Old Jun 14, 2010, 07:41 PM
jiggywatt is offline
Find More Posts by jiggywatt
They all fly once
jiggywatt's Avatar
United States, CA, Rialto
Joined Nov 2005
Help!
SSX wing tips
Hello, I am having a heck of a time covering the wing tips on my SSX. I know there may be a link or tip on how to do it the right way. The wing is covered in monocote and when I went to stretch it out all went bad. As suggested, I went to the LHS to get some ultracote but they were out of the color I needed. I'm going to try and use monocote and a heat gun. Thanks in advance.
jiggywatt is offline Find More Posts by jiggywatt
Old Jul 04, 2010, 01:12 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Cut a piece with plenty of extra to cover the wing tip. attache it to the end rib and allow it to cool. lay the wing on a table with the wing tip hanging over the edge of the table and weigh it down by placing some books across the spar and trailing edge. Use a heat gun to stretch the covering. Start at the leading edge and work your way to the trailing edge. allow the covering to cool before releasing and moving down the tip.
Sorry I took so long to answer your post, it was not in the SSX build thread so I did not notice it rite away.
James
jkarpy is offline Find More Posts by jkarpy
Old Jul 11, 2010, 05:41 PM
They all fly once
jiggywatt's Avatar
Joined Nov 2005
Thanks for the tip. It ain't pretty, but I managed to get the tips covered. I used a combo of heat gun and iron. Some wrinkles just will not come out and the monokote will only take so much heat before it melts.
Old Jul 11, 2010, 05:48 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Looks like it will fly!
Good luck,
James
Old Jul 11, 2010, 05:59 PM
They all fly once
jiggywatt's Avatar
Joined Nov 2005
Thanks James. I built this one as a trainer, but I also have one of the ARF SSX that I am afraid I'll crash. First aileron plane in a long time.
Discussion How will effect Wing Tips on a rc wing? guyg Aerial Photography 15 Jul 27, 2015 05:39 PM
Question Aircraft stability with fuel tanks on wing tips djacob7 Modeling Science 20 Apr 22, 2010 08:06 PM
Wanted Parts Wing tips for Xplorer apcoflyer Aircraft - Sailplanes (FS/W) 0 Mar 14, 2010 04:02 PM
Discussion Wing Tips Tips Chophop The Builders Workshop 2 Dec 16, 2009 08:35 PM
Discussion SSX trainer wing Lawpilot Millennium R/C 1 Dec 04, 2007 09:00 PM
