Old Jun 01, 2011, 03:51 PM
wapko is offline
Find More Posts by wapko
but thats not soon enough
Denmark, Central Denmark Region, Skive
Joined Apr 2011
my test on the teensy++ was also though a 3.3v regulator and LLC. it can run on 3.3. thx though
wapko is offline Find More Posts by wapko
Old Jun 01, 2011, 03:53 PM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Deleted
jhsa is online now Find More Posts by jhsa
Old Jun 01, 2011, 03:56 PM
wapko is offline
Joined Apr 2011
im using 1preter7. I2C_SPEED is defined at 100000L
Old Jun 01, 2011, 04:05 PM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Hi M4d_D,
Your Kitten is Zapping the quad, they are mischevouse like that, i think you ought to give the kitten to me and that will solve all your problems
whiteturbo is offline Find More Posts by whiteturbo
Old Jun 01, 2011, 04:11 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
Originally Posted by whiteturbo View Post
Hi M4d_D,
i really dont think that the rest of my family will be okay with that
she will be a test pilot on my octo when jussis gyro board arrives
i am not sure if its because of the gyros since the quad is really stable when hovering . i only notice these problems when i try to fly like warthox but since i built that quad just for that purpose it is really getting on my nerves .
i cant afford to change all motor-esc combos but i believe the problem must be there , or in the output of the board ( maybe it differs from what is shown in the gui )
i changed the software from 1.7 back to 1.6 and it became a little better , but still not good enough
M4d_D is offline Find More Posts by M4d_D
Old Jun 01, 2011, 05:02 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Are you getting a lot of flex in the material? If they are flexing or twisting in the arms, this could cause you some problems.
Qrome is offline Find More Posts by Qrome
Old Jun 01, 2011, 05:04 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
not enough to cause these problems
especially since the problem appears just one way , so only if i roll left it rolls slower than it does if i turn right . same is if i nick forward , it slower than nicking backwards ( = front up )
Old Jun 01, 2011, 05:57 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Hey guys, since I upgraded to 1.7 I have not been able to flip my quad. Upon investigation, I found that flipping my quad by hand while attached to the multiwiiconf program showed the quad rotate to nearly 90 degrees and stop, even though my quad was fully inverted and acc reported negative G readings.
Interestingly enough this is the exact result I got when trying to flip the quad. It would not rotate past 90 degrees.
Today witespy and I downloaded a development version and found that the conf program would show the quad rotate a full 360 degrees.
I just wanted to confirm that something was fixed to allow the software to detect an inverted position. From the software it appears so. Can I flip now without fighting the software
Tom
vic20owner is offline Find More Posts by vic20owner
Old Jun 01, 2011, 06:03 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
I've been running 1.7 and can flip my quads with the greatest of east - strange that you cannot. I suspect something else?
crazyj is offline Find More Posts by crazyj
Old Jun 01, 2011, 06:45 PM
pinball is offline
Find More Posts by pinball
USA, AK, Soldotna
Joined Jan 2005
If you have the ACC enabled I believe the software limits the angle of the copter to 45 degrees with an RC rate of 1. I think it is mentioned in the release notes for 1.7
pinball is offline Find More Posts by pinball
Old Jun 01, 2011, 09:05 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
I have ACC, but I turn it off of course before trying to flip. I have tried about 10 times and crashed 5 times trying to flip since upgrading to 1.7.
Strange the the software would only show a 80 degree bank even when inverted and this is what I see when trying to flip.
Old Jun 01, 2011, 11:21 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I flip and roll all the time running 1.7 final release -- no problem on both my Quad and Tricopter. It sounds like you are using the ACC. What is your RC Rate set at?
Old Jun 02, 2011, 05:49 AM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
Sorry to jump in guys but...
It works! Ive had the WM+ in the Tri for a couple of days while I worked on the NC version... it works!
Cant wait to try it but Ive got a dud ESC, new set on order....
Thanks Alex and a heap of others....
Artie in Aus is offline Find More Posts by Artie in Aus
Old Jun 02, 2011, 06:11 AM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
what if someone packed the motors wrong , maybe ive got two 20-50s and two 20-34s on the quad which may result in this behaviour ? do they look any different on the outside ?
i believe that may be the problem because the right motor gets hotter than the left motor but if i give full throttle the quad rolls to the left , so the motor works good ...
what do you think ?
Old Jun 02, 2011, 06:50 AM
EnigmaSoar is offline
Find More Posts by EnigmaSoar
United States, FL, Spring Hill
Joined Apr 2009
what do you think ?
Check the props and make sure the concave side is down on all four props.
enigmasoar
EnigmaSoar is offline Find More Posts by EnigmaSoar
