Old Nov 09, 2011, 05:31 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Before I spend the time to wire it up, will the MultiWii work without a WMP gyro attached?
I just want to use the ProMini and MultiWii code to do some channel mixing for some servos that my TX can't do but I don't need the gyro/IMU part of the code.
RCvertt is offline Find More Posts by RCvertt
Old Nov 09, 2011, 05:34 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
You will probably need to do some commenting out of things. Or else it'll spend years in i2c timeout code.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Nov 09, 2011, 05:54 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Thanks. In a time crunch so I'll throw some gyros in there.
Sounds like a (#define MixerOnly) or (#define NoIMU) option would be cool for those that just need a motor or servo mixer.
Old Nov 09, 2011, 06:00 PM
timecop is offline
Joined Dec 2010
It's not as complex as it sounds. I would just add 'return;' into stuff like WMP_Init(), WMP_GetADC() or similar, instead of making it do i2c reads/writes. Only a couple lines change.
Old Nov 10, 2011, 01:38 AM
-katana- is offline
Find More Posts by -katana-
Joined Oct 2009
Originally Posted by Farmer_Joe View Post
-katana- great video! Do you have some pictures for your copter.
Unfortunately not, however, is a Okto flat, about 3.5 kg, totally self-made with pitch and roll and 5.8 ghz downlink.
-katana- is offline Find More Posts by -katana-
Old Nov 10, 2011, 03:35 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
What do you think about ESC with integrated data logger?
Integrated the function of flying data logger, could recording the flying data as: Current, Voltage, Temperature, RPM, Power, Throttle travel etc
High rate adjustable switching (PWM:8KHz/12KHz/16KHz)
http://www.himodel.com/electric/HIFE...ESC-20A-K.html
Widelec is offline Find More Posts by Widelec
Old Nov 10, 2011, 04:17 AM
timecop is offline
Joined Dec 2010
Buy one, take it apart, take some pics. Personally I don't really see the need for 4 escs logging flight data.
Old Nov 10, 2011, 05:43 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
"4. Upgradeable the firmware of ESC through Internet"
Wowww those guys actually thought forward. I am amazed.
I think is asking too much that the code could be open, but this is a great start.
IceWind is online now Find More Posts by IceWind
Old Nov 10, 2011, 07:47 AM
Widelec is offline
Simple is the best
Joined May 2011
-Programmable the parameters of ESC through USB cable connected to computer
-Upgradeable the firmware of ESC through Internet
-High rate adjustable switching (PWM:8KHz/12KHz/16KHz)
interesting features
I think these features will soon many of esc
Old Nov 10, 2011, 08:11 AM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
There is a thread on this forum dedicated to reprogramming various ESC's to increase their performance.
http://www.rcgroups.com/forums/showthread.php?t=1513678
jer291113 is offline Find More Posts by jer291113
Old Nov 10, 2011, 08:15 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Thank you, I was about to make a purchase of some new ESCs, your post comes at the idea time.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 10, 2011, 08:18 AM
timecop is offline
Joined Dec 2010
I'm glad you're testing them. Make sure to tear some up and post pics.
Old Nov 10, 2011, 08:43 AM
Joined Aug 2009
I have been eyeballing these for sometime now but never pulled the trigger.
http://www.hobbyking.com/hobbyking/s...hless_ESC.html
Old Nov 10, 2011, 08:49 AM
timecop is offline
Joined Dec 2010
Ohhh,, another 'Internet ugpraeable ESC firmware'. I downloaded the HiFei software, and unless the've coded the "internet upgrade" part in invisible programming language, it doesn't actually connect to internet to upgrade. Of course, there's no actual firmware for download anywhere on HiFei's site, either. It asks you to open a 'dlc' file for upgrade. Looking at the superbrain thing, it's firmware is also .dlc....
Old Nov 10, 2011, 09:34 AM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Pretty sure they are the same thing in different packaging. A few have come across my build table and I am not impressed. Seems like a good way to charge $30 for a $15 ESC to me. Just my opinion guys, have at it.
Rob...
mxspode is offline Find More Posts by mxspode
