Old Aug 17, 2012, 01:21 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Yes, that is why I was thinking if it's even possible to fix. When I spotted this behavior I suddenly realized the problem with auto leveling that MultiWii and Naza have when flying fast. They both do not level out fast, instead they keep flying and level out very slowly. I think that is the same problem...
I wonder if there is a gimbal controller that does not feature this effect. Naza gimbal sucks, MultiWii works well, especially 2.1 version when servo refresh rate can be set higher. But it looks like it can only be used for really easy flying... oh well.
alek3d is offline Find More Posts by alek3d
Old Aug 17, 2012, 03:17 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Could use a second multiwii with different PIDS etc for the gimbal. Tune to how you like.
Or fly slower
Shikra is offline Find More Posts by Shikra
Old Aug 17, 2012, 03:52 AM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
anyone with a blackvortex board managed to get the integrated GPS to work?
Any idea about that?
GliderLover is offline Find More Posts by GliderLover
Old Aug 17, 2012, 05:23 AM
alek3d is offline
Slovakia
Joined Nov 2010
Or fly slower
I actually use Naza as FC and MWC as Gimbal controller because Naza flies well but gimbal control sucks.
For the MWC Gimbal there are no PID settings, just P setting for roll and pitch. Too little -> it lags, too much -> too sensitive.
I think I just have to fly slow.
Old Aug 17, 2012, 08:01 AM
Nurbs is offline
Find More Posts by Nurbs
Nurbs's Avatar
Stockholm, Sweden
Joined Aug 2003
Originally Posted by rimshotcopter View Post
Do you have a bypass filter on the 1.2GHz Transmitter?
Originally Posted by capt View Post
Probably interference from the FPV TX as it never happened before, the gear is so close on a copter it is a constant battle. Also possible the rx lost power momentarily and tripped the MW failsafe.
I do not have any filters yet and I only use one LiPo for everything so I know I can make some improvements there.
But I just don't understand why it didn't recover from the fail safe when I basically stood next to the copter and didn't get any more response.
It seemed like the program has crashed and needed a reboot.
Can the FPV TX cause that? Maybe through interference through the common wires?
Nurbs is offline Find More Posts by Nurbs
Old Aug 17, 2012, 08:08 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Well, I personally have never experienced the problem because I have not flown outside of LOS however, I have read numerous horror stories in the Video Piloting Forum Seems 1.2Ghz and 2.4Ghz don't mix very well and a bypass filter is required. This maybe why you are unable to reproduce the problem during ground testing.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Aug 17, 2012, 12:16 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
1.2 Ghz equipment is going to have a second harmonic at 2.4 Ghz. Perfect !
In close proximity the two systems will have problems.
sparklet is offline Find More Posts by sparklet
Old Aug 17, 2012, 01:25 PM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
How to test MultiWii failsafe in action? I don't want to crash my lovely quad. Fly close to the ground with rope attached, LOL?
man1024 is offline Find More Posts by man1024
Old Aug 17, 2012, 02:15 PM
Joined Aug 2009
What I do is remove the props, arm the copter, spin the motors at about 1/3 or less throttle, then shut the power off on the transmitter. As for auto-landing etc, that is not working to the degree that it should so I don't worry about that. My only concerns are fly-aways.
Old Aug 18, 2012, 02:05 AM
nicodh is online now
Find More Posts by nicodh
Joined Jan 2011
I'm having the same behaviour as you, with my ecilop and naze32. After some time the gimbal goes left and back after some fast flight.
I will try to use the APM gimbal feature to see if there is diference.
nicodh is online now Find More Posts by nicodh
Old Aug 18, 2012, 05:08 AM
markusb2 is offline
Find More Posts by markusb2
Kalmar, Sweden
Joined Apr 2009
Need assistance from you multiwii gurus!
Please have a look in this thread about my 10DOF problem..
http://www.rcgroups.com/forums/showthread.php?t=1714221
markusb2 is offline Find More Posts by markusb2
Old Aug 20, 2012, 07:04 AM
cronalex is offline
Find More Posts by cronalex
Joined Mar 2012
how to use the artificial horizon remzibi osd in multiwii 2.1
cronalex is offline Find More Posts by cronalex
Old Aug 21, 2012, 05:28 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
just default settings...
no post except cuts...
mwc quad // floating (5 min 4 sec)
warthox is offline Find More Posts by warthox
Old Aug 21, 2012, 06:02 PM
mxspode is online now
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
It was just a dead calm day out there wasn't it. Very nice as usual Markus. Nice to see another side to your flying. I always enjoy watching your clips.
Rob...
mxspode is online now Find More Posts by mxspode
Old Aug 21, 2012, 09:18 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Another Awesome video. Good work !!
jbalat is offline Find More Posts by jbalat
