Old Jun 15, 2010, 08:10 PM
dlt2859 is offline
Find More Posts by dlt2859
Go Fly Something!!
dlt2859's Avatar
USA, VA, Charlottesville
Joined Jan 2009
Charge Rate for a 12v 7Ah Battery
Gang,
What is the max Ah charge rate for a Hanger 9 12V 7Ah battery?
Don
dlt2859 is offline Find More Posts by dlt2859
Old Jun 15, 2010, 08:19 PM
Gary Cee is offline
Find More Posts by Gary Cee
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
A average .7 (700 mA) amp rate for 10 to 12 hours should be fairly safe. There are automatic chargers that work well for that size battery. You may use a faster rate but the rate given is pretty common. Lead-acid type cells generally charge satisfactorily with a fixed voltage source. The initial current may sart out quite high then taper off as the battery voltage reaches equilibrium with the charge voltage.
Lead acid cell should not become deeply discharged and should be charged as soon as possible after discharge. There is no harm in topping off after use even if not fully discharged. A little research and experience will allow voltage readings to help you determine the actual state of charge.
Gary Cee is offline Find More Posts by Gary Cee
Old Jun 15, 2010, 09:17 PM
dlt2859 is offline
Go Fly Something!!
dlt2859's Avatar
Joined Jan 2009
Gary,
Thanks for the quick response!
Don
Old Jun 15, 2010, 09:38 PM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
Also, there are many good chargers on the market now to charge sealed AGM batteries. You might try looking for one at a good motorcycle shop. The good ones are "intelligent" and do things to keep your battery in top shape and prevent or reverse sulphation, etc. and can be connected indefinitely without harm so you're battery is always ready to go.
groundfx is offline Find More Posts by groundfx
Old Jun 15, 2010, 09:50 PM
THEDUDE is offline
Find More Posts by THEDUDE
TOLEDO,OH, USA
Joined Dec 2000
I use the Battery Tender Jr for my SLA flight box battery.
http://batterytender.com/battery-ten...-at-0-75a.html
THEDUDE is offline Find More Posts by THEDUDE
Old Jun 16, 2010, 08:55 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Been using the same Battery Tender Jr to maintain my 2 starter box cells. Changing to a float type charger has more than doubled the life I had been getting from these type cells.
Duster_360 is offline Find More Posts by Duster_360
Old Jun 17, 2010, 01:46 AM
whitedg is offline
Find More Posts by whitedg
Australia, NSW, Rydalmere
Joined Feb 2010
Rule of thumb is to charge SLA batteries between 1/10 of their capacity to 1/4, so for this battery between 700ma to 1.75A.
Normally the charge rate and time is printed on the battery, maybe under a sticker?
whitedg is offline Find More Posts by whitedg
Old Aug 24, 2010, 02:17 AM
jcinauz is offline
Find More Posts by jcinauz
Joined Jan 2010
Originally Posted by dlt2859 View Post
Gang,
Don
Don as a rule 1/10 of the batterys capacity is the rule of thumb eg: 7Ah or 7000mah = 700mah but 1amp is ok just dont leave on for too long.
I always check the Battery for warmth as if it's making heat then it's charging too fast or for too long OK..cheers
jcinauz is offline Find More Posts by jcinauz
Old Aug 24, 2010, 06:38 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Most of the lipo chargers today will charge just about anything. I use the Accucell 6 with no problems. PB setting is for lead acid. It charges it properly and shuts off when done.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Aug 25, 2010, 09:53 AM
dlt2859 is offline
Go Fly Something!!
dlt2859's Avatar
Joined Jan 2009
That's just the conformation I was looking for!!
Don
Old Aug 25, 2010, 01:37 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Especially on sealed (no maintenance ) cells, limit the charge rate to 0.1C else you risk ruining the battery. Be sure to use a voltage limited charger (13.7 volts for a 12 volt battery) as any overcharge is very detrimental even if limited to 0.1C.
Rodney is offline Find More Posts by Rodney
Old Aug 25, 2010, 02:13 PM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
I have a bunch of SLA batteries on my bench, including several 7 ah batteries, and they all say to charge at an initial rate of .3 C or less, so 2.1 amps or less for a 7 ah battery.
They also say to charge to 13.5-13.8 volts for standby use, and 14-15 volts for cycle use.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Aug 26, 2010, 11:42 PM
groundfx is offline
Delta, BC, Canada
Joined Oct 2003
You're thinking of the old "gell cell" batteries. They were very delicate.
The new sealed lead acid batteries are Absorbed Glass
Mat (AGM). AGM's use the same voltage points as lead acid batteries, thus any good lead acid charger with a lowish (motorcycle) rate should work fine.
For example, here's the datasheet for a Yuasa NP7-12
http://datasheet.octopart.com/NP7-12...heet-47645.pdf
They're okay with up to 1.75A... i.e. 0.25C.
Other batteries will have different specs... I've seen some with even higher ratings. YMMV.
Old Aug 27, 2010, 04:41 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There are AGM batteries which can be charged at 3C but here is the problem / issue here in my opinion.
OP wanted to know a safe charge rate for a Pb and the correct generic answrer IMO is 1/10C as this is indeed safe for any Pb I am aware of.
This is one of those two poster threads. OP asked question in post #1 and first respomder ,post #2 provided excellent / accuract answer.
Old Aug 27, 2010, 04:48 AM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
wish I could delete.
4*60 is offline Find More Posts by 4*60
Discussion Battery cells replaced, charge rate is very low Tractable Batteries and Chargers 1 Jan 22, 2010 03:34 AM
Sold Hobbico Torqmaster 180 and 12V 7ah field box battery Whopper Chopper Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jan 26, 2009 08:43 PM
Discussion A123 substitute for 12v-7ah Sealed Lead Acid kenhiraihnl Batteries and Chargers 7 Dec 30, 2008 12:21 PM
Question how many times will a 7ah battery charge a 1850mah pcook Batteries and Chargers 10 Jun 29, 2003 09:40 PM
