like you, in the beginning I didn't understand why ver1.9 was not compatible with my hardware: jussih board v1.11 and wmp, with or without other sensors. I know that olders mwc versions bypass i2c errors, programmers said it was a mistake. My working jussih v1.11 board was modified like this unsolder d12 diode, and pullups resistors(4k7 if i remember) under arduino minipro(not leds resistors 470 ohms ).I solder a little wire from the true 5v (esc) to wmp i2c "d12" connector. now the i2c wmp connector is connected like this +5v +5v sda scl gnd. I solder a 2k2 resistor between sda wmp i2c connector and 5v I solder a 2k2 resistor between scl wmp i2c connector and 5v I power the board with 11.1v and plug ftdi and i2c error=0 jussih's pullups board was done between 3.3v and ic2 lines, with a oscilloscope i2c edges are 0v/3.3v now i2c edges are 0/5v and no errors appear. regards. |
The ESC control is not done via multiwii in this case, but directly via your TX/RX RC, like a variable pitch heli. It's up to you to tune a throttle curve, with normal and idle mode. |
Sounds like the multiWii would make just using a regular VP heli a lot easier to use. Have the heli spool up slowly when throttle is above 1040 then have it gradually go into idle up mode when throttle is above 1100 and such. |
United Kingdom, Milton Keynes
Joined Feb 2005
Bucharest, Romania
Joined Sep 2009
Thank you Alex & Team for making this real.
Keep going...
Pro Mini ~$20 MP+ gyro ~$15 Acc ~$15 Baro ~$15 Compass ~$15 Shield ~$15 Total about $95 add a couple dozen hours of my time in soldering, configuring etc and maybe a blown device if I screw up the wiring, followed by cussing and a delay to get new parts. Compared to this thing for $69 plus free shipping and no hassles ready to fly. http://www.ebay.com/itm/MWC-v1-9-Mul...-/150713400273 OK so they paid a kid $4 to solder it up and made $1 profit. So maybe they did make a quick buck, but I just love them for it. So far I spent $200 and still am not happy with my flying ball of wires. ![]() Hey....no contest the China made Multiwii 9DOF "all in one" ready to fly wins hands down. Just bought one, only 7 left now. This ebay seller has a 99.7%+ rating on over 24,000 items....great customer satisfaction! Ray |
sri lanka
Joined Nov 2010
my multiwii quadcopter altitude hold test
my quad works very well with 1.8 ITG 3205 NCK and baro.
all work perfectly. but my itg3205 doesn't work properly with 1.9 ![]() now i'm using 1.8 roll , pitch P=3.2, D=50 this is the best for my quad. no any vibrations. again thanks a lot for alex and multiwii team. ![]() altitude hold test (ITG3205,NCK,BMP085)
2'nd cam test there are some problems. when the quadcopter comes down so fast there are some vibrations and the pilot is not very good. ![]()
Deutschland
Joined Jul 2011
I never used a warthox board before. On the board it says WMP Power to D12. Here is the picture . But I'll try your solution tomorrow. It was the first try flying.Quote:
