Espritmodel.com Heli Air
Old Oct 30, 2012, 02:49 PM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by bakon View Post
I just flashed my hexacopter today but I am not getting any gyro readings in the configure window. Any suggestions?
Sensors are not set correcly for your board.
Can you tell which one you use ?
You have many i2c errors
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 30, 2012, 02:51 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
I am using the MultiWii SE V2.0 Flight Controller from hobbyking. The link if you want it: http://www.hobbyking.com/hobbyking/s...er_w_FTDI.html
bakon is offline Find More Posts by bakon
Old Oct 30, 2012, 02:55 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
And what did you setup in the config.h tab in MultiWii prior to upload ?
Old Oct 30, 2012, 02:59 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Changed to #define HEX6X and #define A0_A1_PIN_HEX and that was it. Did I miss something?
Old Oct 30, 2012, 03:11 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
You need to specify which board your using.
Download the file that is already setup on HK download page HERE
then use that and config as HEX and other things you need
--- EDIT ---
It is already setup for the board in that file
Old Oct 30, 2012, 03:57 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
--- EDIT ---
For some reason when I used the 2.1 program it would not function. I now am using the 2.0 program with the 2.1 parameters copy and pasted into the proper sections in the 2.0 program and I would say its successful for now. The picture is while the Hexacopter is on a flat surface. I don't know if the grey values are supposed to be that spiky.
Old Oct 30, 2012, 04:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
You always need to use the gui version that match multiwii version
Old Oct 30, 2012, 04:13 PM
Emress
sirbow2's Avatar
United States, IA, Elkhart
Joined Nov 2011
all of the sensors are red and not green (see middle of the screen and right a bit). im guessing you need to define them in to arduino sketch
sirbow2 is offline Find More Posts by sirbow2
Old Oct 30, 2012, 05:05 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Does that look better?
Old Oct 30, 2012, 05:07 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
I think that could have been the problem. I could not find the file that had the Configurer for the 2.1 version the file just came with the arduino program
Old Oct 31, 2012, 05:15 PM
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Dialfonzo, it's not just a 32bit CPU, it's a different architecture, ARM.
Ceros007 is offline Find More Posts by Ceros007
Old Oct 31, 2012, 05:44 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes i know that.
But i am not a programmer so.. That's why i posted here..
Old Oct 31, 2012, 08:55 PM
Joined Feb 2012
Hi guys just watch & fun
Handmade_multiwii_byJang (0 min 13 sec)
jangkihoon is offline Find More Posts by jangkihoon
Old Oct 31, 2012, 09:10 PM
Emress
sirbow2's Avatar
Joined Nov 2011
im must say, good job on the soldering!!! looks like it works very well!
Old Oct 31, 2012, 09:34 PM
Spring Hill, FL
Joined Apr 2009
Hexoween copter
Just wanted to share a picture of my hexcopter shot during tonights halloween festivities in our neighborhood. Fenced off the front yard so kids wouldn't run underneath the copter when I was flying. Trick or treaters all enjoyed the scary flying skull.
EnigmaSoar is offline Find More Posts by EnigmaSoar
