Alex, you are way fast.....guess you just gave me a another reason to pick up the pace and my soldering iron
Thanks for sharing! Jussi |
Latest blog entry: AutoQuad hexacopter with Alexmos...
I have exactly the same problem with left motor I put 0,1 instaead of 1 in acc value seem to work better , try to test it in flight in a few minute, give feed back this afternoon what are you acc value I'have got the original WMP and nunchunk sensor white nintendo one It was working good on aeroquad. lets see in flight |
The first versions were small enough to run on a 168. (around 12 or 13k) The code size of the current version is now too big (around 19k). If your programming skill is good enough, there is however a way to suppress LCD/GUI/EEPROM code (not useful to fly) and fix values so that the code size could fit on a 168. |
I can fly with a acc strength correction of 1.0 without problem. At 0.1, there is nearly no acc influence. |
After flight report not so good than gyro only version for now few questions : I need to decrase the P gain at 1.5 (original was 4.5 for having a non oscillating tricpoter, but after correction are to long I'm working @ 100kz , is acc + wmp are not enough refreched in 100K ? can't work @ 400kz, Alex could you do a test with you original setting with changing only 400k to 100k mode to see if oscillation apear ? when engaging acc mode, with 0.1 gain, 1 gain cause motor left going to slow then I put the tri @ 45 degrée and put the pitch stick @ 0, I can see the tri do from 45 deg to Zero deg in 2 or 3 second, but after It continu to do a loop... slowly hopefully so is the calibration of the accelerometre is good done @ startup ? why left motor go done with 1 gain when stable mode is engage I think that acc calibration procedure don't working fine for now(supposition). my imu is working fine with aeroquad, and there is no vibration on it any Idea Alex ? thxs ps have you a link to buy good copy of the wmp and nunchunk who work @ 400 khz ? I heard that is we put 3.3 k ohm resisto on original wmp it work @ 400 khz, some one as test it ?. thxs |
