Old Jul 22, 2010, 06:47 PM
JimnAz is offline
Find More Posts by JimnAz
Joined Mar 2007
Hi Alex,
Can you explain how to configure from the GUI? A short explanation would be just fine. I can read and see the values but cannot figure out how to change the PID values.
Thanks again.
Jim
JimnAz is offline Find More Posts by JimnAz
Old Jul 23, 2010, 12:23 AM
wland is offline
Find More Posts by wland
South korea
Joined Dec 2003
Originally Posted by JimnAz View Post
Hi Alex,
Thanks again.
Jim
on the value you drag your mouse click left and then click write button
wland is offline Find More Posts by wland
Old Jul 23, 2010, 09:38 AM
bofred is offline
Find More Posts by bofred
Kungshatt
Joined Mar 2008
Hi, and thank you for this great thread!!
I have a stupid question from a non programming skilled person like me.
Is there any easy way of compiling this .pde file?? I have read a tutorial I found on the internet of how to do it with Eclipse and Im getting no were..
http://www.vogella.de/articles/Eclip....html#overview
The ordinary .c files work like a charm but I cant get the .pde´s to be build. I feel stupid (its my first experience with making code...)
Please tell me if Im on the right track here or if Im going in the wrong direction... Thank you!!!
bofred is offline Find More Posts by bofred
Old Jul 23, 2010, 10:06 AM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
yes, use the arduino ide. link
eclipse will work, but takes some effort to configure for use with arduino. unless you have a specific need for eclipse, just stick with the arduino ide.
-sj
sonicj is offline Find More Posts by sonicj
Old Jul 23, 2010, 11:35 PM
JimnAz is offline
Joined Mar 2007
Thank you very much. Now all works fine on the GUI except for the Tri graphic in the lower right corner.( not much to worry about though). The only thing I have left to get is the ESC's.
One more question for anyone on here that may have the answer:::
What ESC's are recommended for this project. I have already established that my CC10 esc's do not arm with this code so I presume they will not work.
If someone would link to them, I would really appreciate it.
Alex: would it be possible to have the axes work using servo's to variable pitch rotors instead of using RPM(speed) controls? I have a lot of experience with collective pitch helicopters and believe this would be a much more precise way to maintain altitude and provide smoother control in wind much like a collective heli vs. a fixed pitch heli.
Thanks in advance.
Old Jul 24, 2010, 03:42 AM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
The white Tri graphic in the lower right corner is for the moment static.
But it will represent the inclination when the nunchuk code will be ready.
I recommend the super simple ESC or Turnigy Plush from Hobby city
I think it would be possible without to much adaptation to the current code.
The hardware is ready to support one more PPM output that could control the spin rate of all motors. We could imagine something like a real heli with a normal and idle up mode on another RC channel.
But think about the complexity of the solution and the crash cost If your motivation is strong enough to build such a frame, I could adapt the code for you.
Alexinparis is offline Find More Posts by Alexinparis
Old Jul 24, 2010, 12:46 PM
JimnAz is offline
Joined Mar 2007
Hi Alex,
Thank you for the very rapid response.
I was only asking about the ESC suitability because I thought maybe some other ESC's than the Turnigy or Super Simple might work.
I am now designing the airframe for the Tri and incorporating the Variable Pitch mechanics is not much of a task. The frame will be much like your moulded frame from FG and CF tow. The variable pitch units are tail rotors from 450 helicopters. Yaw will still be by tilting the Yaw motor assembly.
The code should support driving three pitch servos at 50hz(?PPM?). The throttle(ESC's) should also be at 50Hz and all three motors can be run from one channel. I would imagine that the throttle would not need to be run at the high refresh rate like fixed pitch is now. I think that the pitch of the rotors would only change in response to a correction and not necessarily be a collective type of need like a heli.
Thank you for the offer of modifying the code and yes, if you still would do this, I would be very grateful and accept your offer. If you want to, you can PM me for any other details you may need to consider.
Thank you once again for this great work.
Jim
Old Jul 24, 2010, 01:48 PM
bofred is offline
Kungshatt
Joined Mar 2008
-sj
Thank you Now Im really happy, eclipse made me %(&/¤/#...
Old Jul 24, 2010, 06:27 PM
wland is offline
South korea
Joined Dec 2003
today I did first flight.
It's very stable but there were cutoff. bat was full charged 12.6V
I used PCM1024- rx R146iP Futaba/ tx ff9c
please watch my video about 42s and last scene.
MOV06342.MPG (1 min 19 sec)
My tx ff9c has problem I think.
I change my tx to dx7.It's ok.
Old Jul 24, 2010, 07:50 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
wland - Same thing mine is doing - I thought it was i2c dropout from a bad WII fake - not sure though I havent had time to mess with it -
cdi3d is offline Find More Posts by cdi3d
Old Jul 24, 2010, 09:16 PM
wland is offline
South korea
Joined Dec 2003
I'm using original WMP.
when it fell down, it's possible to fly.
if there was i2c error, triwii can not fly before re-initiation.
Old Jul 25, 2010, 05:24 AM
wland is offline
South korea
Joined Dec 2003
I changed my Tx FF9c to DX7
there was no cutoff.
triwii flight.wmv (3 min 45 sec)
Old Jul 25, 2010, 10:50 PM
wland is offline
South korea
Joined Dec 2003
Hi to all
When I controlled triwii copter, there was yaw drift.
triwii copter rotate slowly.
How to fix yaw drift?
what about increas P value of Yaw?
Yun
Old Jul 26, 2010, 04:54 AM
Paris, France
Joined Jun 2009
Hi to all
Yun
Hi Yun,
Thank you for your video and feedback.
Your tri seems very stable
I doubt your Futaba TX/RX is faulty in this setup. You're not the only one to encounter this problem using a non 2.4GHz radio.
I'm going to release a receiver code with one more verification. I hope this won't impact to much the jitter of RC channel reception.
The yaw drift is impossible to cancel, but with a good angle mechanical adjustment and few trims it should be nearly unnoticeable. An increase of P yaw could also decrease the drift, but for a better head lock feature, I still need to implement a full PID loop (for the moment I and D are not used for yaw)
Old Jul 26, 2010, 05:05 AM
Paris, France
Joined Jun 2009
Hi Jim,
We can use the current 490Hz PWM output to drive 3x 50hz servo instead
+ the current servo yaw
+ another 50Hz PPM for all ESC.
It's not a problem using a servo lib.
You're right with the throttle refresh rate, it won't be so critical.
But I have a small doubt with the pitch refresh rate: 50Hz is maybe to small (we already know it is to small to drive ESCs on a multi)
If you look a heli flybarless system, they need specific servos that can accept a higher refresh rate to maintain a good cyclic attitude.
I suspect it will be also the case here.
