Old Mar 20, 2012, 10:20 PM
EnigmaSoar is offline
Find More Posts by EnigmaSoar
United States, FL, Spring Hill
Joined Apr 2009
Originally Posted by jimfc View Post
Hey - I still want to get up there to Spring Hill and see your craft and show you my new Y6!
Jim
Absolutely Jim. Would like to see it. We'll figure out when and where we can meet up. May bring a couple other quad/tri friends too.
Later
Chuck Stasek
EnigmaSoar is offline Find More Posts by EnigmaSoar
Old Mar 20, 2012, 10:23 PM
jimfc is offline
Find More Posts by jimfc
So I have a head on my butt.
jimfc's Avatar
United States, FL, Palm Harbor
Joined Dec 2010
Later
Chuck Stasek
Sounds good! The more the merrier! I may bring a friend who is interested in building a scarab too.
Jim
jimfc is offline Find More Posts by jimfc
Old Mar 21, 2012, 02:59 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Originally Posted by warthox View Post
I noticed now!
Where they are coming to mind?. a lot of fun
Widelec is offline Find More Posts by Widelec
Old Mar 21, 2012, 08:07 AM
chebari is offline
Find More Posts by chebari
Joined Dec 2011
My multiwii copter collapsed. Does it cause?
After two batteries of 7 minutes.
about 2 meters callus suddenly.
Why?
My friend happened
It happened exactly the same with CRIUS.
Multiwii FPV Crash (0 min 31 sec)
Any idea why?
sorry my bad English
chebari is offline Find More Posts by chebari
Old Mar 21, 2012, 09:03 AM
cybadredd is offline
Find More Posts by cybadredd
Joined Mar 2012
very small ducted fan 32bit multiwii?
Micro Ducted Fan EDF Quadcopter Build 35 Grams With Lipo (2 min 52 sec)
cybadredd is offline Find More Posts by cybadredd
Reply With Quote  (Disabled)
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Why?
My friend happened
http://www.youtube.com/watch?v=Tf04CWer76s
Any idea why?
Looked like the back motors stopped.
Connectors? wiring? low voltage?
Just guessing, there is no way to know by a watching a video clip.
capt is offline Find More Posts by capt
Old Mar 21, 2012, 10:43 AM
zerosight is offline
Find More Posts by zerosight
Deutschland
Joined Nov 2011
Why?
My friend happened
Any idea why?
I see that you have a serious vibration problem. Those vibrations MUST result in defects. All motors stop at the same time, this might move the problem to the commonly used components like power distribution or flight control. The beebs after the crash sounds like a normal initialization of the ESCs. So I assume, you have an interruption at your power distribution. Take care, that all of the connections are soldered perfect and try to avoid detachable connections wherever you can.
AND BALANCE YOUR MOTORS/ PROPS ;-)
zerosight is offline Find More Posts by zerosight
Old Mar 21, 2012, 10:51 AM
chebari is offline
Joined Dec 2011
I understand that could be a power outage the Esc?
very fine wires perhaps?
Old Mar 21, 2012, 11:06 AM
daytimer is offline
Find More Posts by daytimer
United States, IL, Joliet
Joined Sep 2010
Do you have your esc set for nimh, not lipo? It could be a bad esc too. I had one do that on a 250. It shut down in mid-flight, but powered back up after it reset.
Let it idle on the ground for a while and see if any of the motors cut out, or if all of them cut out at once.
daytimer is offline Find More Posts by daytimer
Old Mar 21, 2012, 01:03 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Why?
My friend happened
Any idea why?
What was the pack voltage after the crash? I bet it was simply low voltage cutoff.
Qrome is offline Find More Posts by Qrome
Old Mar 21, 2012, 01:09 PM
empire007 is offline
Find More Posts by empire007
Off my horse
Joined Apr 2011
http://youtu.be/oJlzZghI6MU
I saw someone posted this on a very 'intense' thread earlier this morning.
Came with a callout and everything...
http://www.rcgroups.com/forums/showp...&postcount=117
empire007 is offline Find More Posts by empire007
Old Mar 21, 2012, 02:35 PM
chebari is offline
Joined Dec 2011
75% v
Old Mar 21, 2012, 02:36 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
Mine is flying so well in gyro, Imo if you just tweak with derivative from the default settings then it can help a lot. You don't really need to touch proportional unless it's under compensating and D is at zero.
Still trying to sort out level mode, I am really waiting for multiwii on android to be updated as it will make it much easier to sort it out. I think that I will just decrease derivative and it will improve it. The problem is that it remains level but quite unresponsive on the sticks.When I take off there is no drift but sometimes it randomly starts going to one side.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Mar 21, 2012, 03:32 PM
daytimer is offline
Joined Sep 2010
That looks to me like electrical interference to the camera, not vibration.
Old Mar 21, 2012, 03:50 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
+1
It seems that the ESC's initialized.. you can clearly hear the 3 beeps that indicate a battery with 3 cells.
Once I had my easystar crashing because of a banana plug that was not good.. since then never used them again for battery plug
jhsa is offline Find More Posts by jhsa
