Old Nov 19, 2012, 05:01 PM
shufflez is offline
Find More Posts by shufflez
The Netherlands, NH, Amsterdam
Joined Mar 2008
Originally Posted by jabu32 View Post
it is mounted underneath the board. x axis is pointed in the same direction as if it was mounted on top but the y (and z?) is backwards. i think i got it working correctly by comparing the stuff capt wrote above. i had to reverse y and z i believe. i had to reverse the x axis on the ACC also which seemed odd.
how do i check the boxes to make it stunt mode for pos 1 and ACC+MAG+BAR for pos 2?
Check my post here about my thoughts on sensor direction, as WhiteTurbo had a similar problem (although for him the software changed, not the hardware ).
Sometimes it's tricky to tick the boxes in the GUI, might be due to Java implementation/limitation on certain PC platforms (you might want to try MultiWiiWinGUI).
For me it works to click the top-right corner of the checkbox in the supplied GUI. Click Save after you're done and check in GUI if sensors become active (green) when flicking the switch on TX. Don't forget to calibrate ACC (keep copter as level as possible, wait till LED stops blinking) and MAG (click button and rotate copter 360 degrees on all 3 axes within 30 seconds)
shufflez is offline Find More Posts by shufflez
Old Nov 19, 2012, 06:55 PM
neobot is offline
Find More Posts by neobot
Joined Jun 2012
Originally Posted by jbalat View Post
Can anyone walk me through headfree. Im using the latest dev.
I have the gear switch turning on BARO, MAG, ACC and HEADFREE at the same time
I take off with the switch on and its pretty stable but when I push the stick forward the quad just moves forward and not away from me. All controls just work as normal like headfree is not enabled.
Are they any tricks or anything I need to enable before I flash ?
try without mag enabled
mag acts like you point north you stay pointing north till you move the sticks i,e if you turn the flying quad by hand it will return to the heading defined by stick input
headfree acts like a compass defined by the sticks so no matter which way quad is facing front back left and right are the same
looking at the above it would appear having both on at once is the same as having two dogs on one stick if settings are equal both ways they will cancel each other out? but if headfree were 60% and mag 40% you might get a very weak headfree mode?
neobot is offline Find More Posts by neobot
Reply With Quote  (Disabled)
Old Nov 19, 2012, 11:48 PM
jangkihoon is offline
Find More Posts by jangkihoon
Joined Feb 2012
Originally Posted by dopplet View Post
Very cool, what are you using to drive the brushed motors on the circuit board?
Andrew
I just used bad brushless ESC's N-channel FET.
It is marked f8880.
jangkihoon is offline Find More Posts by jangkihoon
Old Nov 20, 2012, 04:55 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
sorry for cross posing but you have to get one of these. It will save a lot of broken props on your full size quads until you get your skills up
Check out the v939 video here
jbalat is offline Find More Posts by jbalat
Old Nov 21, 2012, 09:40 PM
jbalat is offline
Joined Feb 2011
Thanks for that I kind of thought that would be the case.. Looks like its doing something now but with all that wind around I could only try it out a couple of seconds at a time. The documentation on this feature is really hard to find, I think it could easily save you if you lost your orientation when flying out far away.
Old Nov 22, 2012, 11:24 AM
spagoziak is offline
Find More Posts by spagoziak
"Let's put a camera on that.."
spagoziak's Avatar
Twin Cities, MN
Joined Feb 2010
MWC Survey Updated
Hi folks! It's been a long time since I've been to this thread--took a break to work on a Skywalker & Arduplane.
I just built a tiny quad and realized that the survey I built last year has grown out of date. Not any more!
If you haven't thrown in your best config yet, head over and add it. The purpose is to give others an idea of where to set their config so they can get their new toys off the ground successfully.
This is the survey:
https://docs.google.com/spreadsheet/...tKQlE6MQ#gid=0
This is the results in graphic form (some of the answers don't graph well):
https://docs.google.com/spreadsheet/...gridId=0#chart
This is the spreadsheet view of the results:
https://docs.google.com/spreadsheet/...thkey=CKDQ6O0L
If I missed something or got it wrong, please PM me and I'll fix it.
spag
spagoziak is offline Find More Posts by spagoziak
Old Nov 22, 2012, 12:16 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Hi All,
Just wonder which PID settings is for the Gimbal in the GUI..
sorry for the dumb question
Eric
Dialfonzo is offline Find More Posts by Dialfonzo
Old Nov 22, 2012, 12:24 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Hi Spag,
nice to meet you again!
Great initiative on the survey - will be very useful for beginners.
I'll post my values once I find some time...
kinderkram is offline Find More Posts by kinderkram
Old Nov 27, 2012, 01:15 AM
Fairway is offline
Find More Posts by Fairway
Fairway's Avatar
Joined Sep 2004
Great board....very small
Originally Posted by jangkihoon View Post
did you use this?? I just came across the video today.
How-To: Shrinkify Your Arduino Projects (3 min 42 sec)
If not how did you do it? Great job...
Phil
Fairway is offline Find More Posts by Fairway
Old Nov 27, 2012, 01:17 AM
Tw34k is offline
Find More Posts by Tw34k
I = V/R
Tw34k's Avatar
United States, FL, Jacksonville
Joined Aug 2012
Pretty sure multiwii will never work on a ATtiny 45/85.
Tw34k is offline Find More Posts by Tw34k
Old Nov 27, 2012, 03:28 AM
reinhpe is offline
Find More Posts by reinhpe
reinhpe's Avatar
Österreich, Niederösterr., Haschendorf
Joined Jan 2009
Originally Posted by Fairway View Post
did you use this??
With only two PWM outputs you would be very limited!
reinhpe is offline Find More Posts by reinhpe
Old Nov 27, 2012, 03:31 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
i think someone said earlier that you need to not have MAG selected when on headfree. try that.
sirbow2 is offline Find More Posts by sirbow2
Old Nov 27, 2012, 05:37 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Exacly
HeadFree is something that use the MAG
Old Nov 27, 2012, 05:46 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
My mag is off by 90 degrees. Should be pointing north and it shows that it is pointing east. Have recalibrated at least 10 times and always says the same thing. Using the Multiwii pro board.
Anyone know where to change that in the code? Been poking around but no dice yet
braindead4554 is offline Find More Posts by braindead4554
Old Nov 27, 2012, 05:48 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It's not very important where it point the north at.
What is important is that the position is repetitive and exact.
Like if you turn it 90deg it move 90deg in the GUI etc..
