Switzerland
Joined Sep 2008
There is another board. It is look similar but not. All the components are in the middle plate then we can cut the arms http://www.goodluckbuy.com/mini-micr...ard-only-.html It is impressive to find a such product at goodluckybuy
Here is a video with FPV clips from my xRotor IFrame Quad (HQuad).
Flying MultiWii 2.1 with genuine wm+
Joined Jan 2012
I have a similar BT_module (v1.01) with 4 pins.
How can I change the baudrate on that ? It's still set to 9600 baud. Thanks Quote:
Hey guys... I've been poking in and out of this thread to get my multiwii copter up and running.... It flies awesome but I have been noticing something that I can't really find any info on. Not sure if I missed it running through all the info here or not. For starters i'm using the ZMR Multiwii SE board. Currently not using the baro or the mag on the board. My issue is that if i'm in acro mode flying around the copter will some times pitch back to stop the forward motion. I can just give it more forward stick to kinda "override" this when I feel it coming. Was just wondering if there is a setting or PID value I missed somewhere to stop this?
Joined Feb 2011
On the Tri I have kind of overcome this by moving my CG forwards.
But have a look at the multiwii web site under software and there is some information about a rate setting in the gui beside the roll pitch boxes. This is the rate at which P and D are cancelled during manouvers. 0.4 gives some cancellation while 0.7 is good for aerobatics. I have not tried it so let us know if it works ? |
France, IdF, Châtenay-Malabry
Joined Aug 2010
Hello,
A small best off fpv 2012 to start 2013. I wish you all the best for 2013.
Greg |
