Old Nov 17, 2012, 10:45 AM
jangkihoon is offline
Find More Posts by jangkihoon
Joined Feb 2012
Handmade multiwii board testing.
After my last post http://www.rcgroups.com/forums/showt...0#post23151702
I have done my handmade multiwii board testing to use brushed motors.
Watch & fun
Handmade multiwii board testing_byJang (0 min 59 sec)
jangkihoon is offline Find More Posts by jangkihoon
Old Nov 17, 2012, 01:58 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Originally Posted by jabu32 View Post
how do i test in the GUI if the BARO is working correctly?
is there a way to add a lcd to my board?
if i roll to the right should my acc roll increase?
http://www.multiwii.com/faq
How should be the sensor axis directions
TILT the MULTI to the RIGHT (left side up):
  • MAG_ROLL, ACC_ROLL and GYRO_ROLL goes up
  • MAG_Z and ACC_Z goes down
TILT the MULTI forward (tail up):
  • MAG_PITCH, ACC_PITCH and GYRO_PITCH goes up
Rotating the copter clockwise (YAW):
  • GYRO_YAW goes up
The copter stays level:
  • MAG_Z is positive ; ACC_Z is positive
capt is offline Find More Posts by capt
Old Nov 17, 2012, 02:08 PM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Could someone please explain multiwii OSDs to me? I understand that they output info like other osds, but what is the multiwii part? Do they connect to your main flight control board running multiwii to get their information? Or do they run some sort of multiwii?
Thanks, Zane
zanek is offline Find More Posts by zanek
Old Nov 17, 2012, 06:58 PM
shufflez is offline
Find More Posts by shufflez
The Netherlands, NH, Amsterdam
Joined Mar 2008
i mounted my HM5883l on the underside of the paris v4 board. now do i change the orientation variables via config.h or the sensors file??? also do i have to put a negative on all values x,y,z or just y,z since x is pointed in the correct direction but just flipped upside down.
how do i enable mag and baro with a dx6i? the acc (selfleveling is set for the gyro switch). i can enable them through the gui.
Is it actually mounted upside-down? Or just underneath? Even if pointed forward, left=right and vise versa when wrong way is up And pitch forward would be inverted on the same axis
Regarding the DX6, you can assign the 6th channel to enable mag&baro. On my DX7, my Gyro is ARM/DISARM, 3 positionswitch is ACC/ACC+MAG/ACC+MAG+BAR.
Hope this helps!
shufflez is offline Find More Posts by shufflez
Old Nov 17, 2012, 09:33 PM
shufflez is offline
Joined Mar 2008
Originally Posted by dutchcommando View Post
thanks for your reply.
with the pids all the way to max it actually flies.. it just has a wobble. which increases the more i keep on holding the stick. if i try to fly forward the woble increases the longer i keep the stick forward.
it is rock solid in acro mode.
in stable mode the pids come into play and.. well... nothing changes with moving the pids way up or down.. maybe i'll go back to a lower MWII version..
thanks for the link, i'll be reading that!
How does it fly with regular PID's? You should first tune your PID's on ACRO and only when that's perfect start tuning the LEVEL PID. Please be advised, LEVEL PID is linked to other PID's, so please tune ACRO first
Old Nov 18, 2012, 08:40 AM
bakon is offline
Find More Posts by bakon
I Toast Planes
bakon's Avatar
Joined Jul 2010
Finally Complete!
Took me a while but I finally finished it! Completely scratch built and designed by me.
bakon is offline Find More Posts by bakon
Old Nov 18, 2012, 03:07 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Very nice!! What motors are you using?
braindead4554 is offline Find More Posts by braindead4554
Old Nov 18, 2012, 04:28 PM
bakon is offline
I Toast Planes
bakon's Avatar
Joined Jul 2010
I'm using cheap hobbyking donkey's 960kv. Heavy (The whole copter is 8 lbs) but they get it hovering at half throttle.
Old Nov 18, 2012, 04:35 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
What's your average flight time?
Old Nov 18, 2012, 04:45 PM
Cid156 is offline
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
Hello,
I have two problems with my multiwii
1) When I land too hard or I crash, one motor starts to spin. I can not stop with my tx. I need to unplug the battery
2) I feel that the quad react too slow to my input. Is it the PID setting?
Cid156 is offline Find More Posts by Cid156
Old Nov 18, 2012, 10:46 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
in acro it's rock solid..
with stock pids it does the same as maxed out pids.. slightly less on slow wobble during flight, slightly more fast wobbles if the frame is touched by hand or wind.
board is mounted on gyro foam. (thin)
dutchcommando is offline Find More Posts by dutchcommando
Old Nov 19, 2012, 06:51 AM
jabu32 is offline
Find More Posts by jabu32
Who put that tree there?!?!
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
Hope this helps!
it is mounted underneath the board. x axis is pointed in the same direction as if it was mounted on top but the y (and z?) is backwards. i think i got it working correctly by comparing the stuff capt wrote above. i had to reverse y and z i believe. i had to reverse the x axis on the ACC also which seemed odd.
how do i check the boxes to make it stunt mode for pos 1 and ACC+MAG+BAR for pos 2?
jabu32 is offline Find More Posts by jabu32
Old Nov 19, 2012, 08:33 AM
Joined Feb 2012
Handmade micro multiwii board flying.
After my last postings..
http://www.rcgroups.com/forums/showp...ostcount=28891
I have made new micro quad frame. It is only 53 grams with battery. See my video clip.
Handmade multiwii board flying_byJang (1 min 30 sec)
Old Nov 19, 2012, 03:44 PM
dopplet is offline
Find More Posts by dopplet
Joined Apr 2012
http://youtu.be/uYJQrxBM5bM
Very cool, what are you using to drive the brushed motors on the circuit board?
Andrew
dopplet is offline Find More Posts by dopplet
Old Nov 19, 2012, 04:55 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Can anyone walk me through headfree. Im using the latest dev.
I have the gear switch turning on BARO, MAG, ACC and HEADFREE at the same time
I take off with the switch on and its pretty stable but when I push the stick forward the quad just moves forward and not away from me. All controls just work as normal like headfree is not enabled.
Are they any tricks or anything I need to enable before I flash ?
jbalat is offline Find More Posts by jbalat
