Old Feb 05, 2012, 07:36 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo-Copter SpyderQuad Square
First one cut...!
Feel so good to see it in real after the CAD work.
Thread Here
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 05, 2012, 08:11 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Huh, looks strangely familiar.
mxspode is offline Find More Posts by mxspode
Old Feb 05, 2012, 08:13 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Humm.. They look similar.
But it's the first time i see yours.
Old Feb 05, 2012, 08:21 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Seems to be an invadion.
http://www.goodluckbuy.com/fiber-gla...lticopter.html
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 05, 2012, 08:28 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[]http://www.goodluckbuy.com/images/detailed_images/sku_77831_2.jpg[/IMG]
I like mine better...
Old Feb 05, 2012, 08:43 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I like the fact that chinese one comes with landing gears and all the hardware for 37 shipped.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Feb 05, 2012, 08:57 PM
Joined Aug 2009
Hey Guys, by no means is this a recommendation, I was browsing and came upon these WMP
NEW Wii Motionplus Motion Plus for Nintendo Wii Remote
Edited: http://www.ebay.com/itm/Wii-Motionpl...item335f11583c
Another one, same vendor
Old Feb 05, 2012, 09:15 PM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Similar...
Maiden flight of this thing... 9-21-11 (1 min 37 sec)
troynh is offline Find More Posts by troynh
Old Feb 05, 2012, 09:19 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by troynh View Post
This one don't look the same at all.
I don't pretend to be the only one that did a spider quad frame...!
Just want to share it with all of you..
BTW: i did it with round tube first.. then ported the idea to square
Old Feb 05, 2012, 10:13 PM
bcurtis is offline
Find More Posts by bcurtis
United States, TN, Chattanooga
Joined Apr 2011
Carrier Plate / Carrier Board / Accessory Mount
Everyone seems to have standardized on 45mm screw spacing for their flight control boards (paris/fly/divide). Does anyone have a source for cheap / light / plastic carrier boards for mounting accessories pre-cut at 50mm with 45mm hole spacing? Seems like this should be everywhere, but HK and the other usual suspects don't seem to have.
I suppose ponoko might be an option if no one has done this yet. The arducopter guys have something simple like this:Arducopter carrier plate v1 but they built to 80mm.
b
bcurtis is offline Find More Posts by bcurtis
Old Feb 05, 2012, 10:14 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by Scotth72 View Post
That's how the I term works. It's accumulated error. If you give a stick input, but the aircraft does not move, (its on the bench), then the FC will continue to try to get the aircraft to the desired position. Even if you bring the stick back to zero, it is still trying to get to the older position.
Why would it try to get to an "older position" if that older position is no longer where we are commanding the quad to?
If the quad is level and the TX stick is at neutral then isn't the quad at the commanded position, regardless of if it is in the air or on the ground, for which there should be no accumulated error?
If the quad is on the ground and we give a right roll command of 10 degrees, I can see why the error would build up past 10 degrees if the quad is not allowed to rotate to 10 degrees. But if you hold the quad in your hands and roll it to 10 degrees, the accumulated error should go back to zero since the quad is now at the commanded 10 degrees of roll. In the air or in your hands, 10 degrees of roll is 10 degrees of roll.
If the sticks are at neutral then the desired roll angle is zero. If the quad is level in the air or on the ground then it is at the desired roll angle of zero for which the error should be zero and the motor commands should be equal. Zero degrees of roll on the ground or zero degrees of roll in the air is still zero degrees of roll. If not then I'm missing something here
RCvertt is offline Find More Posts by RCvertt
Old Feb 05, 2012, 10:55 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Yes, but I don't think the system is that perfect. I have always found that if the quad is not allowed to move when the stick is moved, then the outputs never fully equalize out. I have never had a problem in the air however. I am not sure if the I term is ever set to zero in the MW code.
Scotth72 is offline Find More Posts by Scotth72
Old Feb 05, 2012, 11:06 PM
MyEyE is offline
Find More Posts by MyEyE
Joined Jul 2011
New Board and shield
Details
1) 8 PWM channels for 8 motors.
2) 3 Dedicated Analog channels for camera stabilization and trigger.
3) 4 Extra Analog channels for whatever.
4) 2 UARTS: RX0, RX1 and TX0, TX1 for GPS, LCD or wireless, etc.
5) Direct drop in of BMA020, Sirius, Atmel, Pololu MinIMU-9 sensor BOBs.
6) Sketches up to 130048 bytes.
7) Standard 45mm mounting on the shield.
8) Direct plug in of Receiver.
9) Motor connections where needed so no birds nest on top.
8) Built in LLC if running the board at 5v but all test indicates that the board works fine at 3.3v so no LLC needed for 3.3v sensors!
Memory comparison:
Feature 328P 1284P 2560P
RAM 2k 16k 8k
Flash 32k 128k 256k
EEPROM 1k 4k 4k
UART 1 2 4
IO Pins 23 32 86
Interrupts 2 3 8
Analog Inputs 6 8 16
PWM 6 8 14
MyEyE is offline Find More Posts by MyEyE
Old Feb 05, 2012, 11:14 PM
timecop is offline
Joined Dec 2010
Originally Posted by MyEyE View Post
Details
Memory comparison:
RAM 2k 16k 8k
Flash 32k 128k 256k
EEPROM 1k 4k 4k
UART 1 2 4
IO Pins 23 32 86
Interrupts 2 3 8
PWM 6 8 14
Cool.
How about some innovation?
Feature STM32F103C8T6
RAM 20K
Flash 64K/128K
EEPROM Use flash as eeprom
UART 2
IO Pins 37
PWM 4 16-bit timers with 4 channels each
Features DMA, USB
Timers 4 16bit timers, 32bit systick, 32bit cycle counter
Analog 2 12bit ADCs, up to 7.2msps sampling rate x 10 channels
The board: 36x36mm [the new standard]
6x motor outputs
8x pwm inputs reassignable to motor outputs when using PPM
gyro/acc/baro/mag
built in USB
Thank you.
Old Feb 05, 2012, 11:17 PM
MyEyE is offline
Joined Jul 2011
Originally Posted by timecop View Post
Cool.
RAM 20K
Flash 64K/128K
UART 2
IO Pins 37
Features DMA, USB
6x motor outputs
gyro/acc/baro/mag
built in USB
Thank you.
Multiwii compatible? I do like the birds nest! and direct plug in of RX.
