Old Jul 29, 2010, 07:09 AM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Hello Alex and all.
After reading with great interest, I find myself with a burning desire to build my first tri, and after reading your project notes Alex, I will use your excellent TriWii set up. Your very detailed web page has given me more than enough information to have the confidence to feel I can be successful with this project. Progress has stopped at the frame, Sparkfun stuff will be here soon, and the HK stuff is on backorder. My important parts include:
Turnigy 2206(1130Kv) with 10 x 3.7
HK SS 18-20Amp ESC
Dragonlink LRS via Futaba 7C
(using your parts list for the brain, Mini pro and non cloned WMP)
If anyone see's any potential issues with the above equipment please advise.
I do have just some quick questions which I haven't been able to find answers to:
1. Will the ESC settings need to be changed running the 18-20A SS instead of the SS 8-10A?
2. Is there anything I should do during the WMP + Audrino build phase that will make the Nunchuk upgrade easier when it is ready to go?
Thanks for the great project and info.
George.
Thumb_number is offline Find More Posts by Thumb_number
Old Jul 29, 2010, 01:15 PM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
@420RcPilot
I think a nunchuk version should be ready in less than one month.
The GUI and serial communication is ready for it.
The nunchuk decode code is ready, but I have to rebuild another tri for this and to do some integration + a lot of test.
@garindo:
nice ! I'm waiting to see it outdoor
@thumb:
I think SS 8-10A and SS 18-20A share the same processor and the same soft. There shouldn't be any differences to use it.
For the nunchuk upgrade, I will use the extension port of the WM+ (so it's better to not recover it by wires), and I will use the digital pin 6 for the RX channel 5. The rest should remain unchanged.
Yesterday, I did something crazy: a full throttle looping with a diameter of 50 meters. LEDs are almost mandatory to still have a good visualization.
The last version handles very well the full throttle situation.
I'm now fluent in basic 3D: flip front, flip back, flip right, flip left, looping front, looping back, barrel and immelman
Alexinparis is offline Find More Posts by Alexinparis
Old Jul 29, 2010, 02:15 PM
MarcAntonio is offline
Find More Posts by MarcAntonio
Speed Nut
Joined Jan 2010
Hello Alex,
great progress on your controller, love the fiberglass tricopter, and will wait for accel development.
MarcAntonio is offline Find More Posts by MarcAntonio
Old Jul 30, 2010, 09:36 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Alex, Iīll be looking forward to having accels as well...
I am assuming you will use the pass-through method for nunchuk (same as Aeroquad and BaronPilot)...?
Jussi
JussiH is offline Find More Posts by JussiH
Old Jul 30, 2010, 02:07 PM
jonnyc67 is offline
Find More Posts by jonnyc67
jonnyc67's Avatar
Hi Alex, Thanks for an excellent project.I just got my Nano v3 programmed with v2.1 & hooked up to the WM+ clone. All is well ... The GUI is really useful. I'm using fs-r6a receiver (hobbycity 2.4ghz 6ch with no problems so far). The WM+ clone seems ok on test so far at least, but I'm glad you've done the separate PID control for each axis, as the pitch axis on my WM+ clone seems a bit less sensitive than the roll axis. Just need to make a new frame, as my existing tri (1 Kg flying weight, 55cm motor to centre) is home to a KKcontroller at present. Can't wait for you to get the acc's integrated. I like the look of the complementary filtering code William Thielke's written for integrating his acc's on shrediquette...
jonnyc67 is offline Find More Posts by jonnyc67
Old Jul 30, 2010, 05:01 PM
tazdevil is offline
Find More Posts by tazdevil
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
hi Alex, I do my first flip today with triwii, new yaw mecanical is working fine and I can do what I want
need to test new soft with onboard expo.
my triwiii is nunchunk ready if you want a beta tester ,I'm your man
next step, integrate triwii imu on my shredikette frame, I've got the acc of the shredi who is deadI don't now why. Another reason to test it ;
tazdevil is offline Find More Posts by tazdevil
Old Jul 30, 2010, 11:21 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
I have a random question. Can I just directly solder the USB FTDI board (which normally plugs into header pins) directly to the Ardunio board? As long as the USB cable isn't connected to it, I should be ok right? I don't want to have it go into some weird programming mode if I solder it to always be on there to make it easy to plug in. Sorry I don't have much experience with the Arduinos.
Sid3ways is offline Find More Posts by Sid3ways
Old Jul 30, 2010, 11:59 PM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
yes. but then its not available to program another arduino, or debrick a router, etc.
what arduino are you using? many have the ftdi chip built into the design. duemilanove, nano, seeeduino, etc...
