Old May 28, 2011, 10:26 PM
pinball is offline
Find More Posts by pinball
USA, AK, Soldotna
Joined Jan 2005
Originally Posted by actionplus View Post
Thanks pinball.
Does the "ACC" ever go green with radio on and if the flip the "gear" switch?
Because, when I flip the gear switch on my radio, all the Aux numbers change from 1000 to 2000 but acc does not change to green.
Is this normal?
Perfectly normal in your case. ACC denotes a separate ACC (ADXL, BMA020 etc..) when you flip your gear switch it will turn level mode on or off, hence the ACTIVE part in green
pinball is offline Find More Posts by pinball
Old May 28, 2011, 11:03 PM
actionplus is offline
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Acc
Thanks. Looks like it just me trying to figure out the right numbers for my kind flying. (non aggressive)!
actionplus is offline Find More Posts by actionplus
Old May 28, 2011, 11:12 PM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
No problem.
As far as tuning, it just takes time. I just started using level mode a couple weeks ago. I still don't have it dialed right. I had to turn down the P by 2 or 3 to get rid of oscillations, and now it will hover level (after trimming hover mode) but if I fly around a little and let off it will get REALLY close to level but not quite. Seems like it will stay about 5-10 degrees from level after moving around.
But, I'm sure its just in the tweaking. But I will say, make sure you have acro (normal) mode flying nice and stable and well trimmed before trying to mess with stable mode.
Old May 28, 2011, 11:23 PM
Joined Mar 2005
Arrow on gui
The are 3 arrows on the gui(right side) pitch and roll. When does the arrow in the black circle move? Mine never moves.
Old May 28, 2011, 11:56 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
That one is for the MAG I think So if you don`t have a mag installed then there will not be any movement for the arrow in the black circle.
culexus is offline Find More Posts by culexus
Old May 29, 2011, 12:02 AM
Joined Mar 2005
Mag
Oh, okay.
Old May 29, 2011, 12:16 AM
bigbear_fin is offline
Find More Posts by bigbear_fin
Joined May 2009
Thanks for everyone who helped. I ordered new arduino.
bigbear_fin is offline Find More Posts by bigbear_fin
Old May 29, 2011, 12:40 AM
rdbell is offline
Find More Posts by rdbell
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Here are a couple shots of mine. Should be done within the next few days. 24" from center to motor.
rdbell is offline Find More Posts by rdbell
Old May 29, 2011, 04:34 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
5. When the Gaui hit the ground from hovering, the gaui jumps back up (bounce) then lands. Guess due to gyro setting? Anyway to get a soft landing instead of this bounce to land?
In my case it is due to pilot's hands I guess..
jhsa is online now Find More Posts by jhsa
Old May 29, 2011, 05:43 AM
Cid156 is online now
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
Originally Posted by wapko View Post
hi guys.
i'm trying to build a quadxcopter, and i am having some problems.
its made with alu bar, 15mm x 15mm x 1mm. smallest i could get my hands on.
center pieces are 1.5mm alu plate.
motors are 21cm from center. 42cm m2m ?
i use these motors. turnigy l2205-1350kv https://www.hobbyking.com/hobbycity/...dProduct=14739 1 of them has a little more play on the bearings than the others.
plush 18a esc's
apc 8x3.8 SF props, that are as balanced as a noob can get them. i dont have proper balancing tools.
lipo 2650mah, 3s turnigy nano-tech, 35c https://www.hobbyking.com/hobbycity/...dProduct=11946
the board is a diy arduino(328). im using a wm+ clone, dampened with some nice soft rubber standoffs(hard to source the sticky rubber foam, have some underway from HK).
HK t6b tx/rx.
electronics seem to communicate/work fine. roll,pitch, yaw and that is connected correctly. i have however joined all the bec's of my esc's. i've later read that this is bad practice. but have yet to find an explanantion as to why.
my problem is oscillations. BAD ones. i have yet to take off. its just not stable in any way. it really starts to wobble right before it looks like it wants to lift off. if i hold it in my hand and give throttle it wobbles ALOT.
I'm using default PID values, and haven't tried changing them.
now before i throw more money away on a newbies ignorant assumptions. does anyone have any suggestions as to why I'm having so much trouble.
I dont want to go bigger in size to get more stablility.
i measured my lipo and its 12.4v. is this normal?
my lipo guard beeps when i throttle up. is this normal ?
my own thoughts
  • get a proper original wm+, mount it with the sticky rubber foam.
  • not enough torque on the higher kv motors ? too high kv?.
  • maybe wrong motors for this application. im thinking keda 20-50s instead?
  • is it too heavy? 760grams including lipo.
  • loose the alu frame. i like jakubs fiberglass quadframe. will this reduce vibrations from motors getting to the controller. (keda 20-50s okay on this ?)
any suggestions will be greatly appreciated
sorry for the noobish rantings. this is my first adventure in RC. and i had to choose a quad :P
i also have a nk clone on this. but not using it atm. its an unusable unit. it does this thing where it goes into some "powersave mode" or something and stops sending data if you hold it steady for a little while. then you kinda have to yank it to get it to send new data. but this is an issue for later, when i have more stable gyro only flight.
Hello,
I am not sure I have all understood.
But if the quad do not want to take off but want to do a flip on the right or left, It is maybe the same problem that I had. I solved it by increasing a lot the pid value
P=11
I= stay the same
D=20
The lipoguard should not beep except if the lipo is empty... Your lipo should handle a lot of current. Maybe the size of the prop who is too big for the motor...but for me it seems that the motor can handle an even bigger prop...
Cid156 is online now Find More Posts by Cid156
Old May 29, 2011, 05:52 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Just a thought...
Are you sure that the gyros are correcting in the right directions?
Also, some people reported bad results with clones. That is why i went for an original WMP. And I'm very happy with it...
Old May 29, 2011, 06:22 AM
GrootWitBaas is offline
Find More Posts by GrootWitBaas
I don't speak German ....Yet !
GrootWitBaas's Avatar
Germany, Baden-Württemberg, Weissach im Tal
Joined Dec 2010
4 bec's can give problems because they may not all be 100% the same voltage and wil work against each other. Use only one, it has more power than needed. Also where is your centre of gravity and your sensors in relation of COG. PID is the next step to stabelize.
GrootWitBaas is offline Find More Posts by GrootWitBaas
Old May 29, 2011, 08:15 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Linear BEC's should be OK (I have not had problems)
generally they "Load Share" well
Switching BEC's in parallel however may well have problems
due to the electrical noise and method of operation
Reflex1 is offline Find More Posts by Reflex1
Old May 29, 2011, 08:39 AM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
Hi,
I am using the 1.7 code on a tri witch is very stable. I also install lately a camera mount to stabilize the video. It works ok but in real life the mount introduces a small oscillation. It is not visible but you can notice on the video. I suspect the servos i am using are too fast for this (mini digital metal gear) or there is to much gain on the camera stabilization algorithm. Could any one suggest correct servos for this application and if any changes in the code that might fix this?
tigar is offline Find More Posts by tigar
Old May 29, 2011, 11:08 AM
Joined Mar 2005
Pilot Hands
Yeah, I am thinking so. The WiiGaui seems to be veryy touch with the throttle stick. A little movement on the throttle stick gets it going up or down. A smallest change on my stick makes a difference in it.
Might need to look at the expo on the throttle and see if that helps.
