Old May 29, 2011, 12:26 PM
ferdous7466 is offline
Find More Posts by ferdous7466
ferdous7466's Avatar
Joined Mar 2010
can we make a multiwii bi? will the same multiwii soft be workable?i want to build something similar to osprey V22.
ferdous7466 is offline Find More Posts by ferdous7466
Old May 29, 2011, 12:42 PM
actionplus is offline
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Bi
Think you just change this on the 1.7 firmware. Just remove the // for which format you are flying.
/* The type of multicopter */
//#define GIMBAL
#define BI
//#define TRI
//#define QUADP
//#define QUADX
//#define Y4
//#define Y6
//#define HEX6
//#define HEX6X
//#define FLYING_WING //experimental
actionplus is offline Find More Posts by actionplus
Old May 29, 2011, 01:29 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Alex, I am having problems getting with the Bicopter using Pin 6 to output a PWM signal when using my Arduino Mega 1280. I loaded the sample test sketch Servo Sweep, and it works fine, so I know that the problem is not hardware related.
I also tried changing these values but still noting.
Code:
#define DIGITAL_BI_LEFT_PINMODE    pinMode(6,OUTPUT);
#define DIGITAL_BI_LEFT_HIGH       PORTE |= 1<<6;
#define DIGITAL_BI_LEFT_LOW        PORTE &= ~(1<<6);
Code:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
void setup()
  myservo.attach(6);  // attaches the servo on pin 9 to the servo object
void loop()
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
rimshotcopter is offline Find More Posts by rimshotcopter
Old May 29, 2011, 05:35 PM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
Code:
Code:
// Sweep
#include <Servo.h>
void setup()
void loop()
Hi,
yes, I know there is a bug here.
the right code should be:
Code:
  #define DIGITAL_BI_LEFT_HIGH       PORTH |= 1<<3;
  #define DIGITAL_BI_LEFT_LOW        PORTH &= ~(1<<3);
Alexinparis is offline Find More Posts by Alexinparis
Old May 29, 2011, 05:37 PM
Joined Aug 2009
Originally Posted by Alexinparis View Post
Hi,
Code:
Thank you very VERY Much!!!
Old May 29, 2011, 06:03 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi there
since i had a little accident with my octo i was quite frustrated with it so i built a small quad
its somewhere under the kitten ( she beeps like r2d2 )
its a self made carbon fibre frame with 8" props. now im waiting for the lipos since they are in the customs office
what do you think ?
can someone please tell me how to assemble the programmers multiwii code with the octo option ? i have no clue if i can just program it onto the board ???
M4d_D is offline Find More Posts by M4d_D
Old May 29, 2011, 07:09 PM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Avatar configuration is work well
nVader low wind laps 1 (4 min 7 sec)
eyeinsky1 is offline Find More Posts by eyeinsky1
Old May 29, 2011, 08:57 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Originally Posted by tigar View Post
Hi,
I am using the 1.7 code on a tri witch is very stable. I also install lately a camera mount to stabilize the video. It works ok but in real life the mount introduces a small oscillation. It is not visible but you can notice on the video. I suspect the servos i am using are too fast for this (mini digital metal gear) or there is to much gain on the camera stabilization algorithm. Could any one suggest correct servos for this application and if any changes in the code that might fix this?
Try putting some thin rubber between the camera and the camera mount. It might be some high freq vibrations that are causing the "jello" effect on your video. I know I get it with mine! If you haven't already try balancing your props, it will help reduce any vibration at all. lastly, use nylon geared servos for your camera mount, they tend to have less "slop" in the gears vs. metal geared servos.
http://www.vimeo.com/23444683
Dude that's flying great! I may have to build a bi-copter after all. one question. What is the clicking noise you hear in the video, are you flipping in and out of dual rates or something? The noise seemed odd for such an empty field.
crazyj is offline Find More Posts by crazyj
Old May 29, 2011, 10:00 PM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
That clicking is the camera, if you watch and listen closely, it only happens when zooming in or out
whiteturbo is offline Find More Posts by whiteturbo
Old May 29, 2011, 10:29 PM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
I made a new video today with a different subject
MWC and 3D Foamy Action (2 min 28 sec)
Old May 29, 2011, 10:35 PM
Joined Aug 2009
That was Awesome Jason!
Old May 29, 2011, 10:55 PM
aadamson is offline
Find More Posts by aadamson
United States, GA, Atlanta
Joined Dec 2010
FYI, and just passing along... I'm one of the AeroQuad developers and we are working on some fun stuff over in that side of the world ... However, thats not the reason for my post...
I followed the ball as Jussi put the FFIMU together and I picked up a couple recently... Here is a picture of one on a new pro mini shield that is available from the AQ store...
I know I converted AQ to run on Paris and Warthox boards assuming you build with correct sensor orientation so the signs and orders will come out right so I suspect that this shield would also run MWii, but I've not tried it.
Anyway, this is just a way cool little solution... One we are most likely to play with in a stacked configuration running Attitude Estimation(AHRS), sensor fusion, and GPS ... but for now, it's just gonna fly the regular AQ software as I finish up some new features there.
Thanks Jussi for good stuff!
aadamson is offline Find More Posts by aadamson
Old May 29, 2011, 11:07 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
That looks very nice. Is that a new frame?
Scotth72 is offline Find More Posts by Scotth72
Old May 30, 2011, 12:31 AM
aerorotor is offline
Find More Posts by aerorotor
Joined Oct 2009
I have warthox 2.0 board. If the board has stabilization chip, what part of the sketch code needs to be changed to make sure its active?
aerorotor is offline Find More Posts by aerorotor
Old May 30, 2011, 12:55 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Using a BMA180 do I have to connect it's INT pin to the ProMini's ISR pin as shown in it's data sheet?
If so, which ProMini pin is ISR?
RCvertt is offline Find More Posts by RCvertt