-sj
sonicj is offline Find More Posts by sonicj
Old Jul 31, 2010, 12:22 AM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
I'm using the pro mini which is what Alex built this around. I guess I'll just stick with the header pins. I was going to go lazy since I couldn't find any header pins, but found an old sound blaster card which has some that I'll desolder off the board and use.
Thanks sj.
Old Jul 31, 2010, 04:02 AM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
alex, i read the following on your site and had a thought...
But I observed a very annoying behavior with Turnigy Plush ESCs: once it is set under the running limit, but the ESC reaction time to return into the running range is very high, causing crashing oscillations.
this sounds like the "soft start" feature is enabled on your plush escs! are you sure the soft start feature is disabled? cheers!
-sj
Old Aug 02, 2010, 05:39 PM
Logiq is offline
Find More Posts by Logiq
Respect our earth !
Belgium / Europe
Joined Dec 2009
Hi all,
I'm new to this post however in relation with Alex since a long time now
and build my TriWii since a while now.
My TriWii does fly well and I could already spend some good time in FPV.
You can see some footages here http://www.vimeo.com/joelcordier
By the way, it's maybe a good place to thank Alex for his super project,
kindness and devotion. Merci beaucoup (in french)
JoŽl
Logiq is offline Find More Posts by Logiq
Old Aug 02, 2010, 06:33 PM
Logiq is offline
Respect our earth !
Belgium / Europe
Joined Dec 2009
To Wland and others.
I'm also experiencing a crazy Rx problem.
My Tx is a JR 10x - 35MHz
When i use a Corona receiver (tested with 4 devices) I'm having troubles.
Randomly Throttle, Yaw, Roll or Nick are affected with a value bump.
I do not have those problems with a 'conventional' Rx like a single FM
Unfortunately I need Corona type Rx here as there is to much noise in
the 35 band here.
BEWARE that with a FM receiver, a loss of signal can result in
a "Motor Off" command followed by a silent free fall.
See my nice video here
The beep tones yoy hear are extra code that monitors the RX.
http://www.vimeo.com/13835927
Happy end with only 3 broken propellers.
I filmed what happens on the GUI.
I do not understand what's going on as I can confirm that
there are no wrong signals coming out of the Corona receivers.
I monitored the PPM pulses with a good digital scope.
The problem appears at a certain RPM with motors spinning.
I assume it's a parasitical signal that is troubling the arduino.
I'm an electronician and made some electrical filterings without success.
Filmed GUI and running motor without propeller.
Tricopter - Jam on GUI.mp4 (0 min 34 sec)
JoŽl.
Old Aug 02, 2010, 07:10 PM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
the 35 band here.
JoŽl.
great footage joel!
i would suggest using a servo tester to bypass the tx & rx and run your bench test again. if the problem goes away, you know its RF /radio related. if it remains, its likely in the arduino or the wiring.
unplug the motors, does it still happen? if not it could be a vibration induced problem.
disconnect the esc's. does it still glitch?
get where im going? good luck!
-sj
Old Aug 03, 2010, 07:53 AM
cholo is offline
Find More Posts by cholo
Joined Aug 2009
hi,
can you specify which one works ok ?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_1888wt_911
thanks,
cholo
cholo is offline Find More Posts by cholo
Old Aug 03, 2010, 08:21 AM
jonnyc67 is offline
jonnyc67's Avatar
Hi Cholo, I've got 3 wm+ controllers from ebay, all clones. Two work ok in testing using the GUI - done about 1/2 hour on each with no problems or glitches. The third one works ok for a few minutes, then freezes the GUI completely & has to be restarted.
It does this every few minutes so would be a disaster on a tri. The snag is I had the good clone & the bad clone from the same seller, and Alex had the same problem with the other seller I posted, so it's just the luck of the draw from either from these sellers - you could get a good or bad clone as they both seem to be switching suppliers & the boards keep getting updated..... My bad board is blue colour, single sided with just the connector on the back & IDG650 and ISZ650 mems chips, there is also a 'blob' chip on the board which i assume is the a-d convertor. says version MP-V1.5B on the back. I may try this one on a 3.3v supply to see if it makes a difference.
Just to make life really annoying, one of my good clones, that seems to work fine with no glitches, at least on the gui monitor looks identical to Alex's bad clone. We may just be getting unlucky & getting faulty boards...
You could try asking the seller what version of board is in the clone they're selling but other than that it's pretty much hit & miss. Same thing with nunchucks on ebay to be honest - had 3 with 2 different clone boards inside, but haven't had a chance to test them properly yet.
