Old Jun 20, 2010, 09:23 PM
Sherlock is online now
Find More Posts by Sherlock
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Nice build! How much CA does it take to cover a model that size?
Sherlock is online now Find More Posts by Sherlock
Old Jun 20, 2010, 10:13 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
primer and red stuff
The Electrolyte plug is now primered . I spent a few hours today finishing up the glass work and getting some primer on it. In total it took less than a medium sized bottle of thin zap to glass this entire fuse. After sanding the fuse with some 220 and then 320 paper I put on the first coat of primer. After letting it dry I put on the Bondo Glazing Putty which we call "red stuff". This stuff is awesome becuase it dries fast and sands really well. My girlfriend says the red stuff smells and probably causes cancer. She's probably right but then again what doesn't cause cancer these days. Can't wait to sand off the red stuff in the morning.
CN,
I'll be be back in town after the 4th of July. I don't plan to outsource any more of my molds. It was a good experience but was more effort than it was worth.
pdawg is offline Find More Posts by pdawg
Old Jun 21, 2010, 12:23 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Wow! Just with the primer on it - it looked so smooth. Hard to believe so many high spots were there once the putty got a good sanding!.
She looks real sharp pdawg.
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 21, 2010, 01:16 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
looks swseet bret! well....are you atleast going to make some for buds! i can do duct plugs whats cool about your plug, is that you can carve your tails/wing from 1/4 balsa, and make them any shape you want(or depron, whichever)
corsair nut is online now Find More Posts by corsair nut
Old Jun 21, 2010, 10:25 AM
danj31 is offline
Find More Posts by danj31
Greenwood Indiana
Joined Jun 2004
Very nice jet, it should be a great flyer. I have one suggestion for the plug, extend the tailcone past the actual end and scribe a line where you will cut the tailcone off. It will make molding easier because there will not be the corner to fit the cloth in, just cut the cloth a little long and make a perfect triim to it after the jet is pulled from the mold.
danj31 is offline Find More Posts by danj31
Old Jun 21, 2010, 11:07 AM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
NC,
It actually did look pretty smooth for a first coat of primer but I initially just red stuff the entire airframe to fill in the weave of the cloth. After that I will selectively red stuff areas that need additional work. THe second coat of primer is already drying
CN,
We can work something out once I get the molds finished. I'm glad you noticed that the fuselage is not restricted to one wing design. One goal was to keep the fuselage sleek yet provide the opportunity to easily test different wing planforms.
Dan,
Thanks for the input! Yes, I already have that in the plans. I actually do this for the backplate on all my prop airframes as well. In the case of the Micro Stinger it was 3 carfully placed nickels lol. The plan is to mold more than one tailcone for the Electrolyte depending on the diameter fan being used.
Old Jun 21, 2010, 03:20 PM
devmonkey is offline
Find More Posts by devmonkey
United Kingdom, England, Surrey
Joined Aug 2002
Originally Posted by pdawg View Post
Fred,
Devmonkey,
Your fuse looks nice and will likely work with todays systems. It was probably a little ahead of its time. What is the fuselage length?
I'll dig out the molds this weekend and measure them, think it was basically the same size as the original nano bandit, maybe a tiny bit longer. I think I struggled to get a layup <20g which seemed rather a lot for the feigao 40mm ~80w setup I used to run. That was a hand layup in glass only (no carbon/kevlar) and without vacuum and peel ply, so could be made lighter and stronger.
Out of interest what is the 40mm power house setup in todays technology?
Cheers, Joe
devmonkey is offline Find More Posts by devmonkey
Old Jun 21, 2010, 03:58 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Cheers, Joe
Check this one out for sure, especially the videos done and check all the performance measuremnts!
http://www.rcgroups.com/forums/showthread.php?t=1246593
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jun 21, 2010, 04:46 PM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
Man that looks very coool looks like a mico bandit
Dark Angel is offline Find More Posts by Dark Angel
Old Jun 21, 2010, 06:48 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
[QUOTE=devmonkey;15370181]I'll dig out the molds this weekend and measure them, think it was basically the same size as the original nano bandit, maybe a tiny bit longer. I think I struggled to get a layup <20g which seemed rather a lot for the feigao 40mm ~80w setup I used to run. That was a hand layup in glass only (no carbon/kevlar) and without vacuum and peel ply, so could be made lighter and stronger.
Freddies on it.
Eric B.
AirX is offline Find More Posts by AirX
Old Jun 22, 2010, 12:50 PM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Subscribing..............great project!
Steve
stegla is offline Find More Posts by stegla
Old Jun 22, 2010, 06:39 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Great to have you along for the ride Stegla! The plug is moving along nicely however today was humid and close to raining so I didn't add another coat of primer. With nothing to do I decided to try to make it look like an F-20 Tigershark. Not sure which looks better but it definitely does give the same fuselage another look.
Old Jun 22, 2010, 07:32 PM
tehachapi, CA
Joined Jan 2006
the F-20 look is nice!!!!!!!!!!!!!!!!
me wanty!!!!!!!!!!!!!!!!!!
Old Jun 22, 2010, 07:45 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
F-20 version would be faster, land quicker, higher wing loading but cool I'm sure. Opens one's eyes to variable perameters on all projects!
Almost rainy? Nebraska is flooding, Arizona is burning, California was given up upon, Oh well, hope you make some progress soon!
Fred
Old Jun 22, 2010, 08:00 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Very nice Pdawg! It's good to see micros moving into the composite era, one jet at a time!
Can't wait to see this flying - and also the moulding process
Odysis is offline Find More Posts by Odysis
Discussion Bvm Electra Jet @ Heart Of Ohio Jet Scramble kevin Electric Ducted Fan Jet Talk 42 Jan 04, 2008 06:30 PM
We have Electra Jet and Pico Jet new In box mmm208 Aircraft - Electric - Airplanes (FS/W) 0 Aug 23, 2002 10:13 AM
WTB or WTT for a Twin Jet, Pico Jet, Electra Jet darenm Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2002 09:46 AM
Electra Jet or Typsy - Anyone got a Electra JET VIDEO CLIP? rojoyinc Parkflyers 3 Apr 21, 2002 11:56 AM
