Joined Jul 2012
wonder if anyone can help me,
i've got a paris v4 board running 2.1 on my rcexplorer style tri, was flying great and logging some good fpv flying with it till the turnigy(digi) servo took a dump after a brush with the ground, replaced it with a hitec 85mg(analog) and i can't get it off the ground without it going into a flat spin of death, tried clearing eeprom and reloading sketch and playing with rates and pids and servo refresh rates but all has the same result, uncontrollable yaw spin, servo doesn't seem to center that well in the GUI, i'm lost with it and don't really want to buy another servo, the tri flys perfectly with the hitec if i switch out the paris for the KK2 board from my quad, the paris flys my quad perfectly as well if i switch it over also so the board seems fine in that regard. servo is fed from it's own bec. any ideas appreciated |
Joined Jul 2012
Done that shikra, either way results in zero yaw control, very frustrating,
The only reason I'm trying to keep the Paris on tree is I have the GPS pod which is nice for fpv range problems, I've got a cc3d looking for a home though so might retire the wii to another toy instead. |
ok... i'm lost...
trying to tune my quad, but it keeps on having a slight wobble.. like it hangs on a rope or something.. eve with the PIDs for pitch and roll all the way to MAX (P20,0 I 0,250 D100) all i get is a slow wobble when trying to move. nothing aggressive.. just very slow.. i am using the HK multiwii 328P board quad is 52CM motor to motor hobbywing 20A Skywalker esc (not flashed) emax 1000KV 9X4.7 props quad flew great with FreeFlight. anyone any ideas? |
The Netherlands, NH, Amsterdam
Joined Mar 2008
I believe I've seen it a while back when getting my gimbal to work, but not sure if this relates to tri (yaw) servo's. So servo refresh lowest Hz, redefine endpoints, just having a wild guess here. |
Joined Mar 2008
What happens on the default PID's? I believe the D value has been inverted in earlier versions of the software. Maybe try decreasing D helps in your case. On one of my quads lowering D has immediate effect... Are you testing with or without Stable/Level/Horizon mode? Shikra has written up an excellent PID tuning guide by the way! With those PID's does it fly at all, or only wobble on stick input? BTW; Can you check vibrations to the sensors in GUI? Maybe you can try some lowpass filters, but I suggest you first get your quad as vibration-free physically as possible before adding software filtering. |
with the pids all the way to max it actually flies.. it just has a wobble. which increases the more i keep on holding the stick. if i try to fly forward the woble increases the longer i keep the stick forward. it is rock solid in acro mode. in stable mode the pids come into play and.. well... nothing changes with moving the pids way up or down.. maybe i'll go back to a lower MWII version.. ![]() thanks for the link, i'll be reading that!
Joined Jul 2012
Got a few hours to play today so will have a look at those ideas.
Indianapolis, IN
Joined Jan 2011
i mounted my HM5883l on the underside of the paris v4 board. now do i change the orientation variables via config.h or the sensors file??? also do i have to put a negative on all values x,y,z or just y,z since x is pointed in the correct direction but just flipped upside down.
how do i enable mag and baro with a dx6i? the acc (selfleveling is set for the gyro switch). i can enable them through the gui. |
Cumbria in the U.K
How is the board mounted. I have soft mounted and hard mounted boards. My best results are with boards that are solidly mounted. I have had drifting with soft mounting of the boards. |
