Old Mar 24, 2012, 09:02 AM
Jessestr is offline
Find More Posts by Jessestr
België, Vlaams Gewest, Evergem
Joined Nov 2011
Originally Posted by chaosdestro0 View Post
So what proportional value for level do you guys have? I have just put it up to 14 as even 10 was not stable :O. 14 might make it wobble but it's better than very slow wobbles.
Standard PID works fine for me for auto leveling.. Only when I do some fast movements it wobble's a bit.. Might change my PID settings as well.
Jessestr is offline Find More Posts by Jessestr
Old Mar 24, 2012, 09:06 AM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
It's surprising how that I had them at 10 and I did not even have any fast wobble.
I am going to set the orientation is right I guess.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Mar 24, 2012, 09:32 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
We should ask an admin to create a sub-forum only for MultiWii so we could have different threads like safety, how-to, problem, "look at me, i'm flyin' ", etc...
But that will not happen
Ceros007 is offline Find More Posts by Ceros007
Old Mar 24, 2012, 10:04 AM
GrootWitBaas is offline
Find More Posts by GrootWitBaas
I don't speak German ....Yet !
GrootWitBaas's Avatar
Germany, Baden-Württemberg, Weissach im Tal
Joined Dec 2010
have a look at the multwii forums ....
GrootWitBaas is offline Find More Posts by GrootWitBaas
Old Mar 24, 2012, 10:14 AM
Cid156 is online now
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
I am using the bluewonder motor for my quad
It is nice motor, leight and very efficient with a 8x4 prop. ~5A for 400gr
But I do not recommend it for the multi plateform!!!
The wires are too fragile !!!! When you plug.. unplug... or when the wire hit the ground at landing, it used to break where you have soldered the connector
Five time I had to resolder it.
Cid156 is online now Find More Posts by Cid156
Old Mar 24, 2012, 10:16 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Just put a tie-wrap right after the motor to keep them from moving and you will never have any problem..
Using those a lot and they are real nice.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Mar 24, 2012, 10:22 AM
Cid156's Avatar
Switzerland
Joined Sep 2008
I had a lot of them on my planes. I already is use the tie wrap. The problem is where the bullet connector is solder.
Old Mar 24, 2012, 10:27 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I solder my motor direct.. Less weight. and no more problem.
Old Mar 24, 2012, 10:53 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
hex crash
hex crash (2 min 30 sec)
captaingeek is offline Find More Posts by captaingeek
Old Mar 24, 2012, 12:52 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo-Copter MiniControl
Hi All,
Just did first testing on my MiniControl.
MPU6050
Here is a video of it Gyro only flight:
Multiwii_2.0_preversion4
DiaLFonZo-Copter Crazy2Fly MiniControl Gyro Only (1 min 39 sec)
I have a hard time to setup the ACC mode..
It woble a lot and i can't find the right setting (PID) to have it stable.
Anyone have background with the MPU that can help me ?
Code for the board:
Code:
#if defined(DiaLFonZo_Mini)
  #define MPU6050
  #define ACC_ORIENTATION(X, Y, Z)  {accADC[ROLL]  = -X; accADC[PITCH]  = -Y; accADC[YAW]  =  Z;}
  #define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] =  Y; gyroADC[PITCH] = -X; gyroADC[YAW] = -Z;}
  #define MAG_ORIENTATION(X, Y, Z)  {magADC[ROLL]  =  X; magADC[PITCH]  =  Y; magADC[YAW]  = -Z;}
  #define MPU6050_ADDRESS 0xD2
  #undef INTERNAL_I2C_PULLUPS
#endif
Old Mar 24, 2012, 01:09 PM
Kf52t is offline
Find More Posts by Kf52t
UK, Redcar and Cleveland, Redcar
Joined Feb 2010
I've had similar issues with acc mode and v2 pre 4 so I'll be watching this one.
Kf52t is offline Find More Posts by Kf52t
Old Mar 24, 2012, 01:11 PM
gtx is offline
gtx
Find More Posts by gtx
gtx
Nike - Just Regret it!
Sweden
Joined Apr 2006
compass wiring
So, i now have the HMC5883L compass module and, how do i wire it up ? =P
i have my current setup like this,
shall it have 3 or 5 v ? after that i think its only to solder it to the same sda and scl as the rest right ?
gtx is offline Find More Posts by gtx
Old Mar 24, 2012, 07:48 PM
daytimer is offline
Find More Posts by daytimer
United States, IL, Joliet
Joined Sep 2010
slow left yaw
I finally had what I would consider a successful flight!
However, I have a slow left (ccw viewed from top) yaw. I have to constantly give it right "rudder". I tried using the trim on the tx, but I have to trim it so far right that I am no longer able to arm/disarm the motors.
Other than that, it's kind of like learning to fly heli's all over again Very different feel to it. But, I will likely build more in the future
daytimer is offline Find More Posts by daytimer
Old Mar 24, 2012, 08:00 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
3v is correct and pick up slc/ sda/ gnd.
Mine is mounted sensor on top wires aft. I had to use alternative sensor orientation in code and put a - in front of z. See a pic @ multiwii forum.
capt is offline Find More Posts by capt
Old Mar 24, 2012, 08:17 PM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
You can overcome that by putting ARM on one of the AUX channels and arming with a switch.
Art Newland is online now Find More Posts by Art Newland
