Spring Hill, FL
Joined Apr 2009
Chuck |
United States, TX
Joined Jun 2007
and how do you know is your esc's are ppm. |
Anyone willing to be the first guinea pig?
Arduino 3 axis Accelerometer motion sensor free 3cables http://cgi.ebay.com/Arduino-3-axis-A...item2c583e7503 |
Brisbane, Australia
Joined Jun 2007
From a brief browse, it looks to me like Alex's servo routine uses interrupts to determine how long to keep the pulse active, which allows the rest of the code to continue on in the meantime. As my Arduino still hasn't arrived, and as I'm at work and supposed to be working on other (non-Arduino) code, I can't really delve into it too much now. If you look in the area around line 475 you'll find his servo stuff, but interrupts are a bit of a pain to explain, and I haven't looked at the Arduino enough to figure out exactly how they work in that environment anyway. Oh, also note that it looks like Alex is using an alternate method to DigitalWrite, which from the comments claims to be "25 time faster than DigitalWrite", so that could be something to look into in the meantime. |
http://translate.google.de/translate...%3D%26marke%3D ![]() Anyone?
Minthrottle
I have a question to all not using the 10A Turnigy Plush or Super Simple ESCs.
How is the optimal value for MINTHROTTLE determined? My experience is that if I set a to low value on my tri config (around 1120 w/ SS ESC) and do a semi-hard bank or pull up on the AIL/PIT stick, it's almost like the motors cut off in flight. It's possible to recover but a bit scary.... If I set it to aprox to 100 less than hover rate, I need to hold it when I arm the ESC's to avoid rotation, but it flies great and does not cut out. I use the SS 25A or Plush 12A ESC's. /Bo |
Remember to calibrate your ESCīs individually to the 125% throttle range |
Latest blog entry: AutoQuad hexacopter with Alexmos...
Back to the drawing board...![]() -Tim |
