Old Mar 24, 2012, 09:01 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Originally Posted by Art Newland View Post
You can overcome that by putting ARM on one of the AUX channels and arming with a switch.
Just arm with roll.
capt is offline Find More Posts by capt
Old Mar 24, 2012, 09:06 PM
EnigmaSoar is offline
Find More Posts by EnigmaSoar
United States, FL, Spring Hill
Joined Apr 2009
Originally Posted by daytimer View Post
I finally had what I would consider a successful flight!
However, I have a slow left (ccw viewed from top) yaw. I have to constantly give it right "rudder". I tried using the trim on the tx, but I have to trim it so far right that I am no longer able to arm/disarm the motors.
Other than that, it's kind of like learning to fly heli's all over again Very different feel to it. But, I will likely build more in the future
Is it a tri or a quad or what? If it's a tri are the two front motors counter rotating (1 ccw and 1 cw)? If it's a quad are the motors mounted perfectly vertical? If it's a tri you can do a mechanical trim with your yaw table linkage. Also make sure you don't have any rudder subtrim in there that you are having to counter.
EnigmaSoar is offline Find More Posts by EnigmaSoar
Old Mar 25, 2012, 06:10 AM
daytimer is offline
Find More Posts by daytimer
United States, IL, Joliet
Joined Sep 2010
It's a quad. I will double check the mounting of the motors. It is scratch built using 450 tail booms, tail block and tail (with shaft removed) as the arms. So, I suppose there could be a slight twist to their mounting, maybe even something I can't see...
daytimer is offline Find More Posts by daytimer
Old Mar 25, 2012, 07:32 AM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
hey im trying to flash my pro mini with the latest ver. of multiwii but cannot find the actual file to open in arduino software. I have downloaded the newest version of multiwii config from google docs (v2.4) but cannot find the actual code for it. cann someone link it or tell me where it is in the multiwii folder. thanks
kicekilla is offline Find More Posts by kicekilla
Old Mar 25, 2012, 07:41 AM
gtx is offline
gtx
Find More Posts by gtx
gtx
Nike - Just Regret it!
Sweden
Joined Apr 2006
Originally Posted by capt View Post
3v is correct and pick up slc/ sda/ gnd.
Mine is mounted sensor on top wires aft. I had to use alternative sensor orientation in code and put a - in front of z. See a pic @ multiwii forum.
if itīs low voltage, 3,3V, Should it not have scl sda from the LLC ? or is it straight from the arduino ? cant find any pic :P
gtx is offline Find More Posts by gtx
Old Mar 25, 2012, 07:57 AM
gtx is offline
gtx
gtx
Sweden
Joined Apr 2006
http://code.google.com/p/multiwii/downloads/list
link from first post..
Old Mar 25, 2012, 08:21 AM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
Anyone had this issue where when it is in level mode it does not respond that much to inputs?
It flies find in acro mode, just really odd when I put in level mode. Does this sound like P is too high?
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Mar 25, 2012, 09:04 AM
Jessestr is offline
Find More Posts by Jessestr
BelgiŽ, Vlaams Gewest, Evergem
Joined Nov 2011
Crashed my quad from 2ft .. on motor.. Weird things happen now..
- Connections are good as far as I checked..
- ESC's are doing fine
- Tried other battery..
Mt2208 after crash from 50cm (0 min 51 sec)
Jessestr is offline Find More Posts by Jessestr
Old Mar 25, 2012, 09:07 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
http://www.youtube.com/watch?v=x2H5FHwWuc4
Appears to me as a bad ESC or a broken wire..
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 25, 2012, 09:14 AM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
[QUOTECrashed my quad from 2ft .. on motor.. Weird things happen now..][/QUOTE]
The magnets are rubbing, don't run it anymore until you fix it. If it's just loose you can superglue it back in place but you have probably bent the shaft.
Old Mar 25, 2012, 09:15 AM
Jessestr is offline
Joined Nov 2011
I'll resolder my motor to another esc tomorrow. Let's hope it's noy my esc.. warthox has a thread about it that these HW10A ESC's aren't good anymore for multicopters the newer version.. (if I have to buy a new one..)
Jessestr is offline
Joined Nov 2011
The magnets are rubbing, don't run it anymore until you fix it. If it's just loose you can superglue it back in place but you have probably bent the shaft.[/QUOTE]
How could I fix it?
Old Mar 25, 2012, 09:21 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
it's a good day to make flips ...
Multiwii Quadcopter VTAIL (2 min 28 sec)
Bledi is offline Find More Posts by Bledi
Old Mar 25, 2012, 09:39 AM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
How could I fix it?[/QUOTE]
If the shaft is bent it will need replacing, pull it out and roll it on a flat surface to check. The original motor spec will state what size the shaft is, usually 3.0mm or 3.17mm on thes motors.
Old Mar 25, 2012, 10:01 AM
Joined Aug 2009
How could I fix it?
If the shaft is bent it will need replacing, pull it out and roll it on a flat surface to check. The original motor spec will state what size the shaft is, usually 3.0mm or 3.17mm on thes motors.[/QUOTE]
This is why I like RCTimer Motors, the shaft do not bend, they Break LOL. They are super hard and I have a very difficult time trying to cut the shaft down to use the prop adapters that mounts to the motor bell..
