Old Nov 04, 2012, 06:38 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
I wait for the code to compile and then quickly plug it in to upload. I dont have reset on my adapter
jbalat is offline Find More Posts by jbalat
Old Nov 04, 2012, 08:39 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Originally Posted by Dialfonzo View Post
Anyone have try to upload MultiWii on that ?
Flymaple-A flight controller with 10 DOF IMU
just use Naze32
bob4432 is offline Find More Posts by bob4432
Old Nov 04, 2012, 08:42 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Why...
I had one already.
Just showing a board to the community.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Nov 04, 2012, 08:44 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Options.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 04, 2012, 08:45 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
Why...
I had one already.
but it doesn't do anything the Naze32 doesn't and hasn't already done for quite some time? plus they use the bmp085 sensor which everybody here cries about...
Old Nov 04, 2012, 08:47 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Sorry, I will not share to all people on the forum what I found.
BTW: i don't think Naze32 add anything but complexity to MWC.
Old Nov 04, 2012, 08:49 PM
Joined Aug 2009
+1 and attitude.
Old Nov 04, 2012, 08:50 PM
bakon is offline
Find More Posts by bakon
I Toast Planes
bakon's Avatar
Joined Jul 2010
For some reason my hexacopter motors do not spin up at the same time. They start with the back two then move to the side two and then finally the front two. I tried to fly this but the right rear motor seemed to compensate the opposite way then it was supposed to. Any ideas on how to correct this? I made sure to calibrate the ESC's
bakon is offline Find More Posts by bakon
Old Nov 04, 2012, 08:51 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by rimshotcopter View Post
+1 and attitude.
Old Nov 04, 2012, 08:52 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
you only think the Naze32 is more complex because your learned arduino first, had it been the other way, you would think arduino is more complex. hell, Naze32 dynamically configures itself to what sensors you have, etc. how is it harder? hell, it even has a user manual that if you follow, everything is just as easy and some will feel easier than an arduino setup.
Old Nov 04, 2012, 08:53 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
+1 and attitude.
attitude?
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Humm...
You mean when throttle up they start one after the other?
Do you have a Y harness to connect all esc at once on the receiver throttle channel?
Old Nov 04, 2012, 08:58 PM
bakon is offline
I Toast Planes
bakon's Avatar
Joined Jul 2010
Humm...
The start up in that order as I keep throttling up high and higher. I am using the Hobbyking Multiwii SE 2.0 board basically a Crius board so the ESC's are connected to the board directly. Here is the link: http://www.hobbyking.com/hobbyking/s...er_w_FTDI.html
Old Nov 04, 2012, 08:59 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
For Arduino based you need
- Arduino IDE
- ZIP Multiwii file
For Naze32 you need many things to use it.
I ma not saying it's not good or not worth it.
Just don't feel it add much to the "flight".
That's only my humble opinion.
Old Nov 04, 2012, 09:01 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It really look like the esc calibration is wrong.
If you could connect all 6 esc to a Y harness to your receiver you would know if it is the case.
