Old Jan 15, 2011, 12:35 PM
GGRN is offline
Find More Posts by GGRN
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
On this side, i've finished the EDF 40 F8 prototype. Just have to do the paintjob... and wait for the AEO EDF 40 and 8 bladed rotors...
GGRN is offline Find More Posts by GGRN
Old Jan 16, 2011, 02:19 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Brent, what's the weight of the KMS motor, and what about the amps it needs ?
Old Jan 16, 2011, 04:56 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
its about 2.5oz...so kinda heavy. its also 21mm so it wont fit in a stock gws 20mm mount......its all custom baby easist thing to do, would be to find a 5100-5500 kv 20mm inrunner........ on the cut down wattage, its 23A on 4s, about 350W.
corsair nut is online now Find More Posts by corsair nut
Old Jan 16, 2011, 05:19 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Thanks !!!!!!!!
Old Jan 16, 2011, 05:45 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
OK - 850's arrived this morning and of course - I jammed them straight into the Electrolyte.
Still really nose heavy, so we're going to have to add tail weight.
Based on CN's weights, my fan is much lighter so I would've needed to install it much further back. A heads up for V2.
Now to make sure they haven't been sitting on the shelf too long as MT got one and it doesn't seem to be doing well on cycle tests.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 16, 2011, 05:50 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
That 2S Hyperion of mine is more like a 650mah! I thought my charger might be faulty, but I got a new one and the readings are the same. Got some new nano-tech 1000mah 2S packs. On the first cycle they produced more than 1000mah
Good luck with the flight!
MegaTesla is offline Find More Posts by MegaTesla
Old Jan 16, 2011, 05:54 PM
tehachapi, CA
Joined Jan 2006
dont skinmp on cg..add weight if you have to. like i said before, mine is probably on the nose heavy side of the cg already.
Old Jan 22, 2011, 06:44 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
I wonder what's happening in that closet in Miami...
Old Jan 22, 2011, 08:10 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I went to fly the Electrolyte yesterday and one of the motor connectors had come out during my 'let's ram the lipo back in the fuse' process. She's in a nasty place so I have to feed a hook wire to get the lead to the side so I can plug it back in...
I was so consumed with other little things in the hobby room, I forgot to hook the lead back up for this mornings outing.... Doh!!
So close....
The 850 lipo's I would class as 750mah's if you're lucky. Mine didn't perform as I would have expected either (flying them in the micro A-10) so back to the 1000mah's for now.
Old Jan 23, 2011, 08:11 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Hi MT,
Not much construction has happened in that closet for the last few weeks. To be honest I've been enjoying the assets that Miami has to offer. I'm only here for a limited time so I'm trying to soak up as much of that latin culture as possible.... On the other hand I've been working with the help of some friends to bring more press to this niche area of the hobby. In a few months non-rcgroupers will have the opportunity to read about the advancements that we see occuring in this forum .
pdawg is offline Find More Posts by pdawg
Old Jan 28, 2011, 10:09 AM
tehachapi, CA
Joined Jan 2006
cmon dave...you gunna fly this thing or not!
Old Jan 29, 2011, 04:48 AM
tehachapi, CA
Joined Jan 2006
well since dave is slackin big time.....i did some mods to the "E"......i figured....if 200W is good.....why not double it?????? ill be flying it on 400W tomorrow. id like to see a solid 115 mph. that reminds me...i better bring my camera!!!! should be a little easier to hand launch now....with over 1:1 thrust...
Old Jan 29, 2011, 02:13 PM
tehachapi, CA
Joined Jan 2006
http://www.rcgroups.com/forums/showt...0#post17249789
375W of fury! cant wait to see what don has to say about the speed....id have to guess in the 110 range. its a damn rocket!!!!! the hand launch still sucks. i need a small bungee. i had about 4 bad hand launches (lack of breeze) so the nose is just about beyond repair...i just taped it together to get it in the air for these videos...
this is how i crack off the 2011 year speed run trials!!!!!!!!
cmon dave.....
Old Jan 29, 2011, 03:10 PM
tehachapi, CA
Joined Jan 2006
few pics of the new power plant. its accualy from my T-33 which suffered a nasty bust up from a bad hand launch...go figure eh? anyhow, here it is, but instead of the modded wattage blade i had on the T-33(thinner chord blades) i took the stock cut down blade from the old electrolyte fan and installed it on the kms motor. the thinned blade was 350W, this one is close to 400W. crazy stuff. sorry about the pics...this is as good as my camera does...
this fan runs crazy smooth. and was real fast to put together. i spent hours and hours trying to get that outrunner i had to run decent...and it wasnt that smooth. one thing i noticed, was that the old setup had all kinds of caked on tryed grass inside the shroud from aborted hand launches and sucking up grass on landings. certainly wasnt helping my speed on previous setup, perhaps this is why did didnt gain much speed when i changed to better packs/esc. all i know is....it gained performance now..big time. i wanted to use the 8 blade that dave sent me...but after i mounted that fan in a shroud, the watts went way down, only about 260. so, i need to get a hotter motor for that one. cant justify the weight of the kms motor for only 260W. 400....now that i can justify. so looks like the 8 blade needs a 6000kv or so to be in the 400W range on 4s....
Old Jan 29, 2011, 03:15 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
Beginning of the month in the 2010 speed thread:
Originally Posted by mcross View Post
I'm shocked nobody went over 100mph with a 40mm.
I predict it will happen before the end of the month
Congratz Brent!!
8 R-L
8051Hz
6012Hz
110.5mph
68837rpm
9 L-R
8056Hz
5951Hz
114.6mph
68453rpm
10 R-L
8050Hz
6013Hz
110.4mph
68840rpm
11 R-L
8349Hz
6029Hz
123.0mph //double checked, all good!
70018rpm
12 R-L
8217Hz
5997Hz
119.1mph
69336rpm
Discussion Bvm Electra Jet @ Heart Of Ohio Jet Scramble kevin Electric Ducted Fan Jet Talk 42 Jan 04, 2008 06:30 PM
We have Electra Jet and Pico Jet new In box mmm208 Aircraft - Electric - Airplanes (FS/W) 0 Aug 23, 2002 10:13 AM
WTB or WTT for a Twin Jet, Pico Jet, Electra Jet darenm Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2002 09:46 AM
Electra Jet or Typsy - Anyone got a Electra JET VIDEO CLIP? rojoyinc Parkflyers 3 Apr 21, 2002 11:56 AM
