Old Jul 11, 2010, 11:22 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Tumbler,
Yeah we both had long days! I would consider 80 oz. of fiberglass on this size mold a little overkill but not by much. I was taught to make production molds so I generally produce molds that could withstand 500 or so pulls. I don't plan to make that many but it hardly takes any time to put on a couple more layers of 10 oz cloth to beef up the mold... so I do it. 3-4 times the thickness of your part should work however...its really preference at that point and I don't want a flimsy mold that I have to be gentle with.
As you experienced the heavier layers of cloth will resist sharp angles so the layup schedule needs to be designed to gradually build up the radius around those curves. I can't stand having to babysit the fiberglass so IMO I would much rather be conservative and do 2 light layers of cloth rather than one heavy one that might need to babysitting. The Electrolyte had plenty of sharp bends and the early layers required the most effort. As the layers piled up it actually got easier. In your case I would consider more layers of light cloth around the edges giving you trouble prior to going to the heavier cloth.
Responding to your question, the use of bondo on the splitter box gave such a tight fit that I didn't feel it was neccessary to use clay or spackle afterwards. Whatever small gap remained was filled in by the wax and PVA.
NC,
I was taught to use the graphite powder not primarily for strength but to make the epoxy black so you have a color contrast which helps for laying up the fuselgae. The strength should be provided by the fiberglass and not the gel coat. Actually the graphite powder increases the chances for chipping of the mold so I usually put in just enough powder to make the epoxy black.
CN,
yeah I can't wait to see the first fuselage out of the mold also. Its always an exciting day...like the birth of a child. BTW, the cost of making a mold is not cheap but if its something worth molding then it could easily pay for itself if neccessary. I use (and have always used) west systems epoxy. I personally love its convenience with the ketchup/mustard pumps which give the perfect epoxy/hardener ratio everytime. There are better and more expensive epoxies out there but for my level of precision, west systems has worked great.
pdawg is online now Find More Posts by pdawg
Old Jul 11, 2010, 12:07 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Sweet!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jul 11, 2010, 12:09 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
My epoxy did have pumps too actually.
Brian
Tumbler is online now Find More Posts by Tumbler
Old Jul 11, 2010, 01:02 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Hi Bret,
Beautiful work!
Do you use a vacuum to degas the gel coat? I always get small bubbles in it if I don’t degas or spray the gel coat.
How does black compare to orange for the mold color, I use orange dye but may try the graphite if black's better.
mcross is offline Find More Posts by mcross
Old Jul 11, 2010, 01:15 PM
Tumbler's Avatar
Joined Feb 2003
Bret,
Check it out...I just took my parting board off my hatch mold. Time to it allll over again on the other side!
Brian
Old Jul 11, 2010, 01:25 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
looking good guys!
corsair nut is online now Find More Posts by corsair nut
Old Jul 11, 2010, 02:16 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I thought I read thet the graphite powder also helps with making the mold slippery, so the parts come off even easier after layup? That would make it, and the black color way better than dye. Is this true?
Fred
Old Jul 12, 2010, 02:07 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Originally Posted by mcross View Post
Hi Bret,
Beautiful work!
Do you use a vacuum to degas the gel coat? I always get small bubbles in it if I don?t degas or spray the gel coat.
Mike,
welcome to this thread! You are largely responsible for this project. Before the blowdart I never believed these micro edf's could produce enough performance to satisfy my flying style. Your power system made me a believer! To answer your question, degasing the gel coat is a good technique. I have used it but sometimes the gelcoat looks the same with or without. Its not uncommon to get some microscopic bubbles in the getcoat but by the time the mold has been well waxed they don't effect the molded part. To be honest I do no not strive for exact perfection but do try to make the mold as nice as possible with the techniques I've been taught. This attitude keeps this process fun for me. Taking it too seriously takes the fun away.
I would definitely give the black gel coat a try. It is really effective at revealing airbubbles while producing parts. I have not used other colors but I believe it would be hard to beat a black background.
Old Jul 12, 2010, 02:10 PM
Tumbler's Avatar
Joined Feb 2003
Dude, I left my gelcoat out in the sun for a bit to cure and it bubbled the PVA underneath! Luckily its in an area I will be cutting away from the mold anyway. So ummm....don't do that with black gelcoat!
Brian
Originally Posted by pdawg View Post
Mike,
welcome to this thread! You are largely responsible for this project. Before the blowdart I never believed these micro edf's could produce enough performance to satisfy my flying style. Your power system made me a believer! To answer your question, degasing the gel coat is a good technique. I have used it but sometimes the gelcoat looks the same with or without. Its not uncommon to get some microscopic bubbles in the getcoat but by the time the mold has been well waxed they don't effect the moldec part. To be honest I do no not strive for exact perfection but do try to make the mold as nice as possible with the techniques I've been taught. This attitude keeps this process fun for me. Taking it too seriously takes the fun away.
y
Old Jul 12, 2010, 03:50 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Brian,
Yeah heat can be tricky! One of the reasons for doing 2 thin gel coat layers instead of a single thick one is to limit the heat generated. I've dorked entire molds before by trying to "bake" a part in the mold. The sun is pretty powerful to say the least! Fortunately for you it happen in a non-critical spot. Thats a free lesson .
BTW I'm laying up the otherside of the mold today. The 2nd gel coat layer is setting up as we speak.
Old Jul 12, 2010, 06:06 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Sounds like you are powering through the lay-up process Bret.
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 12, 2010, 11:07 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
I haven't been motivated like this on a molded project for some time. Its partly because I've had few opportunities to build over the last 2 years so I ain't taking this time for granted. The thought of flying a micro molded sport jet with great performance also keeps me going!
Old Jul 12, 2010, 11:19 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Is that an old Wattage Cub I see, and a glass of Merlot?
Looking good, I feel your excitement too! Very cool thread and I am enjoying it so. Thanks.
Fred
Old Jul 12, 2010, 11:37 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Fred
Nice work Fred! Yep on the cub and the wine. There was some left over from dinner (which i missed because the mold wasn't finished). Afterwards though I felt the wine was appropriate so I took a glass and took a few pics of my labor.
A flying buddy sold his house so some of his projects are temporarily being stored in my shed including his Cub.
Old Jul 12, 2010, 11:43 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Time for me to get my plug organised I think Bret.
Discussion Bvm Electra Jet @ Heart Of Ohio Jet Scramble kevin Electric Ducted Fan Jet Talk 42 Jan 04, 2008 06:30 PM
We have Electra Jet and Pico Jet new In box mmm208 Aircraft - Electric - Airplanes (FS/W) 0 Aug 23, 2002 10:13 AM
WTB or WTT for a Twin Jet, Pico Jet, Electra Jet darenm Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2002 09:46 AM
Electra Jet or Typsy - Anyone got a Electra JET VIDEO CLIP? rojoyinc Parkflyers 3 Apr 21, 2002 11:56 AM
