Old Oct 12, 2012, 03:27 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Yea, just reverse the Pitch on the transmitter would be the simplest.
However, you can also adjust the mixing table in the MWC firmware.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Oct 12, 2012, 03:29 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by rimshotcopter View Post
Yea, just reverse the Pitch on the transmitter.
Humm...
Yes i guess that would work
Does anybody ever try it.. ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 12, 2012, 03:30 PM
Joined Aug 2009
I have seen a few Youtube videos, not sure if they were the MWC.
Old Oct 12, 2012, 04:04 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
Originally Posted by Dialfonzo View Post
Hi All...!
It's been a while since i posted here but i look often.
I have a little question...
Is there a way to make a Y6 setup but in reverse.. i mean the two motor facing front and one back (in fact 4 front and 2 back... Y6.. lol)
Thanks a lot
Eric Nantel
info@dialfonzo-copter.com
hi,
yes there is ... have a look in the software, in the output section you will see all the models and the specific outputs. if you look at the y6 motor output you MIGHT see something that looks like + , + , + or - , - , -
these stand for the different ways your copter can move , you have to find which one is for nick , roll and yaw
now you have to reverse nick and roll : + -> - and - -> + but do nothing to the yaw symbol , the craft should now work exactly the other way around
M4d_D is offline Find More Posts by M4d_D
Old Oct 12, 2012, 04:12 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by hamburger View Post
is that a stock v2.1 or the latest dev from _shared? There was a lot of rework done on baro code recently and amost everyone seems to agree it was a huge improvement. If you are adventurous, give it a try.
I've used the dev 1143.
Flashed the latest from trunk today and now the GPS doesn't work. Have tried several serial ports to no avail.
Alt hold with 1184 works much better. Due to bad weather I had to hover it in the room. Worked pretty well. It usally descends first until it starts to rise again.
A few ticks up on the throttle trim then helps to slow down the descend.
kinderkram is offline Find More Posts by kinderkram
Old Oct 12, 2012, 04:52 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Selecting a GPS is required in the lastest DEV. It is located under GPS baud area, got me to.
#define NMEA
//#define UBLOX
capt is offline Find More Posts by capt
Old Oct 12, 2012, 08:05 PM
pyrojets is offline
Find More Posts by pyrojets
Joined Apr 2011
Originally Posted by pyrojets View Post
I have some questions about PID tuning and auti-leveling.
My quadcopter is able to hover without any wobble but when it descends a little bit too fast it will start wobbling, do I trim aileron or rudder or both PIDs?
When I activate auto-level, I had to increase throttle to maintain the same altitude and the quad seems twitchier than it was in acro mode. Do I reduce auto-level PID?
Thank you.
Can anyone help me please?
pyrojets is offline Find More Posts by pyrojets
Old Oct 12, 2012, 08:35 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
it wobbles mainly because it doesnt like going through its own air flow. but PID can cause issues too. smaller props (with higher kv motors ofc), flashing your ESCs with simonk/blheli, and adjusting PIDs will help will help
sirbow2 is offline Find More Posts by sirbow2
Old Oct 12, 2012, 09:50 PM
pyrojets is offline
Joined Apr 2011
Thank you for the reply. Will read up on PID tuning again. For auto-level, is it normal to increase throttle to maintain the same altitude as compared to when it was in acro mode? I also noticed that it was a handful to control it in auto-level mode.
Old Oct 12, 2012, 10:25 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
No that does not sound normal, are you using altitude hold?
Old Oct 12, 2012, 11:38 PM
pyrojets is offline
Joined Apr 2011
Nope. Only auto level. Then was done indoors about 3 feet of the ground. Will try it outdoors at a higher altitude to reduce ground effect.
Edit: Gonna get new ESCs and flash it with simonk firmware. My current ESCs are silabs and the flash tool for BLheli is too expensive. Will also change my motors to EK-0002B for more efficiency. Hopefully can get my quad up and running by next week.
Old Oct 13, 2012, 03:27 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
#define NMEA
//#define UBLOX
Ok, must have missed the info. It works now.
Will do more testing today...
btw: does anyone get good results with a sonar?
Can't even figure out how to activate it in the code and where to connect...
Old Oct 13, 2012, 08:24 AM
cencen is offline
Find More Posts by cencen
Joined Aug 2007
TEST - Multiwii Position & Altitude Hold with Optical Flow and Sonar Sensors
Multiwii Position & Altitude Hold with Optical Flow and Sonar Sensors (4 min 40 sec)
This position hold test was made by Alexmos's Multiwii v2.0 based R23 code which supports sonar and optical flow sensors. This succesful implementation only works with arduino pro mini or similar configurations.
For more information please read this post : http://www.multiwii.com/forum/viewto...1413&start=190
Regards,
Feridun
cencen is offline Find More Posts by cencen
Old Oct 13, 2012, 08:49 AM
Joined Aug 2009
Great job Feridun!!
Old Oct 13, 2012, 11:16 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Another PH test, this time with the latest dev. firmware, some PID tuning.
Was very windy with hefty gusts - but did the job pretty good.
MWC2.1.1 (1 min 38 sec)
