Old Feb 11, 2013, 04:12 PM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by pdawg View Post
Jack,
Are you also planning to make a straight vertical? According to Rob it as less coupling issues in knife edge....
I haven't thought it through, hmmmm...
Jack
jfetter is offline Find More Posts by jfetter
Old Feb 11, 2013, 07:43 PM
EDF Addicted
MustangAce17's Avatar
Ocala,Florida
Joined Sep 2005
Bret,im goin for 300 watts on a custom cut rotor with a oldie but goodie motor
MustangAce17 is offline Find More Posts by MustangAce17
Old Feb 11, 2013, 08:27 PM
Current project: Electrolyte
pdawg's Avatar
SoCal
Joined Apr 2004
You will be moving for sure! Hope you have good eye sight!
pdawg is offline Find More Posts by pdawg
Old Feb 11, 2013, 08:30 PM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Where can I start looking for fans that will fit, any good sources?
Old Feb 11, 2013, 09:21 PM
pdawg's Avatar
SoCal
Joined Apr 2004
Jack,
For a first time Micro EDF builder the most straight forward high power setup at this time, that is easy to assemble, is to use the 40mm GWS shroud in combination with the 40mm AeoRC 8-blade rotor (and 2mm shaft adapter). That fan unit combined with a neu 705 2y (get the 2mm shaft version) will draw 300 watts and give you 100mph+ out of sight performance. The only mod (which is really easy) is to sand down the perimeter of the bell lip of the GWS shroud for clean ducting.
The custom shrouds I know of in the 40mm class don't fit that rotor without modification. If a custom shroud designed for the AeoRC rotor becomes available I will definitely let you know.
Old Feb 11, 2013, 09:55 PM
United States, VA, Harrisonburg
Joined Mar 2004
What kinda servos and other electronics are we looking at? I am assuming they are all sub micro's?
invertmast is offline Find More Posts by invertmast
Old Feb 11, 2013, 10:07 PM
pdawg's Avatar
SoCal
Joined Apr 2004
The laser cut parts are setup for Dymond 4.7g servos.
Old Feb 11, 2013, 10:20 PM
EDF Addicted
Ocala,Florida
Joined Sep 2005
Well i was able to track that fast Phazer but it was a bit bigger lol, if 300 isnt fast enough ill go to 500 , im sure I could handle it
Old Feb 11, 2013, 10:22 PM
EDF Addicted
Ocala,Florida
Joined Sep 2005
Im gonna work on a cutdown sky angel 50 fan and pair it with a razor 300, should be powerful and light
Old Feb 11, 2013, 10:30 PM
pdawg's Avatar
SoCal
Joined Apr 2004
That is a nice motor Kyle. At 4700kv you'll likely need 4s. For 3s we are in the 7-9k kv range.
Old Feb 11, 2013, 10:35 PM
EDF Addicted
Ocala,Florida
Joined Sep 2005
Bret, i didnt even know the kv so appreciate that, 4s itll be if it needs it, whats the biggest battery youve used/ that will fit?
Old Feb 11, 2013, 10:41 PM
pdawg's Avatar
SoCal
Joined Apr 2004
A 4s 1000 will fit but the CG might an issue with a light motor in the rear and a 4s pack in front. CN was able to make 4s work so its definitely possible. On 4s your looking at a nice sport setup.
Old Feb 11, 2013, 10:46 PM
EDF Addicted
Ocala,Florida
Joined Sep 2005
Awesome, i need that exact battery anyway
Old Feb 12, 2013, 12:23 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
that was the very first setup i tried, was really hard to get it running smoothly, i was using the stock sky angel 50mm motor as well, and stators cut down to fit in a 40 shroud. does about 200W on 4s 750, and i think that kv is like 4300. so 4800kv should do you about 250-275W on 750-1000 4s. if you want to run a 4s 1000, youll need to move the fan back about 1" from where the stock ducts end. i made a simple extension with mylar and tape
Jack, i prefer the look of the straight tail on mine, i havnt tried a rudder yet so i cant comment on its knife edge qualities
corsair nut is offline Find More Posts by corsair nut
Old Feb 12, 2013, 12:57 AM
EDF Addicted
Ocala,Florida
Joined Sep 2005
Thanks Brent, ill think on it, i have some 51mm haoye rotors to
Discussion Bvm Electra Jet @ Heart Of Ohio Jet Scramble kevin Electric Ducted Fan Jet Talk 42 Jan 04, 2008 06:30 PM
We have Electra Jet and Pico Jet new In box mmm208 Aircraft - Electric - Airplanes (FS/W) 0 Aug 23, 2002 10:13 AM
WTB or WTT for a Twin Jet, Pico Jet, Electra Jet darenm Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2002 09:46 AM
Electra Jet or Typsy - Anyone got a Electra JET VIDEO CLIP? rojoyinc Parkflyers 3 Apr 21, 2002 11:56 AM
