Old Jul 19, 2012, 02:27 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by jy0933 View Post
yeah.. i've thought about getting a imu... but at that price i'd rather getting a aio pro.. about the same price... but better board at some point... one thing i like about paris board i have is the gel thing between fc and sensor boards.. that does pretty good job on damping.... AIO and other integrated boards... I got no idea how to do the same thing to eliminate vib
thanks
You can mount the fc over foam tape too..
And if you get an IMU you will still have the Foam tape under too...
I didn't try it myself but you can get that IMU
- The use of chip MPU6050 + HMC5883L + MS5611
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jul 19, 2012, 02:33 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
foam tape the fc on the frame? i notice the button of the board is no that even.. esp with pins soldered on... will that cause problem? and not so easy to remove i guess
how about using the screws with M.D smaller than M3 and the foam tape as "washer"? will that be a good idea?
jy0933 is offline Find More Posts by jy0933
Old Jul 19, 2012, 02:39 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Installed MultiWii 2.1 on a simple H shaped quad, has a Crius SE flight controller on it... Surely the best so far! Baro and Acc working very nicely.
Flying with the Gopro MWii 2.1 external veiw (4 min 28 sec)
Art Newland is offline Find More Posts by Art Newland
Old Jul 19, 2012, 02:42 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes it could work..
I don't use any damping myself.. i fly my own controller which have soldered integrated sensors with Aluminum standoff and stainless screws...
Old Jul 19, 2012, 02:54 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
When is Z axis stability likely to be solved?
I thought it happened earlier this year but it's clearly not working as well as some of the other FCs out there.
Psionic001 is offline Find More Posts by Psionic001
Old Jul 19, 2012, 03:50 PM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
Originally Posted by EnigmaSoar View Post
My present fleet of TCopters.
Absolutely brilliant work. I love the way how all the wiring is hidden from view, and the frame design is just beautifully minimalist.
Sucks we don't have these type junction boxes in Europe so I guess I need to mail order a few from overseas.
Thanks for the inspiration! - Mark
4x4rc is offline Find More Posts by 4x4rc
Old Jul 19, 2012, 06:57 PM
cbwill1945 is offline
Find More Posts by cbwill1945
United States, FL, Okaloosa
Joined Jan 2012
Just thought I would put a note in to say thanks to Phalanx-0 for going above and beyond to help me with my Kcopter multiwii board.After he tried to explain to me how to load to it and me not knowing what he was telling me. He finally told me to send it to him and he would try to load it. He did so and sent it back to me with pictures of what he did. I have set the PID's and will put it in my quad in a couple days As of now it seems to be working perfectly
cbwill1945 is offline Find More Posts by cbwill1945
Old Jul 19, 2012, 11:47 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
http://www.youtube.com/watch?v=HIxPpHCB2WQ
Awesome.. I love the new H design.. Can you post some close up pics please.. I need to build one ASAP but it needs to fold away too ???
jbalat is offline Find More Posts by jbalat
Old Jul 21, 2012, 02:16 PM
CD-ROM Junkie
Joined Apr 2001
My whole idea behind it was to keep it very simple, this one is 350mm square, 1000 kv motors, 10x4.5 props, and HobbyKing F-30A ESCs with Simonk's firmware (w/bootloader). Frame is 1/2 poplar arms and spine, 1/4 inch bottom plate and 1/8 inch top plate. If I were doing it again, I'd extend the bottom plate out the back, just like the front to give a little more flexibility for battery mounting/CG while the GoPro is mounted on the front (to keep it out of view of the props). Doesn't fold, but three bolts hold the arms on?
Old Jul 21, 2012, 02:23 PM
CD-ROM Junkie
Joined Apr 2001
So... since GPS seems to be becoming a reality for MultiWii, what is the favored GPS hardware? I2C seems to make the most sense... maybe?
Old Jul 21, 2012, 02:34 PM
Widelec is online now
Find More Posts by Widelec
Simple is the best
Joined May 2011
My new Landing Gear Set with SmallQuad 450
http://www.rcgroups.com/forums/showp...&postcount=148
Description: Name: 04_Medium.jpg
Description: Name: 06_Medium.jpg
Description:
95mm height, 240mm wide,
3k carbon tube, 2mm thickness, 165mm long, 58gr total
Widelec is online now Find More Posts by Widelec
Old Jul 21, 2012, 04:27 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I hope I'm in the right area for this question. I just installed multiwii v2.1 in my quad. When I go into the Config GUI the slider bars for pitch, roll, and yaw are missing. It only shows the motor sliders (four of them for the quad). Is this a problem with the GUI or something I need to enable in the sketch to make work? Thanks for any guidance...
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 21, 2012, 04:46 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
Take a screenshot, not really sure what you mean.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jul 21, 2012, 05:19 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Here's a link with a comparison screen shot of 2.1 and 2.0. You'll see the 2.1 is missing the slider info on the upper right of the screen. I came across this after I posted my original question here. No answer for it yet, but I guess I'm not the only one who has this.
http://www.rcgroups.com/forums/showp...postcount=4239
Old Jul 21, 2012, 05:24 PM
Quad lover.
Joined Dec 2011
OK, if I was you post on the multiwii forums as you are more likely to get a decent response.
In the mean time, I would suggest you use this
https://code.google.com/p/mw-wingui/
