth Carbon Armour // Aggressive Flying. The Paris is super stable and in full control all the time... Using the 2.1 MultiWii code with stock PIDs and increased RC Rates to 0.50 will turn the Carbon Armour into a Quad-Monster! The Paris board handles all the abuse without issues.
Love the ability to go from stable to insane with a bump of the sticks. ;-)
Scarab Stealth Carbon Armour // Aggressive Quad Flying (2 min 39 sec)
crazyj is offline Find More Posts by crazyj
Old Jan 21, 2013, 02:52 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Originally Posted by Freakazoid View Post
I was wondering if I can have a function that would simply toggle my hobbyking strobe lights on or off.
The easy way would be hooking it up straight to the receiver, but im running it in PPMsum mode.
Ive looked around in the code, and I suspect my best bet is butchering the camera trigger function.
Would replacing
Code:
  #if defined(CAMTRIG)
    static uint8_t camCycle = 0;
    static uint8_t camState = 0;
    static uint32_t camTime = 0;
    if (camCycle==1) {
      if (camState == 0) {
        servo[2] = CAM_SERVO_HIGH;
        camState = 1;
        camTime = millis();
      } else if (camState == 1) {
       if ( (millis() - camTime) > CAM_TIME_HIGH ) {
         servo[2] = CAM_SERVO_LOW;
         camState = 2;
         camTime = millis();
      } else { //camState ==2
       if ( (millis() - camTime) > CAM_TIME_LOW ) {
         camState = 0;
         camCycle = 0;
    if (rcOptions[BOXCAMTRIG]) camCycle=1;
  #endif
in Output with this
Code:
    if (rcOptions[BOXCAMTRIG]) servo[2] = CAM_SERVO_HIGH;
	else servo[2] = CAM_SERVO_LOW;
  #endif
turn A2 into a servo driver that toggles between high and low if I activate/deactivate camtrig with an aux channel?
Anyone?
Freakazoid is offline Find More Posts by Freakazoid
Old Jan 21, 2013, 04:48 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Hey guys if anyone is interested in setting up a Bluetooth dongle on their MultiWii then look no further as I think I have figured it out.
Connecting to MultiWii Flight Controller with a Crius Bluetooth Adapter (9 min 35 sec)
jbalat is offline Find More Posts by jbalat
Old Jan 22, 2013, 05:06 AM
onlyifamppowered is offline
Find More Posts by onlyifamppowered
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
HI All
I have not been playing multiwii for a while now. My old tricopter is still flying on 1.7. I just brought my new FC from HK
http://www.hobbyking.com/hobbyking/s...DSM2_Port.html
And have downloaded the new 2.1 firmware. I tested the board when I got it and got it doing allthe right things on the new GUI but the board was quad + and I wanted quad x so I flashed it.
All good so far
The GUI is showing that the board is now quad x but I can not get any movment from the graphs like I did before.
I have tried several times and know it has to be something I have overlooked as it was working pre flash and seems to be flashed correct as it is now showing the correct mode...
Any thoughts
Rob
onlyifamppowered is offline Find More Posts by onlyifamppowered
Old Jan 22, 2013, 08:47 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Did you choose the correct defines for the sensors?
Sounds like a problem with the addresses of the sensors.
HobbyKing hardware = cheap
HobbyKing support = not existing
Only thing they do is link on multiwii.com and leave the customers allone...
Old Jan 22, 2013, 11:54 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
I am in...!
I don't really see the point. The Pro Mini is already very small and lightweight. Unless you want to build micro thing like a nanocopter, it's pointless.
Ceros007 is offline Find More Posts by Ceros007
Old Jan 22, 2013, 12:20 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It's not poinless, trying new things is the base of development.
Yes i do like to make very small copter.
Plus it's not expensive and could be nice for experimentations.
Oh... And usb port
