Old Jun 15, 2010, 09:04 PM
LoneRanger is offline
Find More Posts by LoneRanger
Ocala, Fl
Joined Jan 2002
Build Log
Dumas 17.5" F4F Wildcat
seen several models converted in this size frame just no F4F, specificaly not a Dumas model. Doing it agin I would build differently and I could save some weight for sure. I am wondering what power system and servos to use?
Thinking the Hobby King AP03 or the AP05(I think AP05 would be more than adequate for this plane but would let me upgrade to another airframe in the future?) No retracts, just a belly lander- Ail, Ele, Throt.
thoughts on servos? the falcon microservos look pretty nice~
everything is framed up and covering has started.
http://sphotos.ak.fbcdn.net/hphotos-...8_652341_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1553850_n.jpg
LoneRanger is offline Find More Posts by LoneRanger
Last edited by LoneRanger; Jun 28, 2010 at 01:02 PM. Reason: updated title to "Build Log"
Old Jun 16, 2010, 02:39 AM
Truckerboy is offline
Find More Posts by Truckerboy
Joined Oct 2009
That looks really, really good! I think there is one major issue on the wing strength though. You should really continue both of the top spars so they connect in the center part of the wing. Too much up elevator would cause rib no 2 to fail, resulting in a crash. I've attached a picture so you can see what I mean. This is a simple mod that would add almost no weight at all but it could mean life or death of this model .
Well, as for gear, I think maybe a spektrum brick would do fine? Or a light receiver with small linear servos.
Truckerboy is offline Find More Posts by Truckerboy
Old Jun 16, 2010, 09:21 AM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Truckerboy,
Is that a dowel in there? If it is, do you think that he still needs the center spars?
-PC49
PiperCub49 is offline Find More Posts by PiperCub49
Old Jun 16, 2010, 09:32 AM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
Originally Posted by PiperCub49 View Post
Truckerboy,
-PC49
Yes, one should tie the two wing together as Truckerboy shows (spar to spar). Not spar rib dowel rib spar. The question I'd ask is why one would use the dowel?
Konrad is offline Find More Posts by Konrad
Old Jun 16, 2010, 09:41 AM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
I'm sure you've got other ideas, but it would function the same as the so-called "cabin spreaders" do in high wing airplanes. I don't think that you would need it though since the airframe takes that stress when the wing is installed in the fuselage.
Old Jun 16, 2010, 10:10 AM
Konrad is offline
Everett Wa.
Joined Jun 2001
No, these center spars are for flight loads. The "cabin spreaders" are for crash loads. These are same loads for high, mid and low winged aircraft.
Old Jun 16, 2010, 10:13 AM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
So the cabin spreaders don't work in compression the same way that the center spars do?
Old Jun 16, 2010, 10:24 AM
Konrad is offline
Everett Wa.
Joined Jun 2001
Yes, they do work in compression. It is just that they work 90 to the flight loads
This is a good discussion for your thread.
Old Jun 16, 2010, 08:23 PM
Ocala, Fl
Joined Jan 2002
Thanks for posting the pic, that is not a dowel it is a 1/8th x 1/16th strip. I am going to connect the wings as you showed! I was waiting on servos and what not as it makes it easier to install w/o thoes in the way! I would like to use my Hitec flash 4 radio (I havent converted to the new shifting radios yet) and I would like to use the smallest regular servos I can find-
lots of talk about spars and spreaders but not so much on motor, servos, and recievers? lol if a brick would work I would deffinaetly entertain using it- again thanks for the help!
L.R.
p.s. the whole thing is covered now and awaiting electrics. I sure wish I had a digital scale, anybody know where to get a decent one w/o breaking the bank?
Old Jun 16, 2010, 08:46 PM
Ocala, Fl
Joined Jan 2002
http://sphotos.ak.fbcdn.net/hphotos-..._5989171_n.jpg
sorry I am not too good at posting images!
Old Jun 16, 2010, 09:10 PM
Roy!! is offline
Find More Posts by Roy!!
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
lol lil bit off topic but i saw ur home town hehe where u live in ocala
Roy!! is offline Find More Posts by Roy!!
Old Jun 16, 2010, 09:30 PM
Ocala, Fl
Joined Jan 2002
I grew up in Belleview / Dunnellon. My wife and I built a house north of town in Williston now.
L.R.
Old Jun 16, 2010, 11:38 PM
Joined Oct 2009
Looks nice! Are you going to paint it too?
I think the hobbyking linear servos (the old ones with a standard connector) would work fine:
http://www.hobbycity.com/hobbyking/s....1g_%28Left%29
If you want micro JST connector then look at this:
http://www.hobbycity.com/hobbyking/s...ght_%28Left%29
I've got a bunch of the 1.7g servos and they seem to work good at 5v, even though they are rated for 1s operation. Beware though, as they are mechanically of mixed quality. I bought a bunch of them so I could sort out the best ones to use in planes and the worst ones to be used as spare parts.
Old Jun 17, 2010, 08:17 AM
Ocala, Fl
Joined Jan 2002
honestly I could only use one linear servo for the elevator the ailerons are setup to be a conventional push pull set up so I need a small servo. It would seem that quality is a huge issue with things from HK, so I dont know if I am real comfortable ordering just one servo to get it and find out it isnt going to cut it. Allthough they are cheap, price isnt my top concern. I'll gladly spend 30 bucks on a good servo and know I am getting some quality. I have read that thier AP03 and AP05 motors are great, which is why I had them at the top of my list.
now, back to motor, battery, and servo suggestions?
L.R.
Old Jun 17, 2010, 09:14 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Just use the [ img ] tag and the pictures post fine (Edit to replace url with img)
UNGN is offline Find More Posts by UNGN
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion Dumas 17.5 Tigermoth conversion...Input? 56S Scratchbuilt Indoor and Micro Models 16 Dec 24, 2009 09:06 PM
Discussion Dumas Tiger Moth 17.5" flying_violin Free Flight 7 Sep 21, 2009 10:06 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
Build Log Dumas F4F wildcat Citabria86614 Free Flight 37 Oct 11, 2007 08:25 PM
