Old Nov 05, 2011, 06:50 PM
larsm's Avatar
Germany, NRW, Münster
Joined May 2011
Originally Posted by ScooterInVegas View Post
When I go to Level Mode, my Paris drifts badly to the left. How can I fix that? If I trim 10-12 clicks it stops, but I have to de-trim if I switch back to acro.
did you calibrate before flight?
larsm is offline Find More Posts by larsm
Old Nov 05, 2011, 06:54 PM
USA, AK, Soldotna
Joined Jan 2005
Have you tried the 'stable trim'?
Dearm
Throttle to full
Move the pitch or roll stick to add a 'click' of trim as needed.
In your case I would say try 10 or so movements of right roll.
pinball is offline Find More Posts by pinball
Old Nov 05, 2011, 07:06 PM
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
Originally Posted by larsm View Post
i have 1.8 patch 2 now. is the problem fixed there? is "old_stab" the same as inverting acc pitch? how to invert pitch? which axis is pitch? z-axix (motor shaft) axix? is this a general problem of all bma020 users?
//****** end of advanced users settings ************ *
//if you want to change to orientation of individual  sensor
//#define ACC_ORIENTATION(X, Y, Z)  {accADC[ROLL]  =  Y; accADC[PITCH]  = -X; accADC[YAW]  = Z;}
//#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = -Y; gyroADC[PITCH] =  X; gyroADC[YAW] = Z;}
//#define MAG_ORIENTATION(X, Y, Z)  {magADC[ROLL]  = X; magADC[PITCH]  = Y; magADC[YAW]  = Z;}
/****END OF CONFIGURABLE PARAMETERS****/
botton of config.h you need to change
//#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = Y; accADC[PITCH] = X; accADC[YAW] = Z;
to
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Nov 05, 2011, 07:09 PM
Joined Feb 2007
disarm, go full throttle, tap right aileron in sets of 5 till level mode doesnt drift
Old Nov 05, 2011, 07:14 PM
Joined Feb 2007
quick easy way to tell if acc axis needs changing
link to gui and rest multi on an angle if axis is correct angle will remain constant in gui if axis needs changing angle will return to level over a 20 to 40 second period
Old Nov 05, 2011, 07:16 PM
Joined Feb 2007
its untuned out in wind using 620kv motors so its dancing like a punch drunk boxer but do you like the new lights?
n-bot ii multiwii quadcopter testing 1st level lighting nx4008 620kv windy nov 5th 2011 N3M1S1S (1 min 22 sec)
Old Nov 05, 2011, 07:28 PM
quadraf's Avatar
Holland
Joined Apr 2010
A dream comes true.
MegaKopter (1 min 52 sec)
quadraf is offline Find More Posts by quadraf
Old Nov 05, 2011, 07:30 PM
ppridday's Avatar
United States, AL, Mobile
Joined Mar 2005
I was maidening my Quadrino tonight and found the same thing. I forgot about the disarming and doing the tapping left, right, up or down. This works with the Quadrino boards as well correct? Also, you leave it in level mode correct?
Paul
PS: Also, is this only in 1.8 patch 2? I am running 1.7 at the moment..
ppridday is offline Find More Posts by ppridday
Old Nov 05, 2011, 08:01 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Dearm
Throttle to full
Thank you.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Nov 05, 2011, 08:31 PM
Joined Feb 2007
Paul
correct both times
Old Nov 05, 2011, 08:32 PM
Joined Feb 2007
Thank you.
np
Old Nov 05, 2011, 08:52 PM
larsm's Avatar
Joined May 2011
my english is not so very good, what does "rest multi on an angle" mean?
the line is alredy "//#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = Y; accADC[PITCH] = -X; accADC[YAW] = Z;}" but it is commented out. i will enable it.
is this right?:
acc and baro pitch and roll should go to the same direction: calibrated acc_pitch=0 acc_roll=0 acc_z=255. nose down pitch positive, right "wing" down roll positive. copter starts from ground streight up z increses. start yaw in clock direction in top view yaw positive.
line commented out (as original) it behaves exactly like this. when i enable the line, acc_roll and acc_pitch get inverted and it behaves very strange.
Old Nov 05, 2011, 09:00 PM
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Originally Posted by quadraf View Post
This MEGA Octo beats the hell out of any copter.
http://vimeo.com/27055151
Well done! Made me chuckle.
-Tim
troynh is offline Find More Posts by troynh
Old Nov 05, 2011, 09:15 PM
Joined Feb 2007
rest multicopter (quad?) on a flat suface then raise the back till its at 30deg and watch what happens in the gui over 30 seconds without moving the quad
remove the - in front of the x and try that instead
is this right?:
sorry someone else will have to help there as ive never really looked i tend to just watch what the arrows are doing and make changes from that for acc
leave the line of code as is jst remove the -
Old Nov 05, 2011, 09:40 PM
ppridday's Avatar
Joined Mar 2005
correct both times
Thank you sir!
Paul
