Old Jul 13, 2010, 12:03 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Originally Posted by NitroCharged View Post
Time for me to get my plug organised I think Bret.
Sounds like a great idea. I hope this thread has documented enough of the process for you. If not please feel free to ask any additional questions you may have.
pdawg is online now Find More Posts by pdawg
Old Jul 13, 2010, 06:40 AM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I still don;t get how you get the glass on so fast. Yesterday I did my 3 coats of surface coat and on the 3rd coat i immediately laid 3oz glass on to eliminate air bubbles. Then After that tacked up I did 2 layers of 5oz. That's all I could get done. I am now doing 5 layers of 10 oz. I have to let them sit an hour in between each layer because they shift too much if I do more than one at a time. Even when doing the 5oz I get air bubbles if I do 2 layers at once.
How many you doing at a time? Before letting the epoxy cure for a bit?
Brian
Originally Posted by pdawg View Post
I haven't been motivated like this on a molded project for some time. Its partly because I've had few opportunities to build over the last 2 years so I ain't taking this time for granted. The thought of flying a micro molded sport jet with great performance also keeps me going!
Tumbler is offline Find More Posts by Tumbler
Old Jul 13, 2010, 07:08 AM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Brian
Brian,
Once the glassing process is started I don't stop, or intentionally allow the epoxy to get tacky till its done. I believe the fact that my lay-up schedule (4 layers of: 2, 4, 6, and 10oz) is more gradual than yours (a layer of 3oz, 2 layers of 5oz, and 5 layers of 10 oz) in building up thickness might explain why I am continually able to lay down glass. Don't get me wrong, bubbles do occur but usually I am able to work them out and keep moving forward. I never do more than one layer at a time. If the glass is too thick for the contour then your right that the only way to get it to stay put is to wait till the epoxy is tacky....I personally hate waiting. I would suggest copying my lay-up schedule or something close to it. It might be more layers but it makes the whole process much more enjoyable. From the time the last gel coat layer was ready to go, I spent between 4-5 hours laying on glass.
Old Jul 13, 2010, 07:33 AM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
Well if you look at my canopy hatch, the bottom edge is a 90 degree bend and the front and rear lip are also 90 degrees. The top of the canopy is easy. Its the 90 degree corners giving me trouble.
Brian,
Old Jul 13, 2010, 09:35 AM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Yes, and its the sharpness of that 90 degree edge. If it was a rounded 90 degree corner an inch in diameter, the 10 oz glass would have no problem conforming.
Old Jul 13, 2010, 09:57 AM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
good point! I'll remember that when i do the fuse. It sucks cause i have to wait for it to get taky and push it it together or it pulls away from the edge.
Brian
Old Jul 13, 2010, 11:17 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
whos panther is that? i assume thats a yellow P-38? i also see a P-51, FW-190, corsair, GEE BEE(you still ahve that!!!!! that thing flew sweet!) and a number of other sweet builds!
corsair nut is offline Find More Posts by corsair nut
Old Jul 13, 2010, 11:30 AM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
CN,
The panther is a joint project. Several years ago we made the plug based off of Ziroli plans. The plan was to go turbine power but now it could also be EDF. Its a big airframe.
Old Jul 13, 2010, 12:31 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
How long you going to wait before pulling the plug out of the mold?
Old Jul 13, 2010, 01:51 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
The completed Electrolyte fuselage mold
Here she is. The plug and mold came apart fine. There was a little paint that stuck to the mold but it came off easily with some acetone. I also cleaned up the wingsaddle area of the mold. Later today I'll polish and wax the mold to make her shiny again. I'm very happy that my efforts on the plug have now been saved in the form of this mold. The mold turned out as planned so its time to relax, have a beer, and move on to the next stage of this project.
Old Jul 13, 2010, 02:57 PM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
Hi Bret,
Its been a while since I`ve heard from you. At the moment I`m sitting in a tent at the top of the Greenland Icecap. I`m flying UAV`s at an American base called Summit Camp.
I just wanted to say that this is a great project (as all of your projects). I whish you good luck with the prototype. Btw. I`ve been thinking about a similar project and have a small A4 Skyhawk for a 50mm fan on the drawing board.
Best regards.
Kjell.
SpeedMaster is offline Find More Posts by SpeedMaster
Old Jul 13, 2010, 03:10 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
What do you do if it was the first half of the mold and the plug needed a good perpendicular heave to get out Bret?
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 13, 2010, 03:52 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
Looks good man! I assume you had to pull it straight out because of the wing and stab saddles right? I will have the same issue with mine.
Old Jul 13, 2010, 03:54 PM
tehachapi, CA
Joined Jan 2006
lay one up an! sweeeeet!
zroli panther, now that is a nice flying model.would love to see that get done!
Old Jul 13, 2010, 04:48 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Really fine looking mold.
Len
LenBFP is offline Find More Posts by LenBFP
Discussion Bvm Electra Jet @ Heart Of Ohio Jet Scramble kevin Electric Ducted Fan Jet Talk 42 Jan 04, 2008 06:30 PM
We have Electra Jet and Pico Jet new In box mmm208 Aircraft - Electric - Airplanes (FS/W) 0 Aug 23, 2002 10:13 AM
WTB or WTT for a Twin Jet, Pico Jet, Electra Jet darenm Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2002 09:46 AM
Electra Jet or Typsy - Anyone got a Electra JET VIDEO CLIP? rojoyinc Parkflyers 3 Apr 21, 2002 11:56 AM
